Voltage Reading from Fuse Box +12V Cleat to Ground When 'Running'
Discussion in 'Prius v Technical Discussion' started by Air_Boss, Jul 4, 2016.
  1. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    On a 2012 Prius v Five...
    What voltage should be present from fuse box nominally +12V guarded 'cleat' to ground?
    I would have thought +13.8-+14.2V (over +12.8V) when the inverter is operating, but I only see +/- +12.8V.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My Scangauge II shows 14.4 v but I do not have a multimeter.
  3. Air_Boss
    3,952
    1,083
    New Yawk
    Thanks. Hmmm.
    Where on the bus does the scangauge read?
    Any reason to believe the guarded cleat to ground reading would be different?
    49,490
    i'll check mine. the cold reading yesterday morning was 12.87
  5. bisco
    49,490
    mine reads 14.57 at the fuse box, car in 'ready', that is, foot on brake, press power button once.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It is a data value on the OBDII bus perhaps in the inverter. The cleat in the front fusebox is attached to the battery by a long, large cable
  7. Air_Boss
    3,952
    1,083
    New Yawk
    Weird. +12.83 volts cleat to ground in READY mode..
  8. bisco
    49,490
    huh, i wonder if pip is different.(n)
    what does it read with the car off?
  9. Air_Boss
    3,952
    1,083
    New Yawk
    Roughly same, +12.6 to +12.8V depending on state of charge.
  10. bisco
    49,490
    interesting. hopefully, someone with a v and multi meter will check.
  11. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Voltages on my 2012 v, I get 12.7 vdc when system is off as measured at the fuse box takeoff, 11.7 when ON and AC/Lights on but not in ready, and 14.27 vdc when in Ready Mode with AC and lights on.
    The car had just been run about 50 miles 15 minutes before my measurements, so the12v battery probably did not need much charge. I would consider an inverter problem with no real change from off to Ready. Is it actually coming on and saying Ready?
    #11 rjparker, Jul 4, 2016
  12. Air_Boss
    3,952
    1,083
    New Yawk
    Oh, yeah, and there is no indication of a lack of 12V maintenance charge, either.
    This is just (and all) about being unable to use a module that senses >13.2V to trigger a relay to power an accessory.
    Frustrating.
  13. bisco
    49,490
    ya, that kine of stuff in a prius is tricky.
  14. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
  15. Air_Boss
    3,952
    1,083
    New Yawk
    Using that delay relay requires finding a source of +12V with IG2 "on", which has been elusive.
  16. gafortiby
    gafortiby Member
    74
    45
    Colorado
    You could just tap into the fuel injectors or ignition coil circuit. Those are only energized when ig2 is energized. Is IG2 normally open or normally closed? You know what I mean.
    Apparently you can also tap off the washer fluid pump or inverter.
    Highbeam 50% DRL mod, completed | Page 3 | PriusChat
    #16 gafortiby, Sep 23, 2016
  17. gafortiby
    gafortiby Member
    74
    45
    Colorado
    A safer but not as satisfying solution would be to tie into glove box light circuit which is always and only on when headlights are on.
    If you had a 2014 then I would have also said the DRL circuit but I think your 2012 doesn't have DRL.
  18. ChapmanF
    15,615
    Those gadgets (like the InPower VCM-06) typically work great in a Prius.
    Something very peculiar seems to be going on with your particular Prius. You can see that the others responding to your question are doing the same measurement and getting the expected value (high 13s to mid 14s when the car is READY ON).
    Before diving too deep into possible explanations why your Prius is different ... are you sure it is READY ON when you make this measurement?
    -Chap
  19. ChapmanF
    15,615
    When a ScanGauge shows 12 V bus voltage, it may be measuring directly. One of the standard OBD-II connector pins is specified to be an unswitched 12 V supply. (This is why caution is recommended when probing pins in that connector, even if the car is off.)
    -Chap
  20. Air_Boss
    3,952
    1,083
    New Yawk
    Turned out to be an open GROUND in the relay harness driven by the >13.2V sensor. One strategic splice later, works fine.
