Waiting on my '13 Wagon to get here
Discussion in 'Prius v Main Forum' started by tbearprius, Mar 9, 2022.
  1. tbearprius
    tbearprius Junior Member
    30
    Atlanta
    2013 Prius v wagon
    Not many shops near me, out in the country.
  2. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Just the beginning of BIG $$$ Problems..............
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    White smoke means the engine is gone. You need a rebuild to have any hope of reliability. A rebuild of a decent used engine. Shop around, many have had it done for $3,500-$5,000 and a rebuild is worth it.
    These engines from 2010-14 had bad rings - requiring new pistons and rings to correct. Too many have put a head gasket on a severe fail like yours at the white smoke stage and end up doing it again. Some have even moved to a rebuild after one or two head gaskets. Its not a beginner diy job and several have had issues with oil leaks and bad timing after the hg repair.
    It is very possible the head is warped and should be professionally rebuilt even on a head gasket job. Bent rods and holes in the block can and do happen.
    While the car is a hybrid, the engine is a normal gas powerplant. Any shop who can do a Corolla or Camry can do this job. Some are simply scared of the high voltage and the inverter. I would visit a few recommended shops in person. Don't be afraid to trailer the car somewhere if necessary.
    Otherwise, a used engine that is successful might work if you wish to immediately flip the car. The car does have two hybrid expenses in your future - the hybrid battery and the brake booster. Both around $2,500 each.
    #23 rjparker, Mar 21, 2022
  4. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    You guys aren't very encouraging.
  5. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Sorry..... but you probably shouldn't have bought it...... motor, traction battery, water pump, master cylinder and accumulator
  6. PriusHead05
    PriusHead05 Member
    318
    Mine is a 2012 Prius II (regular Prius) with 201k mi. on it and counting. I love mine. Runs and drives like new. It was mostly highway miles, though. It does make a difference on how well the previous owner(s) took care of the car.
  7. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Ya until the head gasket goes.... mine was perfect till 215,000 then it started to go to hell.....
    Head gasket..... brakes........traction battery.. two water pumps....blown inverter...... it will happen sooner than you think...
    driving along getting good mpg then......broke down and you don't go to Autozone for parts....
  8. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    We shall see. I have water pump and other maintenance parts in garage when it gets back. Only paid $4.5k so still above water. Brake booster looks fairly okay to do if I can get a scanner. (new toys).
  9. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    You'll have to do the diagnostics
    vvillovv likes this.
  10. rjparker
    11,116
    6,974
    Texas Hill Country
    Replacing the motor with a better rebuilt version is the safest and more reliable answer.
    Tim Jones, douglasjre and PriusHead05 like this.
  11. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Brake booster and accumulator is 12 to 1300.......Never put a used one on..... I did and it went out.
    Luckily it failed with the rite codes and got a free one. But that program was over last year.
    tbearprius likes this.
  12. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    You can get toyota techstream on amazon or ebay. just google it.......bootleg copy but way better and the one you really need for the prius.
    No scanner can compare and its super cheap..... and you need the plug and cord but usually comes with it.
    MAKE SURE you get it............anything else just a waste of time and $$$$$
    Plugs into usb port on laptop and it works on mine running windows 10.
    I know what I'm talking about because I have changed every major part on mine.
    #32 Tim Jones, Mar 22, 2022
    PriusHead05 and douglasjre like this.
  13. PriusHead05
    PriusHead05 Member
    318
    Like Tim Jones has said. Experience is key. It is not fun when you have a $2500 brake job bill sitting in front of you when you don't expect it. Luckily it was covered under Toyota's extended warranty for the ABS accumulator/pump. The extended warranty they sent out expired in December, though. I was wondering, how hard it would be to put a Gen 4 1.8L in a Gen 3? I know you would probably have to switch some sensors on the motors, but is it so much different that you would have to switch the ECU out?
  14. rjparker
    11,116
    6,974
    Texas Hill Country
    Actually the brake booster customer support program is still good on a less than ten year old less the 150,000 mile car. Several have installed a gen4 engine frankenstein in a gen3 using gen3 intakes, egr and slightly modified harness.
    tbearprius and PriusHead05 like this.
  15. PriusHead05
    PriusHead05 Member
    318
    So it sounds like instead of doing a head gasket, its better and easy to just rebuild the motor so the other problems are eliminated?
    Tim Jones and douglasjre like this.
  16. rjparker
    11,116
    6,974
    Texas Hill Country
    A rebuilt gen3 engine with new rings and 5k oil changes will likely get you 150k or more reliable miles. With a gen4 swap using the gen3 egr and intake seems to negate some gen4 advantages. Time will tell if the gen4 swap under these conditions is dramatically better. Maybe a short block rebuild on the gen4 could be skipped. Maybe there would be less carbon build up with the gen4s improved cylinder cooling strategies and rings. Maybe just disabling the egr as a few have done is an option although that gets a code. 2C8B617C-60BE-4E81-BD12-383BCAA1D7FD.jpeg
    Tim Jones and vvillovv like this.
  17. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I have a better idea.....GET RID OF IT..................................
  18. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    I didn't think the brake booster program covered the Prius V?
  19. bisco
    52,861
    you can check at toyota.com/owners
  20. rjparker
    11,116
    6,974
    Texas Hill Country
    It covers the Prius v
    Tim Jones likes this.
