Volumn Automatically adjusted based on speed...am I missing something
Discussion in 'Gen 3 Prius Audio and Electronics' started by lauren80ryan, Jul 2, 2009.
  1. lauren80ryan
    lauren80ryan New Member
    165
    26
    Tri-Cities, WA
    I SWEAR the Gen II had the volumn on the stereo automatically controlled based on speed. Like it would increase/decrease my blaring radio station as I sped up or slowed down. But my new prius is NOT doing that.:(
    Is this an option somewhere?? Or did they remove this feature?? Or did I imagine it on the II?
    Thanks!!!:D
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The Prius did not have that feature. The only cars I've driven that had the auto volume were GM cars. I always thought it was a gret feature.
  3. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    The Prius does have that feature - I think they call it. It is controllable through the Audio control screen. It is not very effective, I can hardly tell whether it is doing anything.
    kevin
  4. wsrussell
    wsrussell New Member
    34
    Denver
    It is there (at least on my III with Nav), select audio and the the DSP (I think) tab...you can turn it on or off.
  5. Jabber
    Jabber Chicagoland Prius Guy
    703
    213
    Chicago
    With Nav cars, do as WSRussell said. With non-Navi cars, press the tune button 5 times (6 times on a JBL radio). You will see ASL as an option. Turn the tune button to select your preference (high, medium, low, off).
    2 people like this.
  6. hptsang
    hptsang Member
    139
    Houston, Tx
    I am sure that the NAV has it because I remember the sales mention about the volume adjust base on the speed
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    What's most noticeable in the NAV versions is the increase in BASS level when Auto Sound Leveling (ASL) is enabled at higher speeds.
  8. baz
    baz Previously owned Volvo S60R, Prius, Volvo XC70 T6
    Edmonds, USA
    If the ASL feature IS working surely one should be able to see this by monitoring the Volume level numeric value. As speed is increased this numeric volume level SHOULD increase, right ?
  9. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Yep, the Gen II did this. Once I added better speakers, an amp and a sub woofer the profile of the auto volume is WAY too bass-heavy for my taste, so I turned it off.
    Nope, it doesn't show up as an increase in the volume number on the Gen II (so I doubt it will on the Gen III). But it DOES increase the volume, and, as noted above, the increase is not linear across the frequency spectrum.
  10. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    ASL was not very effective on my Gen II Navi and it's the same for my Gen III Navi.
  11. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Non-Nav cars only have a choice to turn ASL on or off...no variable settings like high or low.
  12. fuzzy1
    10,282
    My Non-Nav car has ASL choices of Off, Low, Mid, and Hi.
    In case it makes any difference, my audio system is Type B (Owner's Manual pages 291-2).
    It does make a difference, see page 321.
  13. wave_slider
    wave_slider New Member
    201
    26
    the aloha state
    I've never really cared for the ASL feature. It works ok if you drive with the windows down. It will help to compensate for the wind noise.
  14. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Yep, my 2007 non-nav has the same ASL choices.
    First you go to the Audio screen.
    Then you touch the DSP button, which will bring up the ASL choices.
  15. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    The ASL on any Toyota or Lexus I've owned hasn't been very effective.
  16. dmvp
    dmvp Member
    364
    Thanks for clarifying, Fuzzy! It looks as though the JBL (Type A) is either "on" or "off", however, the Type B has a range of choices.
    :D
  17. lauren80ryan
    165
    26
    Tri-Cities, WA
    Navi only has on or off option. And I turned it off and didn't notice anything different to when it was on. I really noticed it going highway to non-highway in the GEN II we rented for the weekend (package #2) but I hear NOTHING on mine!
    Maybe it's a more gradual raise/decline so I don't notice it?!? I am disappointed that I can't tell it's on cause I thought that feature was great!
    Guess I'll play around a bit more with my other sound settings and see if I can tell any difference.
    Thanks for all the comments. :)
