WANTED - Gen1 Hybrid Inverter
Discussion in 'Generation 1 Prius Discussion' started by Paul Huynh, Jun 12, 2016.
  1. Paul Huynh
    Paul Huynh New Member
    Delaware, usa
    2003 Prius
    I
    Any member with an extra or spare working Gen1 Hybrid Inverter looking to sale or help a newbie out? Please PM me
    Thank you so much in advance
    My is Prius 2003 with 122k miles
  2. bwilson4web
    16,519
    You might join the Yahoo, Prius groups. They might have some leads. Also, Google search "salvage prius".
  3. Patrick Wong
    18,210
    6,517
  4. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Are you certain you need a Hybrid inverter? On more than one occasion I've had customers tell me "the dealer says I need a new inverter can you sell me one cheaper". After they tow the car to me it's evident the inverter coolant pump failed and the inverter overheated and set a code, causing the dealer to want to replace it. In some cases I just replace the pump, clear the codes and the inverter is fine.
    FireFighterHill likes this.
  5. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I had to replace mine, got one from a salvage yard for $75 with no warranty. Worked like a charm and simple to replace.
    TomK
  6. Paul Huynh
    Delaware, usa
    2003 Prius
    I
    Tom can you check with your local yard and see if that have anymore? I just call my local junk yard they want 500 for it... more then ebay price...
    Tom i will be so thankful and paid you in advance + shipping and all.. my zip code is 19707
  7. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    The problem with locating a used inverter is a bit more difficult than other parts in that it is not listed on car-part.com.
    I just called around and found one that would sell me one without warranty of any kind for the $75, it was $300 with warranty.
    I currently looked on the website of the place I found it at and they do not have any Prius.
    Good luck, there are more of these cars going to salvage so you should be able to locate one.
    TomK
