warning light confusion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by halsey, Feb 3, 2024.
  1. halsey
    halsey New Member
    2004 prius. 12v battery died. Put in new Toyota brand battery. Now have warning lights. Red triangle, cel, brakes and in the display screen the hybrid light. I can disconnect the12v and clear them but in 1- 10 miles they come back on. Car drives normally. Need advice...
    52,657
    you need to read the trouble codes to find out what is wrong
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,310
    5,383
    Pacific Northwest, USA
    Any chance you accidentally hooked the battery up backwards for a second before turning it around? What's the voltage of the new battery?
  4. halsey
    halsey New Member
    no backwards installation. 12.7v after sitting overnight.
  5. halsey
    halsey New Member
    I'll need to get a scanner or a shop appointment.
  6. ChapmanF
    18,848
    The lights tell you there are trouble codes to give information about what's wrong. You can post the codes here to get suggestions.
  7. bisco
    52,657
    I’ve heard that it’s possible to fry an old pc board when re energizing it. Idk if it’s true
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,009
    NJ-USA
    Here's a thread that reviews several apps and devices that turn your smartphone into a scantool. Some are capable of checking codes and data for all systems on a Gen 2 Prius.
    https://priuschat.com/index.php?posts/3290690
    bisco and halsey like this.
