Warning light on dashboard
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010_Prius_Bro, Nov 14, 2022.
  1. 2010_Prius_Bro
    2010_Prius_Bro Junior Member
    44
    maryland
    Prius warning light.jpg Prius warning light.jpg This warning light started flashing for about 2 minutes while driving home today. Then it became solid. No check engine light. Looks like something to do with the wheels. What might be the problem? Tires are inflated to spec and no weird sounds while driving. Brakes working normally and brake fluid level is good. Any help would be appreciated.
    iPhone ?
    #1 2010_Prius_Bro, Nov 14, 2022
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    That's the tire pressure warning light. If the pressures are correct,
    then you probably have dieing batteries for the monitors.
  3. Mooselips
    Mooselips Junior Member
    Littleton, NH
    It's telling you that one (or more) tire pressure is low. If you've recently verified that in fact al four tires are properly inflated, then the sensor has probably gone haywire. Talk to your favorite Prius mechanic.
    52,849
    or ignore it
    Grit likes this.
  5. ChapmanF
    19,020
    When it does that, it's not telling you about pressure in any tire. It's telling you it doesn't know the pressure in at least one tire, because of a system issue.
    The system issue, at this age, tends to be that the battery has pooped out in one of the in-tire pressure transmitters.
  6. 2010_Prius_Bro
    44
    maryland
    Thanks guys. Most likely I’ll need to replace the TPMS sensors. All tires are at normal PSI. I’ll ignore for now until I need to change my tires in 2023. Thanks for all your help!
    iPhone ?
    ASRDogman likes this.
  7. NatefromRI
    NatefromRI New Member
    Fort Worth
    Or...it could be that due to cold weather, the sensor is not reading the correct pressure. Have there been any temperature changes recently "in your neck of the woods"? You can put nitrogen in your tires at Costco for free (if you're a member) and this tends to help. Otherwise, it's probably a sensor gone bad if your pressure is accurate.
  8. ChapmanF
    19,020
    The TPMS computer chose to blink the light before going solid, so we know it is a system issue (most likely a dead transmitter), and not a pressure reading.
