VSC, ABS, BRAKE AND (!) LIGHTS ON
Discussion in 'Gen 2 Prius Main Forum' started by calin.ceascai, Jan 8, 2018.
  1. calin.ceascai
    calin.ceascai Junior Member
    RO
    Hi there. Today I replaced my front rotors and brake pads. Everything was ok but at the end I have 4 warning lights on.
    I ave a new 12V battery and I was disconnected for severa minutes the negative wire from 12V battery and the problem was not solved.
    Anyone can help with sugestion? IMG_20180108_212542.jpg IMG_20180108_150553.jpg IMG_20180108_150533.jpg
    Trimis de pe Huawei P10 Leica folosind Tapatalk
    52,915
    did you disconnect any wires down there, on purpose or inadvertently?
  3. calin.ceascai
    RO
    Nope. There is no wires.
  4. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Did you pull the starting battery before you started the work? The bake bake acccumulator may be sensing too much, not enough fluid and sending an error. This is a common problem when changing front breaks.
  5. ChapmanF
    19,061
    Welcome!
    If you jump into this other recent thread right about here, you can see the easy way to find out exactly what your brake computer is trying to tell you about the brakes, and that may lead more quickly to the solution.
    -Chap
  6. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Go to parts store (O'Reilleys, Autozone, etc.) and borrow their scanner. Plug it into the port underneath the steering column on right side. Enter vehicle information and read the ABS codes.
    It will tell you what the problem is. When I had exact same codes it was a rear right speed sensor. So I spent $100 at O'Reilleys and bought a rear wheel bearing assembly (comes with speed sensor). And I paid a mechanic $80 to install.
    Did you unplug anything when you were doing brakes?
  7. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Y not get a scantool to clear those codes first?
  8. padroo
    padroo Senior Member
    2,763
    2,253
    Always write down the codes before you clear them.
  9. ChapmanF
    19,061
    How are you able to say when you had exact same codes, when the OP hasn't posted any codes yet?
    -Chap
    SFO likes this.
  10. calin.ceascai
    RO
    I'm in Romania so I cannot go to O'Reilleys or Autozone. I was to a tester and he cleared the erors so everything is fine now.
    Maybe was just from pushing back the brake pistons without any unplug ABS....
  11. calin.ceascai
    RO
    No. I didnt know. Thanks. I erased the erors and the problem is solved.
  12. MilkyWay
    823
    359
    23
    MI
    What I meant was I had the 4 exact symbols on the dash.
  13. ChapmanF
    19,061
    So does everybody else who has one of a few hundred possible issues detected by the brake/skid ECU and identified by the trouble codes you can read. The point of the lights is to go get the codes read; the issue can't be identified just from the lights being on.
    -Chap
    valde3, dolj and Prodigyplace like this.
  14. MilkyWay
    823
    359
    23
    MI
    Reread what I wrote. I was just randomly saying when I had those lights on the dash my code happened to be so and so and my fix was so and so. I wasn't saying that his code was going to be the same as mine (although on just about every car if you have an ABS/brake light on very good chance it is a speed sensor). FYI, if you go to my original post in the very first sentence I advise him to get the codes scanned.
  15. ChapmanF
    19,061
    Yes, that part I can confirm by re-reading it, and I'm completely on board with that advice.
    (emphasis added)
    That part I can't confirm, even by re-reading, because what you said was still
    (emphasis again added),
    ... and it's not possible to say when you might have had the exact same codes, because nobody at that point in the thread even knew what codes they'd have to have been the same as.
    It may be entirely possible you were thinking "lights on the dash" and your fingers just wrote "codes"; that happens to me all the time. I didn't point it out for the purpose of flaming you, it just made a good case in point for helping future readers see why the dash lights alone aren't enough to identify a problem. (And it would have been an almost equally good case in point had you said it the other way.) It's certainly not a big enough deal to be worth the effort of pretending to have written something else.
    Peace,
    -Chap
    Prodigyplace likes this.
  16. MilkyWay
    823
    359
    23
    MI
    ok, you are taking what I wrote to a very literal level. It should be very obvious that if someone on priuschat posts this (actual screenshot of post):
    And I respond with (actual screenshot of post):
    That I didn't mean literally that I bought a plane ticket to Romania, drove to OPs house, broke into his home, stole his Prius key, plugged in my scanner, and got a rear right speed sensor code, flew back to the states, got onto my computer and said, "By the way, I have the exact same codes as you do because I scanned your car". Obviously I meant same symbols on dash, lights on dash, codes on dash, things on dash, stuff on dash, pictures on the dash, etc.
    Nobody on the planet is dumb enough to think that if 2 cars have an ABS light, that the 2 cars have the exact same symptoms, producing the exact same codes on a scan tool, requiring the exact same repair. And I never wrote that at all. He asked for help, I told him to scan it, and then gave an example of when I had an ABS code it just so happened to be "......". All clearly written without any way to confuse it.
  17. ChapmanF
    19,061
    Here I think you're being unfair to the numerous PriusChat newbies who regularly do tag on to old threads with "I'm having the exact same problem" when there is no basis, other than dash lights, for them to think so. It's not because they're dumb (and certainly not planet-toppingly dumb). It's because they don't get how it works yet, and we can help with that.
    C'mon ... something can be a somewhat loose expression that you're counting on readers to sort out for you, or it can be clearly written with no way to confuse it, but it usually isn't both. :)
    Crossing out 'codes' and writing 'symbols' does make it clearer ... but that seems to have happened after the fact.
    I'm totally willing to believe that you personally aren't under the misapprehension that dash lights alone are enough to identify problems, and you just happened to write something loosely one time that sort of came out that way. But as long as there are other people regularly showing up who really don't know better yet, your post was a good conversation starter about that—even if that wasn't what you set out to do.
    -Chap
  18. Mohammad Awad
    Mohammad Awad New Member
    Jordan
    I have the same problem
    and the code is C1256 what is the solution
  19. John McGlynn
    John McGlynn New Member
    JACKSONVILLE, FL
    My 20 year old daughter’s GEN 2 Prius got the same problem shortly after having a 4 wheel brake job done at a local shop. I suggested she take it back but she took it to another shop and they diagnosed a $2400 repair. The car has 235,000 miles. I found a utube video that shows how to reset the display with a safety pin to short out pins 4 to 14 with a paper clip. The problem is I can’t find codes connector. Any suggestion?
  20. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    Probably, just as well, those are the wrong pins.
