VW Jetta GL TDI vs. Toyota Prius in new Popular Mechanics
Discussion in 'Gen 2 Prius Main Forum' started by paprius4030, Jan 5, 2005.
  1. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    Trains have been using diesel-electric hybrid for years.
    Also, did you know the Queen Mary 2 is a (sort of)hybrid? She uses diesel motors to generate electricity which then power electric motors to drive the propellers. She also has 2 gas turbines to generate extra power when the top speed is required. One advantage od this is that there are no propeller shafts so more space for other things, and the motors can be placed "out of the way" Additionally, 2 of the 4 props are in pods which can be rotated to make the ship more manuverable.
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    Re: VW Jetta GL TDI vs. Toyota Prius in new Popular Mechanic
    Apparently you have not been behind a biodiesel vehicle burning the rendering plant version of the fuel - it would make you want to hurl your McDeath fries. :pukeright:
    Hmmmm, I can see the headlines now:
    Biodiesel’s Unintended Benefit: Reduced Coronary Heart Disease in American Cities Which Use the Animal Based Variant of Biodiesel Fuel! Health Experts stumped.
    In a Totally Unrelated Story: McDonald’s Stock Plummets to a New 15 Year Low.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I think most modern ships are that way. The Carnival Triumph was. OT, it was neat to see her use her side thrusters to move sideways away from the pier in Jamaica.
  4. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    The original hybrid cars 100 years ago worked the same - generate electricity some how, use it to run electric motors.
    How does this preclude prop shafts?? Unless we are talking the huge equivilent of a Sail Drive. Looks kind of like an outboard but the engine is on the inside of the hull and the lower unit bolts up through the hull from the outside.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Well ok, I think they meant elimanate the REALLY LONG prop shaft. Obviously there has to be somekind of shaft between the elec. motor and the propleelor except for the azipod type thing which i believe is mounted on the outside of the hull but inside an inlet in the hull.
  6. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Yup -- as well as diesel/hybrid busses.
    But some of the articles I read indicated that getting one in a passenger car would be more of an engineering trick. I'm unclear why (or I've forgotten) -- size? Reliability? Nt sure.
  7. richard schumacher
    7,664
    1,046
    United States
    True! GM had a 50 year head start on building hybrid vehicles; their automotive division either didn't know or didn't care.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    A lot of the new luxury liners are going to or have gone to "pod" style external electric motors with the propeller bolted directly to the motor shaft.
    The primary advantage is the reduction in noise and vibration. Apparently, the long propeller shafts that connect the motors to the props are a major source of vibration.
    Despite a thick steel shaft 2-3 ft in diameter, they are also remarkably easy to bend. That large unbalance will quickly destroy a diesel motor.
    Had a neighbor with a 2002 VW Jetta TDI 5spd. Yes, it was made in Brazil. Horribly unreliable, he traded to a Pontiac minivan, losing a huge amount of money on the trade, and claims much better reliability.
    How sad!
    A recent issue of Consumer Reports tested luxury cars from Germany (Mercedes, BMW) and Lexus. They brought up the issue of reliability and concluded that once renowned reliable cars have tried to use their past to sell quality, while actually being horribly unreliable.
    If my neighbor with his cursed BMW and "i-drive" is any indication, I would have to agree.
  9. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    Easy on the iDrive there sparky.
    I agree, the *implementation* of it, as it currently stands, is awful. However, the technology behind it is incredible. I've chatted with the Siemens guys who wrote it, and its' very nice. It's all written in Java and realtively easy to extend, unlike our cars which is very closed and not at all extendable. :)
  10. ammiels
    ammiels New Member
    121
    brewster, ny
    These are examples of diesel-electric drives. To be a hybrid there needs to be a battery to store excess energy and draw it down later, I remember reading somewhere that D-E locomotives are never shut off out side of the repair barns as there is no way to restart them on board. Idling diesels use remarkably little fuel as ther is no pumping losses. Peace, Ammiel
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I wasn't reporting on how hard it is to use. The one my neighbor has is always on the fritz, completely fubar'd. He frequently bums a ride off me to work or to the BMW shop.
    Ok, he's a nice fellow and means well. He really likes my Prius, and maybe he might buy one and mine won't be all lonely in the heated underground parking.
    Consumer Reports also reported on how unreliable the i-drive thing in general, and BMW's in particular, have become. Maybe Java has something to do with it, if I have to do an embedded RTOS, I use VxWorks or Neutrino and C++.
    "Sparky"
  12. Jonnycat26
    1,748
    New Brunswick, NJ
    Heretic. C++ is great and all, but if you want ease of 3rd party integration, java is the way.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    lots of examples of diesel-electric hybrids, and money is supposedly the limiting factor...
    here are three examples from a trio of unknown car manufacturers
    http://priuschat.com/forums/album_pic.php?pic_id=799
    for complete details of this story, PM me...
    or go to the Chicago Tribune's online edition (www.chicagotribune.com) and look for the article entitled
    Super Car: The tanking of an American Dream
    this article will provide good insight as to why Toyota will become #1 more by default of the big three than their ability to make cars
  14. paprius4030
    2,077
    296
    York,Pa.
    Boy Dave, this just shows you just how much the Big Three dropped the ball! Imagine if Chrysler had a Dodge Stratus dis,/elec. in production today.
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    you aint kidding, i had to edit the post as an afterthought and you posted in the meantime, but what i added pretty much echos your statement.
  16. paprius4030
    2,077
    296
    York,Pa.
    Dave makes you wonder about these auto execs. Poor Lee Iacco saved Chryslers and thses yahoo's are just about driving it into the ground. Imagine a hybrid PT Cruiser, it would put it BACK into a waiting list position like it had when it first came out and like the Prius is now
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i strongly feel that the big 3 are being controlled by oil interests and not what should be done to preserve our environment.
    most of the exec's that make the decisions only need to survive 5-15 years, get their fat pensions, exercise their stock options and spend the rest of their lives in Palm Springs or whatever. so they are doing what they need to do to survive for the short term.
    why do you think the #1 selling point for the big 3 is the size of the rebate?
    Toyota's #1 selling point is quality... it definitely aint the bargain you get since there isnt any. they charge top dollar for the Prius and still cant make em fast enough.
    a very telling statistic
    average rebate for big 3 autos in 2004 $6500
    average rebate for all Toyotas $529
    well you can argue all kinds of points but that point you can take straight to the bank.
  18. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    imo the cars of the big 3 aren't worth what they sell it for. so even with rebates... they probably don't lose any money
  19. Tideland Prius
    16,559
    While browsing two Buyer's Guide (I think it was 02 and 01) I've noticed that the Cadillac DeVille's incentive (back then) almost matched the MSRP increase from 01 to 02. It went up by almost CDN$1000-$2000. If I recall, incentives were around those digits back then. So really, they don't lose anything
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    I don't mess with buggy, cheap consumer gadgets, almost all of my work is in industrial process control with embedded RTOS. I also don't care about "ease of 3rd party integration" as the tools I work with provide enough functionality.
    You pick a proven communication protocol, such as DeviceNet, ControlNet, Foundation FieldBus, or Industrial Ethernet, and make sure the device in the field (Sensor like position, RTD, pressure, ORP, etc) is reliable, with plenty of early warning before catastrophic failure.
    I want rock-solid reliability. If you're messing with sodium hydroxide, chlorine, or other nasty things, the last thing you want to deal with is some deranged OS running wild. I want a system that will do watchdog checks and provide nice Hot Restart groups if something DOES abend.
    According to Consumer Reports, the BMW systems, in particular the i-drive, have much less than stellar reliability. I find it quite odd that a luxury mark like Lexus can package all the latest features into a very reliable car, but the German companies (BMW, DC, VW, etc) cannot.
    I personally don't trust "ease of 3rd party integration." The first problem with CMM +5 is the huge cost - and time - involved in all that prototyping and testing, to ensure delivery of an absolutely reliable software product.
    It stands to reason that frequent "updates" have not been thoroughly tested and you will encounter field problems that quick iteration testing failed to uncover.
    If it's a car, it rolls to a stop and you call Roadside Assistance. If it's a chlorine cell, you kill a lot of innocent folks.
    It's a very sobering reminder to me of reliability issues when I check up on software packages that I wrote in the late 80's or early 90's that have run 24/7 without fail, then go back to my home and encounter "PFN_LIST_CORRUPT" on Windows XP Pro.
