Wait - Tesla braking isn't regenerative?
Discussion in 'Tesla' started by Lee Jay, Nov 24, 2022.
  1. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    Not quite.
    Regen will slow the car to 3-5 mph.
    The Hold setting will then blend in friction brakes to bring the car to a complete stop.
    I believe ‘roll’ doesn’t blend in the friction breaks, so to come to a complete stop you need to step on the brake.
    Tideland Prius and Trollbait like this.
  2. Trollbait
    12,831
    And the creep will apply power to keep the car moving at those speeds until the brakes are applied, like the Prius?
  3. Zythryn
    6,412
    4,415
    Yes, if you like the car to creep forward, that setting will duplicate that behavior.
  4. Tideland Prius
    16,683
    "Apply brakes when regenerative braking is limited"
    That makes sense but why is that option a toggle switch? What does it do if it's off as in the Bob's screenshot?
  5. Zythryn
    6,412
    4,415
    Under cold or fully charged conditions, regen is limited. As such, the regen strength is less than it normally is.
    If you want consistent behavior from regen, you leave that enabled.
    Tideland Prius and bwilson4web like this.
  6. bwilson4web
    16,544
    As shown, it is not something I use. When regen is limited, the brake pedal adds friction braking to whatever regen is doing.
  7. Tideland Prius
    16,683
    Right I get that. So should it just be hard programmed in? Why would it be an option. If it’s full, why would regen activate? Or does enabling this option mean the car will charge to, say 99.5% instead of 100% (even though it’ll round up to 100 on the batter meter) so give that consistent regen feeling as you said.
    For EV6, it doesn’t regen at 100% but regen kicks in fairly soon. I charged to 100 yesterday. No regen for the first stop sign on my street but regen is back on the next one (uphill).
  8. Trollbait
    12,831
    Was this when you were applying the brake?
    The toggle in the Tesla is for behavior with one pedal driving. On, and it will blend in friction brakes with the regen as the accelerator moves through the brake zone. This keeps the braking force constant regardless of SOC. It can be compared to how a Prius Prime in B will bring in engine braking when the battery charge is high.
    Why be able to disable it? Tesla does sell these as performance cars. Some drivers interested in that want more manual control over of the car's functions. It's why VSC can be disabled in many models.
    Tideland Prius and Zythryn like this.
  9. bwilson4web
    16,544
    My understanding is it may be useful to knock or wipe off rusty brake disks.
  10. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Why would that be required? Logically, if the brakes are not being engaged then it makes no difference whether the disks have some surface rust on them or not. They will get "wiped" the next time you hit the brakes hard, right?
  11. fuzzy1
    10,714
    That hasn't worked very cleanly on my Subarus, past and present, even without any ability for regeneration. Both have experienced serious pitting, from the combination of not being a year-round daily driver, and the region's modern love of winter salt.
    bwilson4web likes this.
