Want to modify steering to decrease turning radius. Can it be done?
Discussion in 'Prius c Accessories and Modifications' started by john1113, Jun 18, 2013.
  1. john1113
    john1113 New Member
    Hey guys. Just bought my Prius C a couple weeks ago. Love it. Except for one thing. I test drove the 1, but bought the 4. The larger turning radius on the 4 is such a pain. I have to do 3 to 4 point turns everywhere. I didn't realize this and there's no law in Canada for having buyer's regret. So Toyota increased the turning radius because of the wider 16" tires. And to fit the 16" tires that were built for 15, without the tires rubbing against the wheel well, they somehow limited the amount the tires can be turned. At least compared to the Prius C 1, 2 and 3.
    If I got the 15 inch tires, is it possible to get a mechanic to modify the steering to that of the Prius 1, 2 and 3? Or is it a huge deal, and probably can't be done without replacing the whole.
    Hope there is someone out there who can help me. Thanks!
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Not all 4s came with the 16s, first off. 2nd off... you can modify it to have the better steering radius, but you are looking at at least $1000 in modifications.
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    hey, you should straight trade for my C2. it has the turn radius you want lol jk
    Danny13pruisc3 likes this.
  4. mahout
    mahout Active Member
    655
    116
    NC
    First, let me point out as an automotive engineer, you are cioncerned about too little a problem.
    Any dfference between the steering ratios are likely the pinion gear to steering rack so yes, you can likely change the rack and pinion to get what you want but there's no real reason to do so. If indeed there is a significant difference in turning radius its ikely the rsult of the rack length and the diameter oif the pinuiongear limitig the trave (therefore you g less travel of the rack back and forth so the wheels won't turn as far.
    Having installed severa wider wheels and tires on Prius 1 thru 4s I can verify there is no problem fitting even 7" wide rims and 205 section tires so changing wheels/tires are not your solution.
    I am curious as to why youbelieve you need to change the steeing ratio,turning radius. I have a sneakin suspicion that going for the slower steeing ratio will not prvent your having to o 3 point turns and why do you have to do so many?
    PS in all likehood, the least expensive change is literally sell your Prius C4 and get a C2 or 3 with the 15" wheels with the 'tighter' steering ratio but check it out first in a test drive that includes a U turn that your C4 has to do a 3 point turnaround to verify theC2 won't need a 3 point. When I tried it here in the shop lot I couldn't tell the real difference..
  5. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    again... as I mentioned above... the C4 with the 15" wheels don't have the higher turning radius. They are the same as the 1/2/3
  6. mahout
    655
    116
    NC
    We got to bench racing the peculiar Prius C change in track and increase in turning circle when equipped with 195/50x16 tires. Its strange that the tire size should decrease in diameter, widen by an inch and the track decrease by 0.8 inch front and 1 inch rear while increasing the turn radius by spec 6 feet. It makes no sense to mount better size wheels/tires and reduce the track. We can understand increasing the offset and increase rim width to accommodate wider tires but reducing the track (distance between centerlines of front tires by .8 inch, or 20.3 mm and the rears by 1 inch, or 25.4 mm.. That’s a change of 10 mm on each front wheel and 12.5 mm on each rear wheel. Nonsense. Probably the suspension is changed to shorten track and possibly because of the change in the steering rack ratio. Next time we get the C4 in here we’ll do some measurements.
    Our conclusion is you’ll be better off selling your C4 and get a C2 and add the accessories of choice if you want that lesser turning circle. These changes to go from C4 to C2 or C3 are major in scope and not readily addressed especially by garages. Its not that it can't be done, two of us are grad engineers who did this kind of projects in our careers but its not simple..
    Further, we got to investigate the Yaris and we think the difference in turning radius could be the use of the Yaris closer ratio rack and pinion in a limited space. With the pinion being larger and the space for the rack being the same, that naturally means the travel of the pinion is less and thus there is less turning the wheel. Ergo, the turning radius is greater. I suspect if yu replaced the steering rack and pinion gear that would slolve your problem. Meassure the turns fully left to fully right and reverse and advise your answer. IOf its less than 3 and an eigth turns lock to olock you've probably nailed it. While you're at it measure the amount of the change in angle of the front wheels lock to lock.If its just the rack that needs to be changed figure $1000 for that including labor but get a quote first. And we still say trading is better. cheers.
  7. john1113
    john1113 New Member
    Thanks a lot for the thoughts and answers!
  8. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    *le sigh* ... why not just get a c4 without the 16" wheels like I keep mentioning... The C4 that comes with the 15" standard don't get the rack change... I know this... because mine has the 15" wheels standard...
    Fasyle likes this.
  9. B2FiNiTY
    979
    227
    *le sigh*
    Fasyle and ztanos like this.
  10. john1113
    john1113 New Member
    Just so everyone knows, in Canada, the 16 inch wheels comes standard on the Prius C four. It's not an add on. So if you want the faux leather heated seats, fog lamps... you end up getting 16 inch wheels whether you want to or not.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Which is why asking questions without listing your location yields 'wrong' answers.
    robertmaria, ztanos and Rob.au like this.
  12. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    What kind of name is John for a Canadian? :LOL: Canada is nice. I'm in Toronto currently for business. Feeling bad for Alberta for that flooding.
  13. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    I dont own a Prius c, but I would suspect that like about every other car built, the steering stops are built into the lower control arms to limit front spindle travel. The steering stops may be an integral part of the arm, or just a simple bolt on. I dont know of any situation where the turning radius is set at the steering rack, it's done at the spindle and lower control arm to avoid bending any steering rods when the limit is reached. I would bet fitting the smaller wheels and increasing the distance to the steering stops is possible at not much cost. A little time spent with the Prius parts guy to compare part numbers should reveal what would be involved.
  14. john1113
    john1113 New Member
    Actually I mentioned I was from Canada in the original post. But it was in passing and probably easily missed.
    NickBaker9 likes this.
  15. john1113
    john1113 New Member
    Thanks!! Ill try chatting with the parts guys!
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Who reads posts' these days. :) I personally didn't know that a c4 there was that far off in difference from the ones there.
  17. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I'm thinking something like this.
    Or, something else cheap and quick would be to watch what you're doing and don't do that any more. Drive so you don't need to do 3 pt turns any more. Perhaps it's driving style, perhaps it's where you drive. Perhaps old habits can be modified.
  18. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    In some states, U-turns are illegal.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I did not find any states that prohibit u turns, certainly GA doesn't. That said, they all restrict when and where you can make a U turn.
    - http://www.dds.ga.gov/docs/forms/driversmanual.pdf
    (Both Taiwan and the Philippines do prohibit U Turns)
    Michigan is notorious for making them mandatory. Michigan left - Wikipedia, the free encyclopedia
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    They may have changed it recently, but I know for a fact that Ohio was illegal around 5 years ago. Unless both the judge and the police officer were taking me for a ride.
