Voltage of HV Battery when fully charged?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ericbecky, Dec 7, 2025.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Tried to find a definitive answer and coming up empty.
    What is the voltage of the HV battery pack when it is fully charged from the external plug?
    If you have Dr. Prius app, it would be noted in the upper left hand corner.
  2. jacktheripper
    jacktheripper Senior Member
    284
    558
    Yo Eric!
    Long time no chat! If my memory serves me right, the pack voltage usually ranges from about 200–224V. I don’t remember ever seeing anything higher than that, but I could be wrong.
    Best,
    Jack
  3. ChapmanF
    18,996
    This is a gen 1 plug-in thread; I don't remember the battery specs for the plug-in offhand.
    ericbecky likes this.
  4. ericbecky
    4,451
    3,359
    Madison, Wisconsin
  5. PriusCamper
    PriusCamper Senior Member
    13,438
    5,424
    Pacific Northwest, USA
    I thought there was a chance they used a higher voltage pack and added some voltage spoofing like has been developed in other aftermarket systems, but seems like Jack is confirming they didn't do that.
  6. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I have a 250v charger so that should work fine.
    PriusCamper likes this.
  7. PriusCamper
    13,438
    5,424
    Yeah... but Lithium is super easy to overcharge and isn't forgiving at all like NiMH so be careful! Of course Jack sells replacement packs with near double the range if you do forget you were charging it after its too late: 2012 - 2015 Toyota Prius plug-in Lithium battery pack
  8. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Agreed. Gotta be careful.
    Just doing some regulated tests.
