Volume knob pushed in
Discussion in 'Prius c Audio and Electronics' started by cmstlist, Jan 12, 2013.
  1. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    At some point I must have pushed the volume knob in too far, because it's now kind of recessed and harder to turn compared to the tuning knob on the right.
    I had wondered if I was just imagining this, and maybe it was always that way. Then a few weeks ago in Toronto my friend picked me up in a car share vehicle that also happened to be a C, and I realized the volume knob was normal whereas mine is not.
    Any chance I'll just be able to pop it back into place? Or should I just check with a dealer on warranty? This is on a Canadian base model, C2 equivalent.
    Galaxy Nexus ? 2
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Can't hurt trying to pull it out. Worst case is u break it.......then have dealer fix under warranty.
  3. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    I can't actually find any obvious way to accomplish that.
    Nexus 7 ? HD
  4. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Play it safe and take it back to the dealership for warranty work.
  5. Walt_NY
    Walt_NY New Member
    I noticed the same thing after my wife drove my C2 - she must have hated whatever was coming out of the radio and smashed the power button! Now I have to use the steering wheel controls to change the volume. Has anyone discovered a fix?
  6. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    Take to dealer?
    Pull out with fingers?
    Pull out with pliers which have been cushioned to not scratch button?
  7. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Wrap your pliers with rubber bands. This maintains the grip, but eliminates the scratching.
  8. Walt_NY
    Walt_NY New Member
    To follow up... At my 6-month service I asked the dealer to check the volume knob. They agreed to replace the whole radio (under warranty).
    I was not able to find a simple fix. I could pull the knob out with my fingertips, but it would just pop right back in. I didn't bother to remove the radio to investigate in any detail.
    RocMills likes this.
  9. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Yeah they did a full replacement of the stereo on mine too.
    Nexus 7 ? 4
  10. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I had the same problem, just swapped the volume knob with the tunning knob since the tunning knob just needs to spin. The knob had been pushed in to hard and broke the teeth on the back.
  11. Anthony W
    Anthony W Junior Member
    Washington
    2002 Prius
    How did you swap the volume knobs? Do you just pull on them really hard and pull them out? Or do you have to remove the radio unit to get to them? I have the same problem. Power volume mashed in and I have to pull it out with my fingers to get a grip good enough to turn it.
  12. ChapmanF
    18,955
    Is this just a case of the knob being too flimsy, so something snaps inside of it and it goes too far down on the shaft?
    If I could pull the knob off I might try carefully dabbing Plasti Dip down into the shaft hole to build enough up to stop the knob at the right depth again.
  13. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
