Warming up the car in winter
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Dec 15, 2012.
  1. bisco
    52,863
    methinks mike or nancy lost interest in this thread long ago.o_O
    52,863
    yes it is logical, i have tried it and it does work.:sneaky:
  3. You are so logical Bisco. I left my car charging in the garage all night with the heater on. It got 125 degrees inside the car and all my batteries were dead. Warning ! Do not try this.
  4. I think they were trolls.
  5. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    If you want instant heat in a Prius, or any other hybrid, light a match, put it in front of your mouth.......and blow !
  6. I prefer downing a few shots of gasoline first.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    lol, yer sarcasm is good, yer a natural
  8. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Andy,
    With the FRONT Defrost button off, the Fan and the Windshield/Feet Vent position puts plenty of air to the Windshield. Sure, I would prefer a Windshield-only Vent selection, but I use Windshield/Feet Vent position most of the time, instead of the FRONT Defrost button.
  9. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    OK, now you added a NEW Problem, Your Spouse !!!
    Yes, when my wife is in the PIP, like to dinner every Friday, MPG goes OUT the window.
    "I'm cold, turn on the heat."
    And she's driving the Gas Guzzler Camero !!!
    Coyotefred and Andyprius # 1 like this.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    We need to make it very clear. ;) (pun intended) The normal settings work fine if you live in a climate where the heater is required (below freezing for the highs). Just letting the engine cycle on & off as needed is enough.
    It's the in-between conditions (cool but not cold) that contribute to "severe", which is counter-intuitive. People could easily assume the extreme instead.
  11. If you put your hand far forward on the bottom with max fan, you will feel NO AIR. Now hit the defrost button, notice the huge difference? I used a telltale at the windshield for proof. I definitely agree with your preference, me too. As John has elucidated, the areas that do not have below freezing temps consistently, notice the condensation/fogging. I'll just have to move back to Ultimate Thule.
  12. donalmilligan089
    239
    22
    virginia usa
    This person wants to know how to warm the engine with out running it, A block heater helps some what and enable ice to warm up quicker. I think an electric water heatr insalled in system might be better . any advice?
  13. bisco
    52,863
    nothing will help if you don't want to run the ice. you can preheat the block and the coolant all you want, but if you want heat, you'll need to burn some gas. not you, but the op, who seems to have given up on this thread.:cool:
  14. bisco
    52,863
    if you are correct, why would driving 15 minutes ev warm up his engine?
  15. lensovet
    2,615
    496
    Burlington, NJ
    Though I guess with the block heater you can significantly reduce the warm-up time, right? So you can use one egg of gas instead of two.
  16. bisco
    52,863
    yes, but i'm trying to stay with the op's question, even though they don't seem to care anymore. or perhaps they went on vacation and haven't come back yet. op stated, ' if i drive for 15 minutes before turning on the heat, mpg doesn't go down when i turn on the heat. can i warm up the car for 15 minutes in the garage so i can turn the heat on when i leave without mpg's taking a hit?' they stated it 3 different ways, none of which made sense.
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I beg to differ.....I defrosted my car this afternoon, then drove to Subway which is a mile away.....My MPG when I turned off the car at Subway was 9 MPG.
  18. bisco
    52,863
    probably would have been 3 mpg if you hadn't defrosted first.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    even less....interesting:whistle:
  20. That's better than some trucks!
