Want to Raise a 2012 Pip. How Big A Rim Can I Use?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenmce, Dec 31, 2013.
  1. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    cutting the lower lip will only increase clearance from front but the spacer idea is a good one
  2. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Oh, I did not catch that you also want rear or under car extra clearance. I hope you find some doable suspension or other mod that gets you what you want.
  3. hill
    8,804
    Oh yea ... big rims ... big treads.
  4. davekro
    davekro Member
    493
    68
    2013 Prius Plug-in
    On the "monsterized' Prius. I had assumed this was Photoshopped, examining closer, maybe not??:eek:
    But I am sure this Prius has a REALLY bored out, blown, et al. 1.8L ICE ! :ROFLMAO:
  5. hill
    8,804
    No - they're shopped . . . the body would look teeny on monster tires/chassis ... that might make 'em even more funny.
  6. markabele
    5,084
    1,782
    Nebraska
    ya, you can totally tell it's photoshopped
  7. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    When I had my Tundra, lot of guys used coil spacers to lift them 2 inches. Ride was a little rougher and a couple guys had problems with the upper ball joints leaking after 30k miles. If you go that route, aim for a polyurethane not a metal one.
    This looks to be universal but use at your own risk.
    Superior RideEFFEX™ 18-1901 - Spring Spacer | O'Reilly Auto Parts
  8. maschronic
    maschronic Junior Member
    22
    Garbage Grove, CA
    1998 Prius
    Not sure if this info will help but ill mention it.
    I had a 97 camry. it had 195/70/14. I put 235/45/17. It raised the car by an inch. It did make the handling much better on the dirt roads at Landers, CA.
    Hope this helps.
  9. virtualy
    virtualy Junior Member
    34
    NorCal
    2014 Prius Plug-in
    I am having clearance problems with my PiP and a hitch-mounted bike rack. I scrape the rack when I try to climb my steep driveway. Wondering if you ever found a solution.
  10. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I plan to follow maschronics lead when I buy my next set of tires.
  11. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
