Wait for Prius Prime ?
Discussion in 'Prime Main Forum (2017-2022)' started by titefd, Sep 15, 2022.
  1. Tideland Prius
    16,665
    Ohh? I thought the Prime was rated under the old JC08. They must've made the change in 2018 then?
    Toyota Launches Redesigned "Prius PHV" in Japan | Toyota | Global Newsroom | Toyota Motor Corporation Official Global Website
    Ahh, yes I was thinking of the old 15kWh criteria. Yes, in that case, it'll definitely qualify for the full rebate. I think the range is a better metric since a smaller or lighter car can use a smaller battery to achieve the same range.
    I'm going to make an even more outrageous guess. MG2's output will increase to 80kW. (Basically, it'll take the bZ4X's motor rather than the RAV4 Prime's motor). This means, it's no longer needs the one-way clutch. Current MG2 output is 53kW and with MG1 combined around 76kW?
    #21 Tideland Prius, Sep 23, 2022
    Trollbait and Sarge like this.
  2. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    This could be a new ball game , better rebate from the federal program , and probably better rebate in Québec ..knowing that GM Canada did NOT reduced the price of the Bolt as they did in the US..
    The Prius Prime next generation could be a game changer in Canada if it happens:ROFLMAO:
    Tideland Prius and Sarge like this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,327
    946
    Monument, Colorado USA
    I think that's wise. Even with Toyota, new Generations have come out with unexpected issues that took the engineers a while to iron out. Even the recent Tundra had quite a few little issues and one rather large issue of the wastegate on the turbocharger. It's best to wait until the model has been out 8-12 months before buying, IMHO. I'm, still, not sold on the turbo's in the Tundra so watching how they hold up long-term.
    Louis19 likes this.
  4. Trollbait
    12,799
    Looks like 2018 is the first year, and there was likely a phase in period; the EU's was 2017 to 2019. It also looks like Japan's WLTP is adjusted for their market of lower speeds and higher temps.
    (instead of just opening the pdf in a tab, it is getting auto downloaded on my machine. search mlit description of japan rde methodology if you want to see it)
    Looks like they cut the Extra High(speed) portion. Which means Japan WLTP will be better than Europe WLTP.
    The WLTP baseline https://dieselnet.com/standards/cycles/wltp.php
    Of course, Toyota and the rest are free to use whatever test they want for internal benchmarks, and pre-official numbers.
    A JC08 100km will likely be 71km/44miles in the EPA. While I think Toyota could easily make the next PP get over 50 miles EPA, they are going to balance that against a price point, and their battery supply levels.
    44 miles is right between the first Volt's and the gen2 one's range. Perhaps GM should have moved its production to another factory
    The clutch is a lot cheaper than a more powerful motor.
    The 88kW one from the Rav4 hybrid is more likely than the 80kW for a power boost. Besides supply levels, the one for the BEV might not be in a format that fits a hybrid transaxle.
    *cough*bZ4X*cough*wheels*cough*
    IIRC, the gen2 Rav4 was once Consumer Report's example of how far a first year model can drop in reliability from the previous gen and manufacturer average. that
    Tideland Prius likes this.
  5. Gokhan
    Gokhan Senior Member
    6,676
    2,650
    Paramount CA
    A 50-mile (80-kilometer) range would be great! However, knowing how conservative Toyota is... :confused:
  6. Tideland Prius
    16,665
    Yeah. That’s why my guess is 65km/40 miles.
    Sarge and Gokhan like this.
  7. DukeofPrime
    DukeofPrime Member
    108
    77
    US
    If you're tall, you may want to get the 2022... assuming you have a choice. The rumors also say the 2023 is lower/sleeker which, to me, means less headroom... which is disappointing as a tall person. In fact, this is what led me to the PP. It is the smallest car I fit into (6'4" with short legs for my height)... any less headroom and the PP is off my list.
    Gokhan likes this.
  8. Delta87
    Delta87 New Member
    2022 Prius Prime
    I placed my deposit June 11 and was told this week I’m at the top of the list. We will see!
    daisy555 and Gokhan like this.
  9. Gokhan
    6,676
    2,650
    Paramount CA
    Note that the Prius Prime Limited is no longer available but the LE and XLE are still being made.
    Delta87 likes this.
  10. Larss70
    Larss70 New Member
    Ontario,Canada
    2022 Prius Prime
    Upgrade
    Ordered in March 2022in Quebec Canada...dealer told me 3 months.... Called me in August saying that build time is scheduled for end of August and that Toyota Japan will let me know when vehicle will be build...fast forward October 1 and nobody knows anything:(
  11. Craig59
    Craig59 Junior Member
    Kitchener, Ontario, Canada
    2018 Prius Prime
    I ordered a 2022 Prius Prime Upgrade with Technology package on the 9th March 2022. I just checked in today with the dealer to see where I am on the list. They told me I'm number 2 out of 19 orders. At this point they can't confirm whether it will be a 2022 or 2023 model. I hoping for the 2023 model. I would think the plant in Japan would be shutting down the 2022 Prius Primes production to retool for the 2023 models.
  12. ct prius dedicated
    74
    38
    2022 Prius Prime
    Toyota has once again announced a reduction in production for Oct down to 750000. What's more they are shutting down a line that produced the prime for a week starting the 8th of October. So...being first on the list (as I supposedly am) may not even help if they don't allocate to the dealership. sigh...
    #32 ct prius dedicated, Oct 1, 2022
    Gokhan likes this.
  13. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Btw, Toyota of Stamford was selling a silver Prius Prime LE for MSRP.
    Code:
    https://www.reddit.com/r/PriusPrime/comments/xs4my1/2022_toyota_prius_le_available_brand_new/
    What they list for stock/in-transit:
    https://www.toyotaofstamford.com/new-inventory/index.htm?model=Prius%20Prime
  14. Turbolevo
    Turbolevo New Member
    lethbridge, AB
    2022 Prius Prime
    Upgrade
    Ordered a Prime upgrade on August 17, 2022. Was quoted 9-12 months. Dealer called me Early September and told me they already allocated one for me and it will be here mid-october. Picking it up in two weeks.
    daisy555, Sarge, Gokhan and 1 other person like this.
