Warning light when the windshield wiper fluid is low or out?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Feb 2, 2016.
  1. Preeeus
    Preeeus Member
    258
    60
    For the 2010 Prius, should there be a warning light when the windshield wiper fluid is low or out?
    I don't see one in the Owner's Manual, but I have never seen a modern vehicle without a warning light for low/exhausted windshield wiper fluid. Mine ran out, and there was no warning indicator when it was low or empty.
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    #2 xliderider, Feb 2, 2016
  3. Preeeus
    Preeeus Member
    258
    60
    Thanks. Funny how my post and that one are timed so similarly.
    Glad to know it doesn't exist, so it's not broken!
    Odd that it's not included or an option, but, well, I guess they had their reasons.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Well, I'm sure there are many others who like you, bemoan the absence of an "Windshield-Washer-Fluid-Low-Level-Idiot-Light", but I love my 2009 Gen II Prius, despite all its deficiencies, but I've never felt the need to ask for "Jam on it" (…so to speak!) :eek:
    Edit: Stop Press! I've just noticed that the Windshield-washer Fluid bottle in my 2009 Gen II is semi-transparent, which means I can monitor the use of the contents, and refill when necessary! (…gotta hand it to those cunning Japanese! ;))
    #4 WilDavis, Feb 2, 2016
  5. bisco
    51,155
    i think europe gets one.
  6. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I've never had any vehicle with a low-washer-fluid warning, but this is my first one that makes the fluid level so difficult to determine.
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Well the OP is wrong anyway. He HAS seen a new vehicle that doesn't have the light. His new Prius. ;)
  8. ETC(SS)
    6,958
    I live in a fairly dusty area so I use lots of washer fluid....but I also like to check my oil level semi-occasionally.
    I don't miss the electronic reminder at all.
    All of my other cars have them, but since I yank the hood open every other fill-up or so to check fluids, and since windshield washer fluid is a .......fluid on the check list, it usually works out.
    Toyota went with the yellow stick to save money.
    I'm OK with that.
    YMMV
  9. qdllc
    qdllc Senior Member
    1,371
    399
    It's a non-critical fluid, so they probably just didn't bother. Most every car/truck I've had in recent years didn't have a warning light for wiper fluid.
  10. David Beale
    5,963
    1,987
    Edmonton Alberta
    Oh, just found that the GIV Prius HAS the light or indication.
    Trade-in time! ;)
  11. krmcg
    2,592
    2,391
    Whittier, CA
    1.JPG 2.JPG 3.JPG 4.JPG I have personally never seen a dipstick for the window washer fluid. Maybe I just have not "been around" enough. But my 2016 Prius has one...
  12. bisco
    51,155
    correct. it's like they molded the fluid bottle to fit any space that was left in the engine compartment, thus creating a giraffe neck filler.
    Preeeus likes this.
  13. Mendel Leisk
    40,586
    There's the yellow plastic dipstick for checking, or is it missing?
  14. krmcg
    2,592
    2,391
    Whittier, CA
    Black dipstick
  15. bisco
    51,155
    i don't bother with the dipstick, i just add fluid if i can't see it.
    WilDavis and krmcg like this.
  16. Mendel Leisk
    40,586
    3rd gen is a fetching yellow. :)
    krmcg likes this.
  17. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Oh, it's there, but difficult to interpret. Fortunately, that's not important, as I'd rarely use the washer even if the nozzles were aimed properly.
  18. David Beale
    5,963
    1,987
    Edmonton Alberta
    Well the 2016 I think also has an indicator on the dash, at least the Toyota Canada site says all Canadian models have it, and if we do you definitely should. ;) We're always last to get stuff. I think the 2016 Prius is the first one for Canada to have the HUD (optional).
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Maybe I'm just a poor child.....
    But I've never owned a vehicle that offered a warning light for low windshield fluid.
    However, I will say, every OTHER vehicle I owned had a much more easy to see and ascertain the fluid level reservoir.
    IMO the plastic dipstick is nearly useless in determining remaining fluid level, and with the reservoir it's very hard to ascertain how full or empty it is.
    My reaction has been just to be diligent in occasionally filling it up. It holds a lot. So topping it off every couple of months makes it a non-issue.
  20. Mendel Leisk
    40,586
    I've never had a problem reading that dipstick, but I've got strong myopia, which actually puts me at a advantage reading extreme close up stuff. I'm the go-to guy for threading needles.
    Preeeus likes this.
