Walked in on my Prime buzzing in the middle of the night
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Dmitriy Sokol, Feb 8, 2017.
  1. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    I walked into my garage to check on something and heard a loud buzzing sound that got me worried. Started to look around and realized that it was coming from the rear of my Prime, under the battery pack. The sound cannot be heard from the inside of the cab. Just on the outside and the tone changed every few minutes. Then it stopped after about 10 minutes, as I was trying to figure out Wth was going on. Any ideas? Did anyone else had that happen? This could be normal and some sort of a battery pack maintenance, but seems weird. Anyone?
  2. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    This happened to my gen 3 twice in the last month or so. I hit the power button twice (on position) without the brake and it stopped. I then turned the car off and it didn't come back. Same thing, sounded like it came from the area of the battery or the battery fan and it was louder on the outside than the inside. Not sure what it was either.
    Dmitriy Sokol likes this.
  3. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I don't know whether this would have any bearing on the question, but it might: Was it charging at the time?
    priuscatprimeguy likes this.
  4. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Charging finished hours before. When charging, the internal cooling fan is running and it's a different sound entirely that's clearly heard on the inside. This one was coming from the exterior, right under the car's traction battery.
  5. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    Most likely the evap system test. Which is a noise from around the fuel tank. Happens after the car sits for a few hours.
  6. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Maybe the car did not like being walked in on.
    timespaceone and vvillovv like this.
  7. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    this happened on both the old Pip, and a couple of times on the Prime.
    I cannot figure out any rhyme or reason for it, but cycling the power switch turns off the noise.
    It is not an evap systems test noise, because the steady buzzing will go on for a long time. I timed 5 minutes once and decided to power cycle and go upstairs.
  8. EspressoFueled
    EspressoFueled Junior Member
    23
    53
    Napa, CA
    Still sounds like a high probability of being the fuel evap test to me.
    Per page 8 of the manual: "Approximately five hours after the hybrid system is turned off, you may hear sound coming from under the vehicle for several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction."
    #8 EspressoFueled, Feb 9, 2017
  9. crewdog
    492
    388
    Woodstock, GA
    I stand corrected.
    Here's a vid someone posted with the evaporation test sound from a Prius C:
    bowang, Dmitriy Sokol and Kramah313 like this.
  10. Kramah313
    411
    326
    Dallas, TX
    Yep that's it. That's the sound I heard. Maybe I shouldn't have stopped it then.
  11. huskers
    2,544
    2,487
    Nebraska
    Now that I think about it, my 2011 Prius does that as well.
  12. DavidA
    2,344
    1,820
    Chicago western burbs
    ^ Vid... I have never ever heard anything like that from my 2010. That sounds really loud and annoying.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I have come to realize that we all are driving a computer that is never completely "off". It constantly checks itself, making sure that all systems are "go". The car is simply amazing, whether other (non hybrid-owners) want to admit or not.
  14. Kramah313
    411
    326
    Dallas, TX
    This would be a good one for Coast Cruiser's Prius oddities.
  15. huskers
    2,544
    2,487
    Nebraska
    You really don't notice it unless things are really quiet.
  16. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Great find. I am too lazy to read the manual :(
  17. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Sounds about right. Glad to see that it's normal. Got me worried for a while.
  18. EspressoFueled
    23
    53
    Napa, CA
    I'm shocked, only 788 pages and you couldn't find the time? I wouldn't feel guilty about that!
    Seriously, this is getting out of control. They have what now, TWO quick reference guides included in the manuals pack? I definitely appreciate Toyota going to the trouble to document everything and I do hope they continue that level of detail going forward, however the level of complexity that cars are getting to strikes me as perilously close to beyond human scale at the driver level. The level of trust implicitly requested of end users of modern cars is growing by leaps and bounds...
  19. Tideland Prius
    16,536
    That's new. I'm used to the brake accumulator buzz but that only lasts several seconds. (Both Gen 2 and 3).
  20. huskers
    2,544
    2,487
    Nebraska
    Yeah, I just want it to get me from point "A" to point "B" without needing a PHD.
    vvillovv likes this.
