VW Faces $17B Fine for Emissions Scam
Discussion in 'Environmental Discussion' started by Jeff N, Sep 18, 2015.
  1. bwilson4web
    16,543
    Thanks!
    I found the updated mileage figures: Compare Side-by-Side
    When you look at the fixed versus cheat mileage, the differences are so small. Talk about poor judgement.
    52,863
    what about power loss?
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Note that those numbers are for a SCR car - it's the pre-2015s (and not Passats) that don't have SCR.
    In any case, the claimed MPG figures aren't what I'd expect to change significantly - the car was compliant during the test cycle. What the TDIs were known for was beating the test cycle fuel efficiency, because they weren't compliant outside of the test cycle.
    bwilson4web likes this.
  4. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Devil is in the details, from what I have read the fixed cars are not epa compliant either but are “good enough” for horseshoes and hand grenades and being allowed for sale anyway.
  5. bwilson4web
    16,543
    In California?
  6. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    Also, VW originally installed inferior quality Lean NOx Traps (LNT)s in the fraudulent Diesels, which weren't capable of functioning reliably over extended periods when actually being used constantly. Which is why replacement of the LNT is also part of the approved retrofits in the US.
    In Europe, where the longevity requirements are not so demanding, VW's fraudulent Diesels are getting away with just a software update and a cheap little plastic strainer in front of the MAF sensor.
  7. Fred_H
    562
    488
    28
    Germany
    It is common practice both for the EPA and CARB to not require absolute full emissions compliance in cases where the technical or financial burden would be disproportionately large. In such cases, the excess emissions must be compensated by emissions reductions elsewhere. For example: Volkswagen Settlement - Environmental Mitigation Trust for California
    and https://www.epa.gov/sites/production/files/2017-01/documents/vw-dera-option-factsheet-2017-01.pdf
  8. bwilson4web
    16,543
    Drove -68 mi from Huntsville to Manchester TN, all EV to test the 1st day of the 150 kW, CCS, fast DC charger. This means I can drive to Nashville TN in EV all the way and back. Not as fast as on REx nor as cheap, still good practice.
    Comments left in PlugShare: $1.00 + $0.30/min.
    The longest, empty coal car train I've ever seen. Four pulling and one in the last 1/3d.
    Thanks diesel cheater VW. I forgive you.
    #1908 bwilson4web, Aug 1, 2018
    Fred_H likes this.
  9. bwilson4web
    16,543
    I may have spoken too soon. Here is the Electrify America (aka. VW diesel fine) :
    Friday I spent an hour in Manchester TN (#5) trying to get a charge with the support staff . . . no luck. Four chargers, multiple remote reloads, different credit cards and no luck. So I drove 76 mi home on the range extender engine (BMW i3-REx). Support plans to call me when it is fixed.
    #1909 bwilson4web, Aug 26, 2018
    Fred_H likes this.
  10. bisco
    52,863
    i can't find a working location map yet. i see there is one in plymouth mass. should work well if only one ev is visiting the mayflower.
  11. bwilson4web
    16,543
    I use Plugshare because it is user maintained. I've found the commercial maps to be unsatisfactory.
    If interested in the nearest working Electrify America station in Springfield, MA:
    PlugShare - Find Electric Vehicle Charging Locations Near You
  12. bisco
    52,863
    at 15 miles per charge, i will be in springfield by next may.:oops:
  13. El Dobro
    El Dobro A Member
    7,106
    3,282
    Chicopee, MA.
    Welcome to Electrify America | Locations
  14. bisco
    52,863
    good spot, probably a ton of ev's out there.:whistle:
  15. bwilson4web
    16,543
    From the article:
    Overall, they estimated that, each year, 2,700 people within these populations will lose at least a decade of their life due to exposure to excess NOx emissions from passenger cars. They broke this number down by manufacturer and found a wide spread of health impact contributions: Volkswagen, Renault, and General Motors produced diesel cars associated with the most yearly premature deaths, each numbering in the hundreds, while Toyota, Hyundai, and BMW were associated with fewer early deaths.
    "The variation across manufacturers was more than a factor of five, which was much bigger than we expected," Barrett says.
    Unlike particulate matter spewed from smokestacks, such as soot, which mostly settles out in the local area, NOx is first emitted as a gas, which can be carried easily by the wind across thousands of kilometers, before reacting with ammonia to form particulates, a form of the chemical that can ultimately cause respiratory and cardiac problems.
    "There's almost no correlation between who drives [diesel cars] and who incurs the health disbenefits, because the impacts are so diffuse through all of Europe," Barrett says.
    This matches the USA experience in that BMW was the control diesel that met USA emissions on the road.
  16. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    So...more people die each year from vehicular accidents than guns and drugs...and...pollution shortens everyone else's life? Then let's ban all cars and light trucks....problem solved.
  17. hill
    9,039
    All cars? Why ... They're not all diesels, much less, the gross polluters
    HPrimeAdvanced and Mendel Leisk like this.
  18. frodoz737
    4,807
    2,561
    33
    ...and hybrids even less, yet still harmful. Still...more deaths from vehicular accident than drugs and guns. VW makes crappy cars people, move on.
  19. fuzzy1
    10,713
    Uh, no. In the U.S., accidental drug overdoses last year took about 72,000 lives, almost as many as cars and guns combined.
    If one adds in the intentional drug deaths (nearly all suicides), then drugs may even exceed cars and guns combined, but the official figures won't be released until December.
    Note that "drugs" here excludes alcohol (~88,000 deaths per year) and nicotine delivery devices (~450,000 deaths/year). Note also that the alcohol figure double-counts a significant fraction of those deaths from cars and violence, and some of the unintentional drug poisonings as well.
    #1920 fuzzy1, Sep 22, 2018
