Want to tear down the steering wheel
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by hassan310, Feb 26, 2019.
  1. hassan310
    hassan310 Junior Member
    29
    PK
    Is there anyone who can help me to remove the steering column for gen 4. I want to install cruise switch since I own a basic model. I found on http://www.marklines.com but it's too costly. Thanks in advance
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Have you the rest of the Cruise Control - I imagine the computer is different, as well as RADAR and Windscreen sensors. They all need calibration (which is costly).
  3. hassan310
    29
    PK
    No. I'm just going for simple cruise not the radar cruise. It's just like plug and play.
    I only need switch
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    You do not have a Gen 4 Prius. I will report this to get moved to the Prius c forum. That is the US name for the Aqua model.
    alanclarkeau likes this.
  5. alanclarkeau
    7,045
    7,593
    Thanks - I didn't look at that - [the Prius c doesn't have RADAR Cruise available, I believe.]
  6. hassan310
    29
    PK
    There is no humiliation in ignorance. I hope you could answer what I asked rather than being stuck in my profile.
  7. alanclarkeau
    7,045
    7,593
    Sorry - but it's a very different car. Moving it to the Prius c Forum will mean that it's seen by people who own a car the same as yours, and will be much more likely to have an answer.
    Prodigyplace likes this.
  8. hassan310
    29
    PK
    How can you be so obtuse? Did you check the link I mentioned(marklines)? Does it relate to prius c?
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    JFYI, the link you posted in #1 is broken, or at least temporally unavailable? In any case, it would help you and other forum goers to place the thread in appropriate location that is under Prius C.
  10. alanclarkeau
    7,045
    7,593
    I'm sorry - nobody is being obtuse - whatever that means.
    The "MARKLINES" link won't open. Your profile says:
    upload_2019-2-26_21-54-29.png - is this your car or are you talking about another car?
  11. hassan310
    29
    PK
  12. Prodigyplace
    12,711
    11,848
    Central Virginia
    All trims in the US and many other countries, including the basic models, have Dynamic RADAR Cruise control already installed from factory.
    People mistakenly post in the wrong forum & are confused by our "Generation" terminology here but are respectful. You did not state you owned a different car.
    The link in your first post just pointed to Marklines main page. Other than your statement of Gen 4 there was no indication you were not perhaps confused by the Generation designations.
    Please be more clear & respectful in the future, or troll elsewhere.
  13. hassan310
    29
    PK
    I didn't mean to disrespect anyone. I knew where I was posting i.e prius gen 4,
    I simply asked how to tear down the steering column and rather than getting solution or a positive answer. I just ended up with that I don't own this car. Fair enough
    Anyway there are many Japanese trims which don't have Toyota safety sense as it is not a standard feature however due to their impressive built quality, they pre install all those wires and ecu and every other components. You just need a hardware(cruise switch, mm wave radar, front Cam whatever the case maybe) and calibrations. You are good to go.
    Lastly, I just want to install cruise switch that's all. Because DRCC won't work good where I live because of very bad traffic. I just need traditional cruise switch for my highway trips.
    Thanks
  14. Prodigyplace
    12,711
    11,848
    Central Virginia
    DRCC can run as a regular cruise control too. Just hold the ON button for 3 seconds.
  15. alanclarkeau
    7,045
    7,593
    It sounds like common sense to install just one wiring loom no matter what installed accessories there are. I've seen that in other cars with extra wiring which actually went nowhere for optional fittings which weren't there.
    After you install the hardware, are there any software changes you would need to make?
    In relation to it being a Gen 4 PRIUS. Can I suggest you change your profile from "2014 Aqua" - so we don't get confused next time.
    Unless - you do have an Aqua (known in most of the world as a Prius c) as well?
    Sorry - I don't know about removal of the steering wheel. I haven't removed one since AIRBAGS came in.
  16. Prodigyplace
    12,711
    11,848
    Central Virginia
    There should be Toyota technical documentation available by subscription for your region.
    @Elektroingenieur may know the details for Pakistan.
  17. Elektroingenieur
    2,515
    3,288
    Three Touring
    I’m not sure that’s so; the only subscription websites for Toyota service information I know about are those I listed on the PriusChat Wiki page, and they only cover the models sold as new cars in each region.
    For a Toyota Aqua or right-hand drive Prius c, the best source for service information written in English would probably be toyotamanuals.com.au, but I don’t know if you can subscribe to that website with an address outside of Australia. If you can read Japanese, you could buy an Electronic Technical Manual CD for the Aqua (NHP10). The English-language equivalent (Global Service Information Center) may also exist, but I’m not sure how you’d get it without an inside connection at Toyota or a dealer or distributor.
  18. Prodigyplace
    12,711
    11,848
    Central Virginia
    They are looking for Gen 4 Prius steering wheel teardown.
  19. Elektroingenieur
    2,515
    3,288
    Three Touring
    That’s easier: I’d suggest a subscription to toyota-tech.eu, and then go to: Repair > Repair Manuals > Model: Prius > Basic Model Code: ZVW50 > Search > RM3213EN > Steering > Steering Column > Steering Wheel.
    Prodigyplace and alanclarkeau like this.
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I think he was being a bit rude. (n)
    Obtuse: annoyingly insensitive or slow to understand.
    e.g. "he wondered if the doctor was being deliberately obtuse"
    synonyms: stupid, dull, slow-witted, slow, dull-witted, unintelligent, witless, half-baked, half-witted, doltish, lumpish, blockish, imperceptive
