Warning Light to Take Immediately into the Dealer
Discussion in 'Gen 2 Prius Technical Discussion' started by msquared48, Jul 16, 2011.
  1. msquared48
    msquared48 New Member
    30
    Everett, WA, USA
    Well, it made it to the shop and I am waiting for the diagnosais.
    In thinking further on this scenario, I am further convinced that it is the water pump, as we got the warning after driving 70 miles or so, and it cleared 2 hours later, which could mean that the car cooled to the point that the warning light sensor cleared. We'll see.
  2. msquared48
    30
    Everett, WA, USA
    Well, the sensor warnings were due to low battery voltage - 10.7 I guess, but the battery tested OK and is fully charged, holding it for now anyway. Will just have to keep an eye on it. The water pump is OK too.
    Thanks for all the comments. You learn something new every day...
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Rather than pressing the lock button inside the car, I recommend locking the car with the mechanical key. If you use the key, you know it's outside the car...
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    If the inverter pump is OK now, that means, it now shows turbulence in the reservoir? Was the cause of no turbulence previously a low 12V or the inverter cooling system needed the air bled out of it ???? :D
  5. archae86
    archae86 Member
    153
    24
    Albuquerque, NM
    A recurring observation on this forum is that many of us who have taken our cars to the dealers with a 12 V battery in marginal condition have been given a passing grade from them. It seems that the usual dealer testing here is biased in the direction of avoiding failing a battery that has any useful life left, and not biased in the direction of protecting the customer from an awkward experience.
    The sticky thing is that a lifetime of experience of how traditional cars behave when their battery is going marginal is poor preparation for the myriad behaviors that a Prius can exhibit when the 12 V battery is dying. Oddities in detecting the fob, including failure to recognize that the fob is inside the car, a whole range of odd instrument panel displays, and various other things are possibilities.
    I, personally, carried out 12 V battery replacement on our 2006 Prius using the kit offered by elearnaid. While no very great skill or sophisticated tools were required, the instructions had several points of ambiguity, and the working location is actually rather awkward. Also considerable force was required at one point (although the instructions happily warned of this). If you have any doubts on this point, I think you might be better off seeking replacement by the dealer or other professional. But I do suggest that you not wait until the car is dead. Your recent episode almost certainly reduced the remaining life of the battery appreciably, and very likely you were within a year or so of it without the episode.
  6. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    It would be very foolish to not replace a four-year-old battery that has displayed the symptoms you have described.
  7. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Every person who has posted on this thread has suggested replacing the 12V battery. It is annoying when people come here seeking help only to ignore it.
  8. andyprius
    2,212
    188
  9. andyprius
    2,212
    188
    I think the problem is the more enthusiastic PCers are more conversant with general car repair, electric/electronic, computer problems all in varying degrees and treat a problem like a challenge even possibly as a hobby. Where as some of the 1st time users may not even relate to what we are trying to explain. :fish2:
  10. imwoody36
    imwoody36 the prius parts guy
    143
    116
    southern Indiana
    my two cents.
    only charge a prius battery for 20 minutes at reduced amperage.
    ( the lowest setting..never "boost")
    they usually recover well, unless cooked.
    overnight charging at 4 amps is going to shorten the life of the 12 volt battery.
  11. Patrick Wong
    18,210
    6,526
    When charging the Prius 12V battery, I use a lab power supply set to 13.8V. The power supply has a maximum current output of 3A; hence the charging starts at 3A constant current and some lower voltage than 13.8, maybe 12.5 or so depending upon the state of charge.
    The voltage slowly rises depending upon how low the battery is, and eventually the charging becomes constant voltage at 13.8 with the current flow declining over time. I usually continue this overnight, or until I note that the current decline stabilizes. Usually this will be at around 100 mA or less (if the final current is much more, then that is an indication that the battery is not in great shape.)
    This process is essentially no different that leaving the Prius READY for the same period of time, i.e., the car is on a road trip. In fact it is better because the Prius will basically use constant voltage of 13.8 regardless of 12V battery state of charge (once the 12V battery is fully charged then the DC/DC converter may reduce voltage if the cabin ventilation system is not running, unless some other significant electrical load is on like headlights.)
  12. richard schumacher
    7,686
    1,068
    United States
    10.7V is too low. That battery is nearly dead. Replace it or you will get stranded somewhere.
