vsc/trac light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bornloser, Jan 19, 2017.
  1. Bornloser
    Bornloser Junior Member
    Arkansas
    I just bought girlfriend a 2010 Prius. Had to look hard to find one with the heated seats she wanted, but found one several hundred miles away. When he delivered it, it was being towed 2 wheels down, and when he started it, it had the vsc/trac light on, even though we were not moving. He said this was common for one that was towed and light would go out after 10 starts..
    Is this true, and if not, how do I clear it?
    Thanks
  2. JC91006
    16,935
    8,645
    That is not really true, did he tow with the rear wheels down?
    Disconnect the 12v battery negative for a few seconds. That might clear it. If it comes back, you've got a problem
  3. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    If he towed it with the ignition on then yes rear wheels down may have caused the light or something to do with the steering angle sensor. There's no reason to leave the ignition on except to keep it in neutral, which is not necessary with rear wheels down.
    iPhone ?
  4. Bornloser
    Arkansas
    I cant state if ignition was on, but rear wheels down. Ill disconnect 12v and check. Ill post back tonight.
    Thanks
  5. trentofdestiny
    1,104
    227
    Harrisburg, PA
    That's good, the way it was towed, anyway. As stated above, if the light comes back on after battery disconnect, then there exists a hard fault. In that case, an auto parts store may be able to read your code (just ask if they can read ABS codes because that's the computer we are dealing with).
    iPhone ?
  6. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Drive 2blocks and it will clear
  7. Bornloser
    Arkansas
    It never cleared by itself...I checked it with MY scanner and found no codes. Long story short, I took it to a dealer that tried to charge me 300 diagnostic fee. After all said and done, no charge, they cleared the error. It takes Techstream to clear it.
  8. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Sounds like it could've needed some type of relearn or initialization. Hard to say. Probably says what they did exactly on your paperwork though.
    iPhone ?
  9. Bornloser
    Arkansas
    Paperwork says left and right speed sensors at $295 each, diagnostics minimum 3 hours
  10. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Ooh sounds like it was towed with ignition on, rear wheels moving, front wheels not. If the towing company had damaged the wiring to the sensors, the error would not have been able to be cleared without repair
    iPhone ?
  11. Bornloser
    Arkansas
    Yeah, I think they read the codes, told me the sensors were bad (and they were not), tried to milk me for un-needed repairs, then cleared the codes and found there was no recurring code because they weren't bad.
  12. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Ugh. Makes sense though. An important part of the diagnostic process is to clear it and see if it comes back, after recording all pertinent codes and data.
    iPhone ?
