Volume Randomly Going Up and Down
Discussion in 'Gen 3 Prius Main Forum' started by dannybjax, Sep 11, 2020.
Tags:
  1. dannybjax
    dannybjax Junior Member
    Jacksonville, FL
    I have 3 Prius'. The volume on my Gen 3 2011 goes down (and sometimes up) at random while I'm driving without touching any buttons. It goes down a lot (like from 35 to 25) and it's random so it's not going down as I go faster and I'm not touching the steering wheel controls either. Anyone ever seen that? Thanks in advance!
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Which one of the 3 2011 cars that's doing that?
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    When this happens, does he volume banner on the MFD show?
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    my 2006 goes up and down randomly sometimes, and when it does, the volume shows on the MFD as if i'm using the steering wheel buttons. i'm thinking the clock spring in the steering column is failing?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Mine occasionally does that when the signal is getting weak and it goes into and out of "HD" mode.
  6. dannybjax
    Jacksonville, FL
    Sorry - correction - it's my 2012 Prius II with "stock" touch screen radio.
  7. dannybjax
    Jacksonville, FL
    Nope - no changes on the MFD. The radio display reflects the volume (which goes up and down erratically)
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I currently have this happening randomly on my 2007. It stops if I move the steering wheel slightly, so I'm pretty sure it's a clock spring issue. Just glad it's something minor like the volume and not temp, lol.
    dannybjax likes this.
  9. dannybjax
    Jacksonville, FL
    Thanks for the idea TMR - I tested it today and the movement of the steering wheel did not seem to make a difference.
