VSC, ABS, BRAKE AND (!) LIGHTS ON
Discussion in 'Gen 2 Prius Main Forum' started by calin.ceascai, Jan 8, 2018.
  1. John McGlynn
    John McGlynn New Member
    JACKSONVILLE, FL
    Well late yesterday I reached down under the dash with my right hand under my knee and found the OBDII Connector. I don’t know why I missed it before while I had crawled underneath the dash. So per the youtube video I shorted the on top 4th pin from the left to the bottom 4th pin from the right, pushed the brake, pushed the start button, waited till everything stabilized, pumped the brakes 8 times, the the ABS VSC and associated lights reset. Let’s see if it stays off, meanwhile I’m sure it was triggered by the brake job don by s local non Prius experienced shop.
  2. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    So that would be pins 13 and 4, then.
    Agreed. That is a reasonable conclusion. I hope your lights stay off.
