VSC Brake lights on - C1345 error code - will not clear - my fault?
Discussion in 'Gen 2 Prius Main Forum' started by PriusDadNoob, Jul 18, 2024.
  1. PriusDadNoob
    PriusDadNoob Junior Member
    72
    2008 Prius. My steering was "loose" at speed so I connected my laptop to the OBD2 port, fired up Techstream and then... clicked the wrong buttons. Muscle memory I guess, from dealing with the brakes on several Gen 2 prius: I went into the ABS/VSC/TRAC area in techstream and did the relearn procedure instead of the going to the steering area (EMPS) and reseting the angle sensor. (resetting the angle sensor fixed my "loose" steering when I was driving over 40 MPH in the past but that is another issue)
    Now my brake light, ABS and VSC lights are all on and will not clear with Techstream or the paperclip method. (Pins 4 and 13, pump the brakes 8 times etc.) The car will drive but the brakes are not working right, they are like traditional brakes, not regenerative braking I guess.
    The thing is, the car was FINE. No lights, nothing, just that loose steering issue. This problem only occurred after I clicked the wrong button in Techstream!!! Now the error code C1345 will not go away and the brakes are not right. Did I do something wrong when I did the relearn procedure? I have searched this forum and cannot find the proper procedure for a 2008, only a PDF of the 2010 procedure.
    Here is what I tried:
    Open Techstream
    Go to Chassis
    Open ABS/VSC/TRAC
    Entered Utilities
    Ran the reset memory procedure
    Ran the Test Mode procedure
    Ran the ECB Utility - Linear Valve Offset
    Ran the Signal Check
    Errors still persist and I'm desperate as this is my daily driver!
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    Generally you didn't do anything wrong you just messed with something that didn't need to be messed with but that doesn't matter now so when you do the linear valve offset relearn does it do the procedure and past or fail? If it's continuously failing I fear to say you may have created something going on in the actuator circuitry.! It is possible I don't see why is this a already replaced actuator in this vehicle? If not it might be getting one so maybe it was time anyway. Hard to say especially if it's accepting the relearn procedure for the linear valve then I'm pretty stumped too maybe take the power away from the car for the night literally undo the 12 volt take the plug out of the HD battery just because or not I guess you can leave it and it's not going to make any difference Make sure the 12 volt goes dead and silent the system. And then in the morning boot everything back up and see what you got The only thing I can think of is in fact the linear valve offset is resetting and holding.
    PriusDadNoob likes this.
  3. ChapmanF
    19,006
    Do you hear it trying to learn the linear valve offset? It takes a minute or so, and makes a series of clicks and increasingly loud whooshes.
    If it isn't doing that, I wonder if there's some simple step in the repair manual prep for the procedure that has been overlooked.
    Another issue, but that is interesting; there may be a chance you fooled yourself there. Could you show a screenshot of where in the EMPS area you found an angle sensor reset?
    I am asking because, as far as I know,
    • The steering angle sensor isn't even an input to the EMPS ECU. (The steering torque sensor is, but the angle sensor is not.) The angle sensor is only an input to the skid ECU.
    • The skid ECU doesn't need you to do anything to calibrate the angle sensor. When you're driving straight ahead according to the yaw sensor and equal wheel speeds, it looks at whatever the angle sensor is reading and remembers "ok, that's zero angle."
    Or is it possible you were remembering going to the EMPS area and calibrating the torque sensor zero point?
  4. PriusDadNoob
    72
    @ChapmanF I checked and you are absolutely correct on the steering bit. I did the torque sensor zero point, not the angle sensor! It did seem to help with the loose steering at speed, for a few minutes, then it went back to the old feeling after restarting the car. I'm fairly certain it is providing too much power steering at speed. Perhaps I just need to replace that power steering module. I would welcome you opinion on that.
    BUT back to my major problem :-(
    It did make the series of clicks and bonks when I did the relearn. I will try to share screen shots of each screen I am using, but I am fairly certain I was on the right screen. I am not certain, however, that it was fully complete. It did say, "process complete when the light blink" (or something similar) but I did not see a final "blink" at the end of the procedure. The lights blink during the relearn, but there is not a final blink after they go solid at the last big bonk sound.
    Do you have to wait some time after the end of the procedure before exiting the test? One test says to "wait 2 seconds then wait as long as the manual says" which I do not know how long that might be. Do I need to do all the steps I described all over again each time? (Reset, Test Mode, etc.?) I have replaced the accumulator and actuator on a few of these and it's not a fun job. I'd rather not do it for a car that does not need it, and it was running fine yesterday. To answer your question I do not believe it has been replaced. Car has 253,000 miles.
    I feel certain that I can fix this via Techstream with the correct procedure. There is a chance the test literally broke the actuator (if it was about to fail??) but that seems unlikely given there were no symptoms.
    Brake fluid level is fine.
  5. PriusDadNoob
    72
    @Tombukt2
    Thank you for your ideas. I will try to disconnect the 12v and HV battery overnight and see if that helps. I did the 12v battery for 45 min to no avail. What do you think could be the issue with the "actuator circuitry"? And do you know how to tell if it is actually accepting the relearn? Many YouTube videos later, people show doing the relearn and "look, the light is off!" but that is not my case :-(
    Car has 253,000 and has the original actuator as far as I know. That job is a bear and the used actuators are fairly pricey AND I am not sure that is even the problem. Would be pretty bad to do all that work and have that light still light up.
    Are there any other reset procedures or "get it out of test mode" procedures that I might be missing? It's so crazy that there were no lights on and the brakes were fine until I did that relearn accidentally!
    Any more ideas would be appreciated and thank you.
  6. ChapmanF
    19,006
    I've done the linear offset learning on a gen 3 but never personally on a gen 2. It sounds similar from your description, but I probably shouldn't guess at the exact clicks and bonks and light blinks.
    If you had just done some brake work, I'd be asking how confident you were of your air bleeding job. I'd guess bubbles could play havoc with the learning process, and so possibly could misadjustment of the gen 2 rear drum brake shoes.
    Have you gone straight to the repair manual to review the learning procedure in all its glorious detail?
    Toyota Service Information and Where To Find It | PriusChat
    I would certainly do that, before taking any more drastic steps.
  7. PriusDadNoob
    72
    Great advice as usual @ChapmanF I do t have the manual but will follow your link and see about getting one. I’ll also inspect brakes and maybe even bleed them. That’s not too tough and much simpler than the actuator.
    I’ll let you know how it goes. I’d like to avoid the dreaded dealer option. They will likely just recommend an actuator anyway unless they have a good mechanic. I have never taken any of my prii to the dealer.
  8. ChapmanF
    19,006
    If you really had not done any brake work, and the trouble only started when you ran this learning procedure unnecessarily, then I probably wouldn't jump too quickly into actually doing any kind of brake work, adding to the no brake work you did to begin with. I think that could have a nonzero chance of making the situation more confusing.
    I would probably make poring over the relearn procedure in the manual my first priority.
    If that didn't end up getting me anywhere, then I would be looking at inspecting/bleeding/whatever.
  9. PriusDadNoob
    72
    Will do. I’ll get a copy of the manual and make sure I’ve done things correctly.
    I did drive it 15 miles to work today. Strange to drive a prius with “regular brakes” no regen. The rear brakes did seem to stick ever so slightly but they probably have not had a workout in a while. Good news is that accumulator buzzed every once in a while which means it seems to be doing its job.
    Thanks again and I’ll be back here later. Currently at work so I’ll take a look at this tonight.
    Pioneerscot likes this.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    One of the main points in the "pre"-procedure is that the 12V battery is healthy and fully charged. This can cause the initialization (relearn) to fail, and affects how quickly it will complete.
    Might consider hanging a charger on it for the duration.
    BuckleSpring and PriusDadNoob like this.
  11. PriusDadNoob
    72
    Update: I tried to disconnect the 12v and HV battery overnight. That did not help.
    I have made a video of the issue. I have read the manual and I think I am doing this right but the calibration never completes. The light do not blink quickly and they do not clear.
    Still need some ideas guys. I will try to run the procedure with a charger connected to the 12 v battery. But I always heard that is bad for the system. I have charged the battery ONLY while it was out of the car. Never while it was connected with both positive and negative. Will that hurt my prius?
    here is the video
  12. Tombukt2
    13,845
    2,515
    Durham NC
    No you can have a battery tender or a battery charger set down on the two amp charge mode or something like that not on the 30 amp jump start mode or any of that nonsense and it won't hurt a thing. Don't feel bad on that linear valve offset thing I have legitimate version of tech and I can't get the last whatever four lights that flash or flashed fast mine start flashing fast when I start the thing but then at the end the light goes off but I don't get the lights flashing fast or whatever it is they're supposed to do there's nothing I'm standing there staring at the thing for 8 minutes wondering and then I just turn the car off reboot the car check the brakes and the lights are all off and everything's fine but it doesn't do what the instructions say it's going to do It never has on any one of these I've done I've only had to do the linear valve offset about four times and they were generally on brand new break actuators A lot of times when I move them from a car to a car I don't have to do the linear valve at all If I take it off correctly I barely have to bleed the brakes but I always connect tech and at least do the part or you're pumping the brakes 30 times and 30 seconds and activating the internal valves and then that's it.
  13. PriusDadNoob
    72
    Problem solved! Thanks for all the help.
    @mr_guy_mann you win the prize. It was a 12v battery problem. I connected my (old style Schumacker 2 amp, 12v) battery charger to the 12v battery and ran the procedure just like before, but this time it worked (12v battery is Optima yellow but 5 years old AND I drained it once while I was working on the HV battery and forgot to disconnect it)
    The only difference was that when the test was supposed to be done the lights DID blink quickly and that also cleared the C1345 code and the car is starting up just fine.
    I'm not sure if my 12 battery is actually bad or if connecting a 12v charger is really just the best way to run this test. Time will tell if my 12V battery decides to die (I will search PriusChat for how to know if my Optima is dying, I am sure there is a thread)
    Thank you all SO much. I hope I can help you as well someday. ...Now to run the actual steering torque sensor zero point procedure and hopefully get my 2008 Prius to stop applying power steering while I'm driving at speed!
    bisco and Brian1954 like this.
  14. mr_guy_mann
    4,113
    2,011
    NJ-USA
    I would charge the 12V fully then get it tested. Don't know about you, but I never have a battery fail at a convenient time. It usually happens in some parking lot late at night when I'm in a rush.
    Optima was a good brand years ago (as was Interstate), but I haven't heard positive things for the past decade or more.
  15. PriusDadNoob
    72
    I know it must be AGM. Is there a brand you like?
