WARNING Another Techstream project
Discussion in 'Gen 4 Prius Technical Discussion' started by Misterman74, Jun 10, 2026.
  1. Misterman74
    Misterman74 Junior Member
    33
    Fresno
    2018 Prius
    First and foremost. Got a VXDIAG device to plug into the obd. Included with the purchase UPON REQUEST ONLY is the "free techstream".
    Wow shady.
    They email you a google drive link, embedded within is a link to a sketch mirror site for the actual download.
    Its a zip. Windows defender AI straight went nuts. Without even opening it. After much research, seems as tho its a real trojan, not just a patch. Recognized as Trojan:Script/Ulthar.A!ml
    Apparently the cheap amazon cables that have the CD are guilty of this too.
    just wanted to spread the awareness of if you do go this route, USE A DEDICATED LAPTOP that you are sure is free of any personal information. Preferably on a divorced, secure network.
    --- side question. Legitimate TIS download techstream, what happens after the paid subscription window?
    Any specific loss of features? Or just a dead brick wall of login screen?
    52,742
    thanks for the heads up!
  3. Misterman74
    33
    Fresno
    2018 Prius
    Bump for question in bold
  4. Brian1954
    Brian1954 Senior Member
    2,645
    1,052
    South Central PA, USA
    Without a current subscription, you will not be able to login to the Techstream software on your computer.
    Misterman74 likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,943
    6,862
    Texas Hill Country
    All Techstream versions available from non Toyota sites are cheap and have instructions which say turn off virus check, don't go online or Toyota will deactivate and some features never worked even 15 years ago. You also have to run a registry hack. The hacked versions never worked online but had 90% of the features when used off line including bidirectional controls.
    The current Toyota subscription version will work online but is not the same Techstream in look, feel or features since Toyota went to a new graphical GTS+ version. It is tied to the subscription but will work offline for the subscription period once activated online. The minimum Pro subscription that includes GTS+ Techstream is 2 days for $80. If you buy the one year Pro subscription you have to login online once a week. A hardware interface and PC are still required.
    In reality, many keep an old version on a XP or Win7 machine as a backup to thheir easier to use but slightly limited Autel or Launch scanners, some without bidirectional controls or ecu programming but selling for as low as $60 (usually with one brand requiring no recurring subscription).
    #5 rjparker, Jun 11, 2026
  6. Misterman74
    33
    Fresno
    2018 Prius
    that answers my question! Thank you guys I really appreciate it!!!!
