WARNING: Don’t do this to your Prius that burns oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by M67v, Apr 26, 2021.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    oh thank you thought you were pissed at me.
    M67v likes this.
  2. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    This. I don't see Sam's posts thanks to the handy-dandy ignore button, so it seemed like a strangely combative set of responses. :D
    M67v likes this.
  3. ChapmanF
    18,249
    I tend to not use the forum's ignore button for just that reason, so I won't get thrown off when reading a thread. I've got a kind of internal ignore button that works ok a lot of the time.
    If you want to put a kind of constructive spin on it, in a lot of areas of life you do sometimes run into other people kind of like Sam, only usually less so, which makes them a little harder to recognize. Here on PriusChat we get valuable experience that helps to spot them quick.
    M67v likes this.
  4. privilege
    privilege Active Member
    659
    169
    Birmingham
    when you come into a conversation with an opinion/theory, and others point out the flaws in your view...
    it's up to you to understand the guidance or take personal offense.
    either way, the folks that share their experiences already know better.
    M67v likes this.
  5. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    I tried switching to 0W-40 (from 0W-30). The oil consumption went down only very slightly, but the fuel consumption increased slightly, so I switched back to 0W-30. So thicker oil doesn't always help much, but I agree that it's worth a try.
    If I lived in a very hot climate, I would be using xW-40.
    I think a lot of people don't fully understand the motor oil cold temperature viscosity rating system (the number in front of the "W"). All motor oils are always much thicker than optimal when they are cold. Oils with a lower W rating are just less bad than oils with a higher W rating when it's cold.
    edthefox5 and M67v like this.
  6. M67v
    M67v Junior Member
    49
    Reading, PA
    I hear you man. Like I mentioned earlier, I was replying to someone who you may not have seen because you may have hit “ignore user”, but I only replied in such a way because I was already not in a good mood and that person was clearly trying to press my buttons
