Want to install an Engine Block Heater yourself? This guide may help.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Green Hokie, Jul 15, 2007.
  1. CIA_Guy
    CIA_Guy Junior Member
    Okay...dumb question here....other than waiting for the next group buy, where can I buy a block heater for my Prius? I searched the forum, but didn't see a link to a website.
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    <div class='quotetop'>QUOTE(CIA_Guy @ Sep 12 2007, 09:23 PM) [snapback]511689[/snapback]</div>
    Besides the PriusChat shop go to www.metrotpn.com.
    Wayne
  3. FireEngineer
    1,247
    124
    Wayne
  4. JoeyJoeJoShabadoo Jr
    48
    New Jersey
    First time posting on the forums. i've been lurking around for a few weeks so sorry if this is a repeat question. But does installing the EBH yourself void any of the warranty?
    Also, what about the EV switch, i read that one thread that the dealship said it would void the warranty. Is there a definite answer to whether it does or not?
  5. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(JoeyJoeJoShabadoo @ Sep 15 2007, 06:33 PM) [snapback]513147[/snapback]</div>
    EBH cannot void your warranty, it is a Toyota part placed into a sleeve in the engine block meant only for the EBH and none of the wiring integrates with the Prius systems, totally separate.
    As for the EV switch.....your on your own.
    Wayne
  6. Silver Surfer
    Silver Surfer Junior Member
    38
    Asheville
    I see that everyone uses a timer to have the EBH start about 3 hours before using the vehicle.
    My question is: Can the EBH remain plugged in all the time without overheating the engine area, or causing the EBH itself to burn out?
    Some of us are "retired" and do not have to worry about having a timer to get the car ready for a work commute. I would just like to be able to leave it plugged in until I plan on driving as long as this will not create a problem.
  7. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(Silver Surfer @ Sep 16 2007, 06:33 PM) [snapback]513424[/snapback]</div>
    Sure, go ahead. Longest I've left it plugged in was 6 days. When started the ICE temp was just a little higher, a few degrees, than a 3 hour preheat. The ICE and transaxle are a great heat sink, pretty much impossible to overheat with a 400 watt element.
    Wayne
  8. n8kwx
    n8kwx Member
    236
    Arlington Heights, IL - NW Chicago Suburb
    The heater draws 400 watts. If you leave it plugged in all the time, that quickly adds up to 9.6 kWh a day. That's almost a buck a day for most people (10 cents a kWh).
    You would probably spend more on pre-heating the engine than you'd save in gas at that rate. (especially if you are retired and don't drive much).
    You might consider buying a timer and setting it to shut off the heater overnight, and other times that you know you'd likely not be driving.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(bruceha_2000 @ Sep 9 2007, 02:00 PM) [snapback]509629[/snapback]</div>
    No answers here and I didn't find anything useful with Google. I've decided that it should be safe enough if I just push the connected plugs into the grill which holds them tightly, just as I do to 'store' the plug while I drive. I also push the cap into the grill so it doesn't get full of rain overnight :)
  10. Bob64
    1,540
    93
    Virginia
    <div class='quotetop'>QUOTE(n8kwx @ Sep 16 2007, 10:18 PM) [snapback]513480[/snapback]</div>
    Anyone have an estimate as to how much the EBH can save in gas as opposed to without?
  11. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(Bob64 @ Sep 27 2007, 08:55 PM) [snapback]518785[/snapback]</div>
    See the original engine block heater thread, calculations were done there.
    Wayne
  12. cheule
    cheule New Member
    39
    Green Hokie, thanks so much for your guide! I used it today to install my EBH that I got from Acornblue. The install was quite tricky, and without your guide I don't think I could have done it.
    In fact a lot of the additional comments in this thread helped also, like wearing fingerless gloves to prevent getting your skin scratched and connecting/disconnecting the cable about a dozen times so that when you finally connect it blindly it goes in easily.
    Thanks PriusChat!
  13. Green Hokie
    Green Hokie Member
    189
    Glen Allen, VA
    <div class='quotetop'>QUOTE(Sean Blumenthal @ Oct 1 2007, 12:41 AM) [snapback]519700[/snapback]</div>
    You're welcome, Sean! Glad it helped make your install a little easier. I use my block heater every morning, even in the summer. Electricity is extremely cheap in my area!
    Pete
  14. CIA_Guy
    Does anybody still have them in stock? I notice they aren't in the Priuschat shop any longer and Metropn says they are back ordered.
  15. Bob64
    1,540
    93
    Virginia
    Doubt it, I think the priuschat and chicago area group buys have cleaned out the stock of EBH for the moment... You might wanna check some other stores... also, check with the latest part number, as I heard the part number has also changed.
  16. sdp40f500
    sdp40f500 New Member
    27
    Milwaukee, WI
    As a complete newbie (still waiting for delivery of the '08 Prius), this might be a good time for me to ask: Is there anything in the Toyota warranty that prohibits or gets nullified if a block heater gets installed? Would this be something I'd want to remove before taking it to the dealer for service?
    Thanks!
    Jim
  17. FireEngineer
    1,247
    124
    <div class='quotetop'>QUOTE(Casey Jones @ Oct 3 2007, 11:40 AM) [snapback]520684[/snapback]</div>
    No and No. Come to the Milwaukee Hybrid Group engine block heater install party on Oct. 13th and get all the info first hand.
    Wayne
  18. Skinflint
    Skinflint New Member
    Thank you Green Hokie for the pics and instructions and Wayne for the extra tips but, I do have two cents worth to offer. I have had my EBH for a while but, waited til our first oil change to consolidate my under car tasks. My son and I installed yesterday.
    Self Installers Beware! There is a pseudo-hole that at least one other member tried installing the EBH into and had pictures showing that the EBH would not seat completely nor clip into. Don't be fooled as I was. I did the same.
    The pseudo-hole is lower than the real hole, it's in the same general area as the pictures and the opening faces toward the passenger's side of the vehicle. The real hole is higher up and the opening faces toward the driver's side of the vehicle. If you are lying on your back, between the ramps, with your feet out the front of the car. . . Wrong: Inserting right to left. Correct: Inserting left to right.
    Green Hokie's sixth picture shows the correct EBH chamber body just at the tip of the red arrow. You can not see the hole opening in the picture, just the chamber. Knowing "where" is part of knowing "how". I hope this helps others avoid my mistake. :)
  19. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Just be sure you know what the main parts are from the underside of the car. The engine block heater goes into the engine...that incorrect hole is 1)too large of diameter, 2) doesn't go into the ICE...it goes into the inverter box. Study the pictures carefully and be sure you understand what you're looking at.
  20. hill
    9,041
    <div class='quotetop'>QUOTE(FireEngineer @ Jul 16 2007, 10:52 AM) [snapback]479579[/snapback]</div>
    Your kidding right? Inside joke I missed? Set 'em as light/dark as you want. The cheezy stock picture manager program that comes w/ your O.S. will do it for you (ie, do it yourself) after you download them.
