Warning light when turning left?
Discussion in 'Gen 2 Prius Main Forum' started by schmultzburger, Jul 16, 2012.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Having light come on at turns is a classic symptom of low oil.
    Unfortunately I have customers who use this as their sole indicator as to when to add oil.
    Scary.
    It is definitely waaaay to low by that point.
    cwerdna, m.wynn and edthefox5 like this.
  2. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Well, It's a bummer that we have to check oil dipsticks. I thought we were done with dipstick checking 30 years ago... Can't wait for all electric vehicles now.
  3. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Yes, my clean dipstick reinserted showed clean no trace of oil... I had to start prius and let it idle few minutes before showing oil at low level on dipstick.
  4. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    I have say that is not a great procedure to follow. While the engine is off and sat for a minimum of 5 minutes (according to the Toyota Repair Manual, I know Edthefox will beg to differ) you need to read the dipstick and add oil until it is at least above the F mark on the bottom of the dipstick. At just on the F mark the oil is still 1.6 qt (US) (1.5 L) too short. When you consider the total volume of the sump is 3.9 qt (US) (3.7 L) 1.6 qt (US) represents 41% of the total volume, it just does not make a good practice keep the oil that low.
    m.wynn likes this.
  5. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Correct, Prius was parked for three hours and I open hood to check the dipstick. It's hard to believe that dipstick is clean no trace of oil. I will check again since filling oil yesterday.
  6. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Fyi. My 07 doesn't use much oil, but I switched to Mobil 1 recently and oil burn is minimal.
  7. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    I wonder if Toyota has a threshold for oil consumption (e.g. > 1 qt/1000 miles?) where an engine rebuild is considered? Certainly it's possible to carry oil to add periodically, but I have to believe that eventually reliability becomes an issue.
  8. dolj
    dolj Senior Member
    8,655
    4,406
    Yes they do, it is > 1 qt (US)/600 miles.
    It is not hard to believe, if you never check your oil.
    Why didn't you check 5 min after you added oil? Once it registers on the dipstick just keep adding 0.5 qt (US) at a time, until the oil level is between 2/3 and full. Don't overfill!
    Then to get an idea of the oil burn rate, check at every fuel fill. Once you get an idea of the rate at which it burns oil, select an interval (once a week, once every two weeks, etc) and check and top up as required at that check.
    #28 dolj, Jan 31, 2018
    strawbrad and KennyGS like this.
  9. Fredsimm
    188
    117
    Tupelo MS
    Currently I've used 1/4 qt. with 2400 miles on the odometer. With conventional oil I would probably be almost a whole qt.
  10. toyofan
    toyofan Junior Member
    Pennsylvania
    I am curious about what the best practice is regarding managing the engine oil level. I'm not quite at 1/2 qt low after 5000 miles. Should I be always be trying to keep it up to the full line, can I let it go till a qt low and then just do an oil change at 10,000 miles, or just not let it get below 1/2 qt low? I check the oil level about every other week or so.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    @Raytheeagle or @danlatu what do you recommend?
    Raytheeagle likes this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I keep our cars at 2/3 to 3/4 level on the dipstick. I check the level every Saturday to ensure the level doesn’t creep low and if it does, I add some;).
    Been doing that for 20 years and so far has worked well (y).
    uart, danlatu and Prodigyplace like this.
  13. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I would do an oil change. Its cold in pa now, you have moisture and fuel inside your crankcase(oil pan) from cold starts. This water and fuel break down the oil. You could have your oil analyzed at black stone labs to see how much life is left if you want to stretch those oil changes to 10k and just add oil. But this test cost 28$. I do 5k winter and 7.5k summer oci.
    Prodigyplace likes this.
  14. toyofan
    Pennsylvania
    Does it make a difference that I'm using mobil 1's 10,000 mile synthetic? They promote or "guarantee" that it will hold up for 10,000 miles or 1 year.
  15. Mendel Leisk
    42,369
    Are you joking? (n)
    Raytheeagle and uart like this.
  16. danlatu
    533
    1,367
    maryland
    They also have 15k 20k 25k 30k motor oil out there but when contaminants like fuel and water are introduced in the crankcase during the cold season, oil will break down. I am sure in perfect conditions it could last with a perfect running motor. I would question wether the oil filter would hold up at these mileage claims. The only way to find out is to send it in for testing.
    Amsoil 83.50$ for an oil change & filter + 28$ @10k and + 28$ @15k for testing. 140$ for oil change and testing?
    I would love to see the test results if someone wants to try it.
  17. danlatu
    533
    1,367
    maryland
    Bmw no oil dipstick! What if the oil level sensor fails?
    Prodigyplace and Mendel Leisk like this.
  18. Mendel Leisk
    42,369
    Way too pricey for me, both items. :eek:
