warm weather prius will not start. Stranded every day for hours till weather cools
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nathaniel McClain, Jun 9, 2016.
  1. JC91006
    16,688
    8,521
    So it seems this has nothing to do with heat.....Do you have another keyfob?
  2. Nathaniel McClain
    Nathaniel McClain Junior Member
    40
    Martinsburg, wv
    Yes two of them.
    Yeah this is the first time it wasn't affected. It did sit in hot weather though and I only tan it a short time like seconds.
    I know it only happens when hot but today I was playing with it and kind of regret it cause now I'm stuck...
    And yes I have another. I've tried both.
  3. Nathaniel McClain
    40
    Martinsburg, wv
    I looked at fuses and they were crusty looking outside the car so I cleaned them and reinstalled. I'm now wondering if maybe grounds are bad...?
    Does this seem possible??
  4. JC91006
    16,688
    8,521
    Sounds like an immobilizer problem. You probably should send a PM to our Colorado expert "3prongpaul", he would know how to fix this.
  5. bisco
    51,258
    was the car in a flood or something?
  6. Nathaniel McClain
    40
    Martinsburg, wv
    I'm sorry to explode this...
    I was just checking everything and found that there is this vent tube going to this small circuit board below the key fob area. It was extremely dusty. I cleaned it and far started....
    May coincidental but what does this thing do?
  7. JC91006
    16,688
    8,521
    post a picture of this circuit board
  8. Nathaniel McClain
    40
    Martinsburg, wv
    Not that I'm aware of. But it's unsure really
  9. bisco
    51,258
    how long have you had it? miles/years. who/where did you get it?
  10. Nathaniel McClain
    40
    Martinsburg, wv
    I can't add on phone. I will when home. But it's the one below the key fob about 5" down and 1" right. There are small slits to allow air flow as you remove that shifter bezel behind it you will find that small board. It has a white plastic tube about .5" that obviously flows with air
  11. Nathaniel McClain
    40
    Martinsburg, wv
    I've inky had for 8,000 miles it has what is believed to be 84,000 (odometer matches title but was replaced)
    I bought from a guy in Rockville, md. Defintly not a flood area but never know
  12. bisco
    51,258
    i hope not, though they do ship those cars around the country. not sure what would make the fuses crusty.
