Warning about front brake wear......
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sorka, Apr 13, 2017.
  1. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    My front brakes started squealing from the inner pads feeler gauges hitting the rotors. But the outer pads still have about 70% of the pads left. The inner pads were down to about 1.5 mm even on both sides. Car has 250K miles on it and they are the original brake pads.
    So FYI, if this is typical of this caliper setup your brake pads may be more worn than you think.
    The rear drum shoes were 2 to 3mm so they've another 75K miles easily before they have to be replaced.
    Redid the front brakes yesterday. New rotors, pads, shim, and slider hardware.
  2. Mendel Leisk
    38,893
    You can see the inner pad thickness, looking through the little "window" on caliper shoulder. Sounds like neglected caliper pins btw.
    valde3 likes this.
