Walmart then triangle RED light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shash_bro, Feb 3, 2014.
  1. jefe
    jefe Member
    169
    50
    Cary, NC
    I just don't understand why you are trying to trash the Scanguage, that's all.
  2. Shash_bro
    Shash_bro New Member
    23
    I hope it doesn't cost more than $500 .. I just can't afford ..
    I saved for 7 months to buy a prius full cash.. and 3 months later this happens.. fekked I guess
  3. JC91006
    16,936
    8,647
    I have a theory but it doesn't really pan out correctly.....this is with the 19 year old mechanic in mind.
    Instead of draining the engine oil on the car, the mechanic drained the transaxle fluid.........but if he did that, adding 3.5 quarts of oil to your engine would overfill the car completely.....however if your car burned oil at 200k miles (which many do), it could easily have been 2 quarts or more low. So it may not have shown that it's overfilled by 3.5 quarts after filling.....that would explain the transmission not driving in D
    crazy I know......
  4. YOLOsoBuyaPrius
    YOLOsoBuyaPrius Junior Member
    77
    Nebraska
    I think with a 20 year old this would be possible, this is probably a very likely situation considering that they had to check to make sure that they could do an oil change for a prius
  5. Shash_bro
    23
    Just say that was the case - Is there a way I can sue Walmart to get money back? I am not good with policies and laws etc .. Just want to be ready. Thanks much
    Prius_Cub likes this.
  6. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    From friends/family experience with damage caused by the oil change service itself at Walmart or damage as a result of handling the vehicle, they'll pay for repairs and costs of loaner vehicles.
    If it was their fault, demand they reimburse you for your costs and that they pay for the repair.
    Sorry you're going through this. :-(
    HTC Evo 3D
  7. JC91006
    16,936
    8,647
    to continue with my theory, you did drive your car home so the following has to happen.
    When you were first done with the oil change, your car didn't drive. Brought it back into the bay and realized they drained the wrong fluid. They fix it by correcting the oil level, then adding Dextron transmission fluid to your car (they don't stock WS) to fill the transaxle. This would enable you to drive home but would quickly destroy that transmission and not allow it to engage into D.
    ok, that should cover it.
  8. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I suppose anything is possible, but personally I find that very unlikely. They would have to be exceptionally clueless to confusing the transaxle with the engine sump.
    More likely is just a simple overfill, as in drain the engine oil and replace it with too much. We've seen loads of cases like this report here on these forums. I'm not sure if it's something to do with the Atkinson cycle or not, but you don't seem to need much of an overfill on the prius engine to cause oil/fouling of the throttle body.
  9. JC91006
    16,936
    8,647
    Yes you are correct, but I couldn't understand how he's not able to drive in "D". Mine was just a crazy thought during my spare time.
  10. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Well as I said anything is possible, but I wouldn't want to unnecessarily panic the OP that they might also have thrashed his transaxle too.
    Remember that the drain plug for the ATF is a recessed hex (allen) key, so it can't be removed with a normal socket or wrench. For 100% certain the guy would be under there with a normal socket or impact and would have to go out of his way to search up the right tool to even access the transaxle drain.
    Anyway, hopefully the OP will update us with the outcome soon.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Focus on one thing at a time. And the first thing is finding out what is wrong with your vehicle.
  12. Shash_bro
    23
    The Sergio guy at Toyota dealership says " the best tech in hybrids has been working on diagnosing your car for 2 full days and he got more than a page of just diagnostics codes. We will need to run more diagnostics on the hybrid side which will cost additional $160. One code was with computer software .. we flashed it and still getting more than a page of errors. The HV battery is at 8 volts but needs to be at 15v .. everything is messed up on your car and needs one more day of diagnosing"
    ME: I told him "online experts say it could be an oil overfill from Walmart" (I had told him the whole story 2days ago)
    Sergio guy: "trust me the tech working on your car is the best in hybrids and he's a lot better than all those online guys and it's not oil overspill"
    I was mad cause I can see he's just BS ing. But asked him to go ahead with further diagnostics cause I don't have choice nor time. I have asked him to send me the page of diagnostic errors ... he's like I'll try ..
    I left a voicemail again asking him to send me all the codes.
    Pls advice. Thx much
  13. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    I agree he's full of BS. The 12 volt battery fully charged would only be at 13 volts, 15 volts would be a real problem, and the HV battery should be at 201.5 volts at leased. You have a right to all of the codes after all your paying for them.
    John (Britpris)
  14. uart
    uart Senior Member
    4,220
    1,212
    Australia
    It may have started with the oil overfilled and subsequent fouling of the throttle body causing the engine not to produce power, but after you continued driving it until it could go no more you might have caused problems with the hybrid battery. Also the 12V battery may have been weak to begin with and what with all the start attempts and hazards light is possibly toast too. This may be causing them problems with the diagnosis.
    Too late now, but it would have been SO helpful in diagnosing this if you had payed attention to when the engine was or wasn't running and the SOC of of the HV battery (8 bar graph) during the time it was struggling. Also would have been helpful if you had have checked the oil level and condition yourself after a problem was first noticed, instead of just handing back to the clown who probably screwed it in the first place.
  15. Shash_bro
    23
    "Britprius"
    He was talking about HV battery 100% .. I paid attention to every word he said and typed my post immediately after and that's why I used quotes. I don't know what to do when people are so dishonest. They think it's cool .. just like smooth talking to a girl full of BS and they just get used to it... I hate this!
  16. uart
    uart Senior Member
    4,220
    1,212
    Australia
    In that case he was referring to one of the NiMH module pairs, typically about 15 to 16 volts. If a module pair is at 8 volts then you'll be up for a new traction battery I'm afraid.
  17. Shash_bro
    23
    I think I will just leave the car with them.... I will buy a $1000 Accent with borrowed money from a friend for now. No More hybrids for a poor guy. Thx
  18. JC91006
    16,936
    8,647
    Where are you located? How much did you pay for the car? I don't think leaving it with the dealer is wise. But a car with 200k miles, especially a Prius, can have some high repair bills.
    There may be more options for you. Just don't give it to the dealer!!
  19. Shash_bro
    23
    I am in Bay Are, California. Bought this car for $6300 5Dec2013 .. it has 202000 miles on it now.
    What other options I may have?
  20. JC91006
    16,936
    8,647
    I believe Luscious Garage is in the Bay Area and they are the real experts in hybrid repair. They also will have more options for you in terms of what you can do.
    How much do you owe the dealer at this moment? Before you go forward with the additional diagnostics for $160, you can ask for the codes they already pulled. That should point you to the right direction of the problem.
