Want to buy a Reliable Code Reader under $50
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stoner, Dec 20, 2018.
  1. Stoner
    Stoner Junior Member
    45
    Naples, Florida
    Hello,
    Brand new to this forum and retired in 2017 after driving my 2008 Prius to work in Miami 250 miles round trip twice per week for the last 9 years. I then let my daughter drive the car and she put about 20K miles on it so the odometer now reads 168K miles.
    I love the Prius, but beyond regular oil changes every 5K miles and having the belt changed, I've neglected it because I thought I would just sell it after retirement. But now, I have changed my tune and would like to keep the ol' girl. She gets great mileage and is cheaper to operate than my Silverado 2500 HD! After reading several posts and being somewhat mechanically inclined, I would like to tackle many if not all of the maintenance issues I have been neglecting and bring her back up to speed again.
    This week, the "check engine" light came on and two codes were read on Advance Auto's code reader. I was impressed at how easily these codes were read and told if I'm going to work on the Prius myself then I better buy a good code reader.
    Can you please offer a suggestion on a good quality reader for under $50 dollars? Seems to me one that plugs in under the dash would be easier for me to operate without having to worry about wi-fi and/or bluetooth. Do I have to monitor temps and pressures or are those just fancy add-ons? FYI I have an iPhone 5S.
    Suggestions??
    Thanks,
    Stoner
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Welcome!
    Techstream is the gold standard. It's what Toyota mechanics use. It runs on Windows. Sadly, a fully legitimate copy cost's as much as a used car. But there are lots of Mini vci adapters that come with an older version of the software available for under $50 on Amazon and probably Ebay. It's easiest to install the drivers on a 32-bit Windows laptop, but I've read of people managing it on the 64-bit versions. I have it on a Linux laptop that's running Windows XP in Virtualbox. I keep the wifi turned off so that the ancient Windows XP won't get infected and the Techstream software can't go trying to authenticate and update itself.
    Since you have an iPhone, the simple answer would be a wifi OBDII adapter and EngineLink, which is available on the App Store. It's not nearly as versatile, but it's a handy way to see and reset codes as well as monitor sensors. But you will need to install the Prius DTC codes. There's a thread here somewhere about how to get the codes for Toque Pro, which also work with Engine Link.
    Skibob and Raytheeagle like this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    For $25 buy a cheap Android device that can access wifi ( wifi needed only to download the app)
    For $6 buy torque pro app
    For $18 buy an ELM 327 OBDII Bluetooth adaptor
    Not sure why your budget is so low. This will save you hundreds of dollars.
    Back in the day these tools cost well over $500 if not $1000. I remember when $200 was a bargain price for a reader.
    If you have $120 more you could also by a pirated version of Techstream, minivci, and a cheap Windows XP laptop. This is the most versatile, but more time consuming and awkward to set up.
    TL Biles and jerrymildred like this.
  4. Stoner
    45
    Naples, Florida
    Thanks for the reply Jerry....don't have any Windows pc's available. Like you mentioned, will look for iPhone capable but still would like a corded version. I'm finding many don't work with Hybrids unfortunately. Currently looking at a JDiag OBD2 READER on Amazon for $30.
  5. jerrymildred
    11,517
    14,158
    Tampa, FL
    The wifi is dead simple. Just plug the device into the OBDII port and it will make its own network. In the phone, go to "Settings," tap "Wi-Fi," and select the network it created. It should have an obvious name, but the manual will tell you the name in case there's any doubt. When you unplug the adapter from the car, the phone will reacquire your previous network if it's in range.
  6. ericbecky
    4,443
    3,351
    Madison, Wisconsin
    Do not bother buying any 1 trick pony code readers.
    I suggest getting an adapter that does not directly read codes.
    Instead just get one that collects and transmits the data. (Search elm 327 Bluetooth obdii). There are some as low as $10.
    Then use an app, like the $6 Torque Pro app paired with a cheap ($25?) Android phone or tablet.
    The whole setup is well within your $50 budget.
    jerrymildred likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,835
    Clearwater, Florida
    I like my VXDIAG with TECHSTREAM off amazon.com works very well full techstream one piece unit. The little box plugs into the obd connector the other end is a usb that plugs into a laptop. Has same software as the dealer uses. $77.
    I also have a scan gauge X gauge. Thats a really handy box its a universal code reader but no techstream. I keep that in my car everyone at works knows I have it and I help alot of people who have codes pop up on there car.
    Skibob and jerrymildred like this.
  8. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Plus I don’t think an old laptop with a single core running windows 7 would cost that much. Biggest problem would be finding one with a battery good enough to run 1/2 hour or so.
  9. Patrick Wong
    18,210
    6,514
    Or spend $25 on a new laptop battery?
    johnjohnchu, Skibob and Raytheeagle like this.
  10. edthefox5
    10,096
    4,835
    Clearwater, Florida
    There's literally hundreds on my local craigslist. A few Dell D630's even. Most really cheap some $25.
    Skibob likes this.
  11. Skibob
    2,912
    1,505
    Northern California
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,972
    New England
    Could never get knockoff version of techstream to run on my old netbook, but OBDLink® LX Bluetooth | OBDLink® | OBD Solutions paired with Android phone and apps (have Native OBDLink app, Torque Pro, Hybrid Assistance, and other free apps) are serving very well.
  13. Skibob
    2,912
    1,505
    Northern California
    Salamander_King likes this.
  14. Salamander_King
    11,024
    8,972
    New England
    My miniVCI is 2 years old, and not sure if it's compatible with the newer version of Techstream. When I tried on my old netbook running Win7 32bit, the driver just would not recognize the miniVCI. Tried few different versions of drivers and software, but no avail. I gave up on it a long time ago. If I have time and inclination, I will give a try again. Thanks for the info, though.
    Skibob likes this.
  15. Skibob
    2,912
    1,505
    Northern California
    Did yours come with a disk? The driver is usually on the disk also. I’m pretty sure those instructions work on older versions. I guess your VCI could be bad also.
  16. Salamander_King
    11,024
    8,972
    New England
    Yeah, the disk was busted en rout long way from CHINA!
  17. Skibob
    2,912
    1,505
    Northern California
    Thats the problem then.
