VVT Oil Filter? Poor MPG'S?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edthefox5, Jun 4, 2010.
  1. Patrick Wong
    18,213
    6,530
    Hi Andy,
    The oil filter is hiding behind a hex hole plug which is screwed into the cylinder head, around 1" below the intake camshaft timing oil control valve. The plug somewhat resembles the transaxle ATF drain plug. Pls look at the second drawing in my post #4, and also my post #7.
    I haven't bothered to remove this oil filter because 1) until Ed pointed out its existence, I was unaware of it, and 2) since I don't have any relevant DTC posted by the engine ECU nor do I have any driveability or mpg issues, I'm not worried about the filter being clogged.
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Hi Pat, I will look some more. Please do not think I was rushing you, I realise it is a weekend. Thanks for your input.
  3. andyprius
    2,212
    188
    Never found it, 3rd. time. There is a protrusion sticking out on th right, front side of the camshaft cover, slightly below cover. However this has a cap inserted inside, for cleanliness, I suppose. I am wary of punching it out with a screwdriver. also, went to toyparts and they told me they NEVER inspect, clean,replace this filter, in fact they don't even carry this filter! This of course is just one partsmans opinion in one dealership. But being of a veryfying nature:cheer2:, this makes me want to check the filter even more, SO: the filter is in front, on right side, next to (timing oil control valve) whatever that looks like. The pictures from the manual are identical to the repair manual I had on my 84 camry. Either too generalised or too theoretical. So........do I break that protective cap open??????? No apparent exposed hex heads anywhere.
  4. Patrick Wong
    18,213
    6,530
    Hi Andy,
    Pls print the page that I had attached to my post #4. Then take that page with you when you look at your car's engine.
    Find the intake manifold where it attaches to the cylinder head. Then locate cylinder #1 intake manifold port on the cylinder head, which will be to your far left, when you are standing in front of the car looking at the engine.
    Compare that to the page in your hand, which shows you what the cylinder head would look like with the intake manifold removed. You'll find the hex head bolt to the left of the cyl #1 port, around 1" away. That bolt is also ~1" below the camshaft timing control valve.
    If this procedure fails to help you locate the bolt, then pls take a photo of whatever you are looking at.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Hi Patrick & Andy,
    Andy: Its exactly where Patrick said it was....but maybe its not on all models??? My Haynes/Chilton's says its on all models but who knows. Look for this valve in this picture:
    http://priuschat.com/forums/attachment.php?attachmentid=23837&stc=1&d=1275947525
    Whats odd is thats the valve for sure with the electrical connector on it but the engine area in that picture does not resemble at all whats on my 07. Mine looks like the diagram that Patrick posted. It does not have all those plugs under it just a very obvious female hex headed bolt so there may be engine revisions here. Its super obvious on my car but not in the picture I just posted so there must be year changed revisions on this. So go with caution there Andy.
    Andy look at the picture posted. Is that what yours looks like? Or there is a different and third type? Not mine,not the picture but yours?
    BTW, If your car looks like the picture I have no idea which one is the filter hole. Maybe the angled down big bolt?
    Good Luck!!
  6. LoveMyPriusIII
    LoveMyPriusIII New Member
    66
    That's interesting. Does this filer also apply to the 2010?
  7. andyprius
    2,212
    188
    Hello Ed and Pat, From the Photo that Ed sent me, it's impossible to miss, that can is huge! Except, I don't have one! I will "Attempt" to attach a picture, tho I'm not very good at this. One would think all Gen 2s are the same.
  8. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    The "can" with the wires attached is the oil control *solenoid*
    that kicks a spool valve back and forth. Not a filter. The
    filter is clearly slid into a deeper hole in the head, where
    it can actually be in part of the oil flow.
    None of this has *anything* to do with ignition timing. It has
    to do with valve timing on the intake. See this and this for
    how the sprocket "vanes" work with oil pressure. The pressure
    is sent toward the "advance" or "lag" sides or held steady and
    unchanging depending on what timing the ECM wants to see at
    the cam sensor -- full feedback loop.
    I would have difficulty believing that this filter ever needs attention
    unless there's been a much more serious problem with oil filtering
    in general.
    _H*
  9. andyprius
    2,212
    188
    Re: Last para. Yes, That is what the parts person said.
  10. edthefox5
    10,096
    4,840
    Clearwater, Florida
    None of us are confusing the valve with the filter. I did early on in the thread as that was what my manual inferred but Patrick had excellent docs that set me straight at the beginning.
    We are just trying to use the valve location to locate the filter on Andy's model.
    Patrick and I have located it on our 07's. Andy cannot find his as there might not even be one.
    Apparently there are differences throughout the years. All the posters here would like to know that.
    Yes you are correct the VVT is used to advance or retard the intake valve system. Has nothing to do with the ignition. My manual has a very long description of the VVT system I should have read more precisely. Apologies to all as I thought they were working together but the VVT system is separate to control mechanical intake valve timing
    only.:rolleyes:
    And I am not inferring there's an issue. I simply hypothesised if someone had a strange mpg loss issue on an older gen this might be worth a look.
    Not sure why your dismissing a maintianable filter on our engines. You don't think this filter will ever get clogged? Partially clogged? Most people have there oil changed at the dealer with dino Vat oil cause its free.
    I've never even seen this filter mentioned here and I've been here almost 4 years and read posts almost everyday.
    It would be nice to tell a poster to check something other than there battery when there complaining of mysterious mpg loss. See alot of those here.
    My manual says any problem with the VVT system a check of this filter should be performed.
    My manual lists all the sensors the PCM samples to adjust oil flow via the adjustable VVT oil control valve (OCV) to the cam actuator vanes to either advance or retard the cam. These are:
    * Vehicle speed sensor
    * Throttle position sensor
    * Maf
    * Engine coolant temp
    And it says a Diag Code will be thrown and Check Engine Light Set if any problem in the VVT system detected. It does not say what code will be set.
    I would imagine if the oil control valve (OCV) failed and since the engine spark would probably still advance as it would assume proper intake valve advance but if none because of the OCV failure it might spark knock setting knock sensor DTC?
    Of course the engine would sense knock and pull timing and run poorly also.
    But what would happen if the filter is partially clogged allowing oil flow but not 100%. That probably would not throw a code but would impact fuel economy as the cam would not achieve proper advancement. Only way to tell is for us to start checking our filters. Looks pretty easy on my 07.
    What other maladies or codes do you think would set if the OCV failed?
    Thank you.
    BTW, very nice post on the battery smell post there Hobbit. Although I did wince a little when I saw the picture of your fingers across the terminals.:eek:
  11. andyprius
    2,212
    188
    Hi Pat, Ed: I found it, at least a maint man found it for me. It was a rather large metric allen, filter was not particularly dirty. Maybe after my cataract operation on Wed I'll be able to find things. TY Ed and for your patience.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Great! Good job! Thats good news in that they didn't change it for different years. How fine was the filter medium and did you notice the filter o-ring seal they talked alot about?
    Thanks!!!
  13. andyprius
    2,212
    188
    .Hi Ed, The mesh was fairly fine and of very good quality. The oil ring, or O ring was set at the end or to the inside The end that fits on the hex nut was totally flakey, lost its shape easily and was on par with the devices that hold the radiator cover. This was why, when I removed the hex nut, the filter stayed inside and I had to fish for it with a pair of needle nose pliers. ALSO; I sent you a private message. Andy.
  14. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Yes not much to that filter. I went to the dealer today to buy some other stuff and a new o-ring for this filter as I intend to check mine. The filter itself is $11.00 and the o-ring is $2.00 each so not much there. Both not is stock and had to be ordered. Soon as I get them I'll check mine and post pictures.
    ydpplqbd likes this.
  15. edthefox5
    10,096
    4,840
    Clearwater, Florida
    I wanted to check the VVT filter on mine so I ordered the parts and went at it.
    It requires an 8 MM Hex socket and a 3 inch extension. A hex key would be really difficult to use right there. Had to break mine loose with a breaker bar as was socked down good.
    Fist take off the air cleaner assy. That requires a 10 MM socket on a 1/4 inch short extension. The 2 top bolts, the throttle bore clamp bolt found right behind the maf plug, and the intake tube clamp. A 10 MM will work on all 4 of these.
    Disconnect the MAF electrical plug by sqeezing the tab on the connector and gently pull. Pull the air clean/maf assy off the throtlle and set aside.
    Unscew the VVT filter hex bolt head and the filter comes out attached to it at least on mine. I found my filter to be pristeenly clean.
    But I am meticulous about oil & filter changes. I think that filter could be sludge up if your car lives on dealer vat oil and its poorly maintained. Its a very fine filter. Just my opinion. I think Toyota engineering was a little worried about getting debris in the advance and retard oil ports to the cam actuator as I bet those passages are rather small.
    I bought a new filter and metal washer as they were very cheap and I was not sure if I would mess it up taking it out.. The filter plugs into the hex bolt head. Then you can screw it in by hand and torque it down.
    Pretty easy. I don't think on my car its warranted to look at this filter every oil change but at 100K would not hurt.
    While I had it all apart I noticed my throttle body was getting sooty. And I also spotted quite a bit of oil at the bottom of the intake manifold by cracking open the throttle body and peering down the throat. Real nice big puddle there. Seen it before on my car. It has been discussed before here but still not 100% sure why that oil's there. Because of the nature of the intake system of the Atkisson cyle there is some blow back I have heard here.
    Never oil over the mark on the dipstick. Some people have it some don't.
    To clean the throttle body I usually cut up an old t shirt in a strip and stuff it down the throat.
    Crack the bore open and stuff it in with a screwdriver. Deep. Spray soak it good down there with carb cleaner and use it to scrub the throat and the butterfly. When removed everything is clean as a whistle including the oil puddle. I spray clean the butterfly spring and then lubricate it. Re-installed everything and good to go. Whole job was like 30 minutes.
    Since I had the camera out I took some pictures. Shots of my 3 year old Wheel Skinz, Wet Okoles, and my eBay $20 dash mat which I really like. Its missing the eBay Plastic hood that goes over the MFD housing. I Love the Okoles. I need to take them off and hand wash them. But been on for 3 years and still look great. No smoking. Worth every penny.
    Also I picked up a new terrycloth Toyota seat cover at the dealer. $27.95
    Fits real nice and has a hole in it that hangs over the head rest so it doesn't fall down. Just pull it off and machine it. To protect the Okole seat cover. Beats the old bath towel I usually use. Sometimes I get dirty at work.
    Thats right. You have to use covers to cover the cover.......never
    ends. Just like the floor mats. You use crappy floor covers to cover the nice dealer mats.
    Filter: 15678-21010 $11.00
    metal Washer: 90430-14008 $2.00
    ozzy1, m.wynn, Dino33ca and 5 others like this.
  16. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Is it easier to see this hex bolt from the top or bottom?
    I have a car that had a P0011 code( I cleared it) that has not come back but was thinking this filter could be partially clogged. It is a 2008 with 210k that has an excellent service history up to 162k but then a second owner who either serviced somewhere other than Toyota or didn't service. I changed the oil which wasn't too bad. It drives perfect and got 52 MPG on a 45 mile trip with a mix of highway (mostly) and city.
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Interesting discussion. I would assume that the oil flow through this screen filter is immediately downstream on the high pressure side from the engine oil pump and filter. The oil moving through this screen filter would then be pre-filtered by the engine oil filter. So, probably, the only time you would ever have to worry about fouling of the VVTi screen filter is in cases where the engine oil filter is plugged to the point of activating the bypass. Might be something to check in vehicles with questionable maintenance.
  18. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Can you even buy this filter? Thinking about replacing it when I have the urge for a DIY
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Yes I posted the part numbers in post #35.
  20. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Its very hard to see especially on an older car where it may be very dirty. Its a female hex key socket bolt. Have to take the air cleaner assy off.
    Its right below cylinder #1. Be aware that bolt is really hard to get out. I had to use a breaker bar
    and a quality hex socket.
    Please see Patricks directions on his post #21.
