Voltage on headlight high. 14 volts +
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Uberfast, Jul 25, 2016.
  1. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    Hi there. 2014 Prius V. Voltage on headlights 14. 63 volts. This reading is from of the low beam headlights. What could be causing this problem. Thanks for the help.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,983
    4,727
    Texas Hill Country
    Probably normal. Just means the system is charging the 12 v battery. Check the voltage at the jump spot in the fuse box and again using the display diagnostic modes. Let the system remain in Ready for 10 minutes and it may go down. Plus some digital meters have been known to read a little high, like the free ones from Harbor Freight.
    Prius v Display Audio Service Menu w Battery Check | PriusChat
    #2 rjparker, Jul 25, 2016
  3. CR94
    CR94 Senior Member
    2,642
    1,138
    Northwestern S.C.
    Was that value measured at the bulb connector with both lights operating, with good bulbs? If not, it doesn't mean much; some voltage drop between fuse box and bulb is normal with operating bulbs.
    After frequent complaints of short headlight bulb life in some early 3rd-generation regular Prii, Toyota issued a technical service bulletin to correct the problem by splicing in an added wiring harness on each side. It amounts to adding a small resistance in series with each bulb. I haven't heard of the vagon being involved.
  4. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Normal when in Ready Mode, our car measures 14.4v at the jump terminal in the engine fusebox. I suspect that that's the reason why the Prius headlights burn out pretty quickly. The plus is that the bulbs burn a bit brighter. ;)
  5. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
    My 2012 Prius v is 14.3 or 14.4 volts when in Ready. 14.6 seems a little high, but not much.
    16:50 minutes to 18:05 minutes describes the 12 volt charging system.
  6. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Very informative. Ok. Will look into this more. Thank you.
    Yes the bulbs are new. Voltage tested at bulb connectors.
  7. rjparker
    7,983
    4,727
    Texas Hill Country
    You can see 14.6 when the 12v battery has been discharged a little. The regulator will back off incrementally as the battery charge comes higher to perhaps 13.6v.
  8. ChapmanF
    15,666
    You haven't said whether you tested the voltage at the bulb connectors with the bulbs in place and lit. As CR94 pointed out, that's the only measurement that tells what you need to know. You need thin backprobes for your meter in order to do that. Insert the backprobes around the outside circumference of the rubber wire seals.
    What you need to know is the voltage after the expected voltage drop caused by the wire harness, and without the bulb present drawing current, there is no drop.
    -Chap
    CR94 likes this.
