warm weather prius will not start. Stranded every day for hours till weather cools
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nathaniel McClain, Jun 9, 2016.
  1. Nathaniel McClain
    Nathaniel McClain Junior Member
    40
    Martinsburg, wv
    Yes. I don't have much of choice and it's a darker color like almost black
    51,258
    do you use sun shades?
  3. Nathaniel McClain
    40
    Martinsburg, wv
    Odometer was replaced bit says 85,000
    Batter
    i bought some because of this but forgot to use and I have been putting windows cracked bit forgot to too... Earlier today I did all this and no issue but I forgot a couple hours ago and it's not running.
    Has anyone else had ambient temp from weather affect their gen 2???
  4. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    Have you checked the negative terminal on the battery? Make sure it is tightly secured to both the battery and screwed in good to the body ground.
    When the immobilizer light is not blinking, do your interior lights work? Does anything in the car have power?
  5. bisco
    51,258
    the only thing i recall seeing is poor operation, not a no start situation.
    i'm beginning to wonder if something in your immobilizer system is overheating. maybe you were on the right track to begin with.
  6. Nathaniel McClain
    40
    Martinsburg, wv
    Ever heard of it before??? Worth getting a new one or is there a bypass?
  7. Nathaniel McClain
    40
    Martinsburg, wv
    Yeah checked it may times
    Yes everything works including fob to lock unlock car. Only things not working is car won't start or go ready
  8. bisco
    51,258
    no, but i haven't heard everything. i'm thinking you need toyota diagnostic software to help you pinpoint the problem.
  9. Augustus88
    87
    29
    Birmingham, AL
    Three Touring
    If you press the START button with your foot off the brake, does it go into accessory mode? If so, and you press the button again with your foot of the brake, does it then go into the ON but not READY state?
  10. Nathaniel McClain
    40
    Martinsburg, wv
    It does nothing.
    So when the immobilizer light is blinking. It will start/ go into accessory mode.
    When it's not blinking it won't do anything.
    Lights work door works. Fob works. But nothing in dash. It's even gone as far as it will blink then when I press it, makes a faint sound and does nothing. It won't blink after key pulls out.
    Typically this only happened after driving it and warm days and letting it set for a minimum of 30 min or so.
  11. Nathaniel McClain
    40
    Martinsburg, wv
    I have had it start blinking after playing with fob. Which I do but I think it only really resets the light after the issue has gone
  12. Augustus88
    87
    29
    Birmingham, AL
    Three Touring
    Extremely strange.
    Does anyone know if accessory mode (foot off brake, press START once) uses only the 12 volt battery, or if that mode is powered by the HV battery?
    I wonder if some component is borderline failing (Like a capacitor on a circuit board somewhere), and the heat aggravates the condition.
  13. Nathaniel McClain
    40
    Martinsburg, wv
    whwt makes it worse.... Missing a date tonight! :/
  14. Nathaniel McClain
    40
    Martinsburg, wv
    I checked the immobilizer capacitor and didn't see any issues
  15. Nathaniel McClain
    40
    Martinsburg, wv
    I meant to say the board and looked for discolorations, bad solder, swelled capacitors and didn't see anything. I was trying to see what energizes that and check it. Like does the main Ecu energize it?
  16. Nathaniel McClain
    40
    Martinsburg, wv
    If it matters I recently changed my radio from a standard CD player to the MP3 version. Doubt it matters but through that out there
  17. bisco
    51,258
    have we discussed actual 12 volt measurements?
  18. Nathaniel McClain
    40
    Martinsburg, wv
    I measured and it was 12.8v front and back. I haven't measures Ecu or anything just up front and rear.
    Out of half fear reading that soe
    some reson my post didn't go through.
    Ok so update, today as I went for morning coffee. And when I came home and pulled out the key I noticed the light did not come on for security!
    I started it and it still started though.... I shout it off and waited a couple hours and came out and it started again but the light was not blinking. I shut it off and out of curiosity I tried once more and it is back to not starting.... No light blinking. So weird. Any thoughts?
  19. Nathaniel McClain
    40
    Martinsburg, wv
    One other thought is, my door does not always beep when key is in and sometimes it beeps when no key is in and everything is off
  20. JC91006
    16,688
    8,521
    You need an exorcism
    Nathaniel McClain likes this.
