vsc abs (!) lit after obd2 plugged in
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rowand, Jul 17, 2018.
  1. rowand
    rowand New Member
    New South Wales
    hey guys, i’m newbie, just newly own a hybrid vehicle. prius 2005 gen 2.
    i bought ELM327 WiFi OBD2 scanner.
    first time i plugged in was ok perfectly running connected to my phone, then i did run the deep scan. and then i accidentally close the app(car scanner) while the deep scan running. i saw the OBD2 stop blinking.
    i turn off the car. reconnect the obd.
    and the obd doesn’t want to turn on. and VSC lit after wait 10 sec the abs and (!) lit.
    i cannot use the obd again
    49,707
    welcome!
    sometimes obd's make prius computers unhappy. clear the codes and see if they come back.
  3. rowand
    rowand New Member
    New South Wales
    how do i clear the code?
    i did zero calibration with pin 13 and 7. still the obd2 not working after i plug in.
    49,707
    try disconnecting the 12v negative for a few minutes.
