Warning message
Discussion in 'Gen 4 Prius Audio and Electronics' started by Ryder99, Mar 7, 2023.
  1. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    Is there a way to perminately fisable the warning message that comes on when the car is first started?
  2. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    What warning are you getting? Is the check engine light on? Maintenance required?
  3. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    If it’s a standard warning message where you have to click OK on the screen (the gen 3 doesn’t have this so I don’t know for sure) the only thing I can think of would be to get one of those OBD2 port scanner/customization apps. I used to use Carista before they went to a subscription model. I’m guessing they’re all like that now unfortunately.
  4. AntonyU21
    AntonyU21 New Member
    ca
    It is possible that the safety warning message will appear when the handbrake switch is set to open
  5. bisco
    52,891
    Is it the gps warning?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    My C has some kind of safety warning that comes up upon every start.
    Likely no way to eliminate it.......but it disappears on it's own after about 20 seconds.
    If that's the kind of thing you are asking about........just ignore it and find something else to obsess about.
    Ryder99 likes this.
  7. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    The message is the one that pops up on ebery start up. Sometimes it feels like the message is on for longer than 20 seconds.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    This "discussion" is pretty pointless.......unless you tell us what the message ACTUALLY SAYS.
    Sounds like it is their stock "drive safely" warning.
    Might be longer than 20 seconds.
    Probably can NOT be removed.
    Probably should find something important to worry about instead.
    I think I said that already.
  9. bisco
    52,891
    maybe it's new to gen4
