Waiting on my '13 Wagon to get here
Discussion in 'Prius v Main Forum' started by tbearprius, Mar 9, 2022.
  1. tbearprius
    tbearprius Junior Member
    30
    Atlanta
    2013 Prius v wagon
    Hmm, didn't see it when I logged into Toyota owners. Hopefully won't need it.
    Another note, dealer called and said head wasn't warped and rest of engine looked good. Still, may just sell it and get out of it once the gasket is repaired. Sad because interior/exterior part of the car are immaculate. You would never know it had 139k miles on it.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,133
    6,983
    Texas Hill Country
    The brake booster program is not a recall. A recall is a safety related issue that is performed regardless if it is broken or not. The brake booster program is a customer support program that is mailed to registered owners.
    This kind of program is voluntary on the part of Toyota and is dependent on certain conditions, usually the system has failed, specific codes are present, not cleared and any mileage or time limits have not expired.
    Salvage title cars are excluded as are cars where someone installed a used brake booster which has failed or was the wrong part. Lots of folks get a customer support program confused with a government mandated recall.
    To make customer support programs more difficult, some dealers would rather not do them at the reduced profit Toyota pays them. In the end many v owners have received free brake booster systems installed by the dealer past the standard warranty periods. Often because the customer mentioned the Prius v customer support program #20TE07. If you keep this car you have until 150k miles for this repair. After that it is $2500 - $3500 depending on the dealer.
    #42 rjparker, Mar 28, 2022
    Tim Jones likes this.
  3. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Many thanks, saved for later. Yes, have had several service campaigns/extended warranties on Subaru's that we've owned, mainly the CVT.
  4. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Does it burn any oil?
    I thought you could take it back..... I guess your going to learn the hard way. Hybrid battery could go out tomorrow....
  5. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    No, auction car. Stuck with it. Will run Dr. Prius app on it when I get it back.
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Sorry got this mixed up with a different post.
    tbearprius likes this.
  7. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Oh yeah, read that one. I'll put this one under "live and learn".
  8. bisco
    52,891
    with the price of cars these days, a new head gasket, or even rebuilt engine still puts you way ahead of the game, imo.
  9. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Unless you need a traction battery and master cylinder with accumulator.................
  10. bisco
    52,891
    that would be the trifecta! :)
  11. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    But this isn't a horse race............
  12. rjparker
    11,133
    6,983
    Texas Hill Country
    A trifecta is a winning bet. With a gen3 you have to sell short. A decent hedge is to buy under market.
  13. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Sigh, got car back and it ran great. Dealer said they drove 40 -45 miles with no issues. Car had check engine light come on during drive home which makes me think they did something to wiring harness. Codes for low coolant temp, MAF sensor (new), throttle position sensor, c1259/1310, etc. Now have to take it back where I'm sure they will say they did nothing to it and want to charge me to diagnose.
  14. rjparker
    11,133
    6,983
    Texas Hill Country
    They had to tear everything off the engine to do a head gasket so its possible something was not replaced 100%. Some codes take a period of time after a power disconnect.
    What exactly did they do? Did they rebuild the head? Or just the head gasket?
  15. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Just the gasket, said the head was fine. One of the codes was for intermittent signal from throttle position sensor so I took the intake off, found a ground wire hanging loose on the left side of engine. It looked like it connected to the top of the valve cover so I found a bolt and attached there. Hopefully that was some of it
  16. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    And you were right about battery, looks like it needs one. Has the p080a code, Dr. Prius app says at 25%. Will need to look at cost effective options.
  17. rjparker
    11,133
    6,983
    Texas Hill Country
    Concerning the hv battery, I would drive the car a few hundred miles first to see if a series of charge discharge cycles helps. I am sure the car was sitting for several months.
    Your battery replacement options are simple; used or new. Most battery replacements from $500 to $1600 are used batteries with one or more bad cells swapped with a better used cell. It might work six to twelve months before you have to test the warranty. That kind of battery is worth maybe $600 if a local independent shop does the work. Local meaning easy to get to for repeated warranty work. By the way, Dorman from your local autosupply are used cells.
    New cells from Toyota are around $1600 if you shop and put them in. Toyota new cells were recently on sale from a dealer in Florida for about $1350. The careful reader may realize new cells can sometimes be obtained for less than used cells. Don't be the guy who overpays for used cells.
    New aftermarket cells from third parties "newpriusbatteries.com" or lithium from "projectlithium.com" are available as well. They are not exactly the same shape or fit but will work. I would get the lithium even though they are a single supplier barely out of beta testing. More power and mpg have been reported. New cells will last eight to ten years, used cells eight to ten months.
    With that said, I would wait until the engine is solid before going down that road.
    #57 rjparker, Apr 4, 2022
  18. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Thanks for the information, I appreciate it.
  19. Mendel Leisk
    42,369
    Or clean it, say at engine coolant change intervals: 100K miles or 10 years, and 50K miles or 5 years thereafter.
  20. tbearprius
    30
    Atlanta
    2013 Prius v wagon
    Mendel, I saw a TSB where Toyota changed the intake manifold design and did some reprogramming. Do you think that is worth doing (on my own)?
