Warning: My 2010 Prius brakes failed while driving!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusfannn, May 13, 2013.
  1. Yes, just the noise while braking.
    40.0%
  2. Yes, smilar noise then brakes failed.
    30.0%
  3. I've heard of someone else having this issue.
    30.0%
  1. Former Member 68813
    3,524
    983
    US
    You are not helpful, we are talking about master cylinder failure here.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Not recently. I checked it for UIA concerns last year.
    I agree that if the master cylinder failure is becoming common then this is a very serious issue and I don't mean to belittle it in any way. I just want to make sure we are not confusing this issue with others. :)
    WE0H likes this.
  3. Former Member 68813
    3,524
    983
    US
    Most of those failures were reported in 2010 IIRC. Was the part redesigned in 2011? If so, 2010 should be recalled. Does anyone know?
    I did some search. I hope I understood correctly.
    The 2010 part# is 4705047140
    BRAKE BOOSTER ASSY, W/MASTER CYLINDER. BRAKE MASTER CYLINDER (PRIUS (ZVW30)). # 4705047140, 4705047060
    The 2011-12 part# is 4705047180
    BRAKE BOOSTER ASSY, W/MASTER CYLINDER. BRAKE MASTER CYLINDER (PRIUS (ZVW30)). # 4705047180
    There was also part# 4705047060
    but not available anymore (defective???)
    BRAKE BOOSTER ASSY, W/MASTER CYLINDER. 2012 TOYOTA Prius # 4705047060
  4. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    That's pretty much the case on every car.
    WE0H likes this.
  5. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    I think you would be shocked at how many people probably don't know that you aren't supposed to pump your brakes when you have ABS.
    WE0H likes this.
  6. fuzzy1
    10,705
    But doing so won't cause brake failure. It takes away much of the benefit of ABS, but still works as well as pumping old fashioned non-ABS brakes. OP's description clearly indicated that something else was happening.
  7. Former Member 68813
    3,524
    983
    US
    True. But I owned many cars in the last several decades and have been active in many automotive forums for more than a decade and never heard of total and sudden failure of brake master cylinder until this. While this is still a rare event in 2010 prius, the pattern does emerge though. I guess the high tech design makes it more vulnerable to failures. Based on that, I made some trial stops using emergency brake just in case I need to use it once. It's weak, but it works and stops the car at low speeds. Not sure about high speeds. I personally prefer a hand brake as it can be moderated easier.
  8. nparker13
    nparker13 Member
    121
    CT
    I'm somewhat relieved I'm not the only one with this issue, but on the other hand I still have the issue. I have a 2010 Prius V (5) with about 70k miles. I had the EXACT same issue with loss of power and the dreaded squeak. I brought it in to A1 (New Haven CT) . They replaced a brake position sensor (i think)...still squeaked...then the whole master cylinder...still squeaks...I'm headed down there this afternoon to bring it in again. Thankfully my insurance company has been working with them (mechanical breakdown), but this is a major issue if multiple Prius are having this.
  9. Former Member 68813
    3,524
    983
    US
    nparker13 likes this.
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
  11. Bill Norton
    Bill Norton Senior Member
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    I still don't understand the OP saying this: "and was able to slowly get the car to stop by pumping the gas pedal."
    Say what?????
    And then he goes on to say he didn't think using the emergency brake would have worked.
    It amazes me how many people don't understand and have never been told and trained about using the Emergency Brake as an Emergency Brake. It is also called the Park Brake, but that is a secondary function.
    I blame a lack of proper Driver Training. If your Dad doesn't know, how can you get the training.
    How are new drivers trained these days?
    The Emergency Brake is a mechanical cable system. It will work No Matter What. Total car system blackout, EMP in the area, Zombie Apocalypse....
    You step on that pedal and you will slow down. Try it. Practice for when your brakes fail.
    That's why it's required in all cars.
    F8L, Thanks for the recall info!!! I got myself registered.
  12. Blu-ray
    471
    198
    TampaBay, FL
    Unless it's a 2003 Ford Focus. I used the parking/E brake when parking on a hill and the cable snapped.
  13. priusfannn
    priusfannn Junior Member
    Los Angeles
    Thanks. I checked my VIN on the toyota.com/recall site and my car is part of it.
    I just picked up my Prius from my mechanic yesterday. They replaced the brake booster / master cylinder.
    Hopefully I will get reimbursed from Toyota.
  14. priusfannn
    Los Angeles
    Update: 2 days after picking up my car from my mechanic after replacing the master cylinder the recall came out. About a week after that, my brake pedal started making the same noise as before. Took my car to the dealer. They ordered the pump/accumulator which is the part named in the recall. The pump failure probably caused the master cylinder to fail, twice. Will update after I hear back from them.
  15. eliotb
    eliotb Junior Member
    68
    16
    Northern Virginia
    I've got a 2013 car that is 6-weeks old and the brake pedal slowly dropped to the floor at a traffic light today (with my foot applying gentle pressure.) I'm going to take a look for any errant brake fluid. At first blush it has all the earmarks of a failing accumulator/booster or a fluid leak.
    Anyone had this happen on a brand new vehicle, basically right out of the box, or am I just looking at normal behavior for the braking system on this thing?
    Thanks.
  16. Bill Norton
    2,242
    753
    MONW, Ks.
    2019 Prius
    L Eco
    Dang Eliot,
    I would drive carefully straight to the dealer and get a ride home. No where else.
    You do know the Park/Emergency Brake pedal is your last ditch mechanical brake system, correct?
    Please practice with that pedal.
    It sounds like you are driving a very dangerous car.
    Good Luck
  17. eliotb
    68
    16
    Northern Virginia
    In fact, I just got under the car in our parking lot at work and see a puddle of brake fluid, so I'm headed to the dealer now. Yep, i am exceptionally familiar with the emergency brake and ABS brakes.
    WE0H likes this.
  18. WE0H
    WE0H Senior Member
    3,247
    528
    Please keep us updated on what failed.
    Mike [​IMG]
  19. hlunde
    hlunde Member
    419
    75
    A little more detail about the video. The vehicle is a Toyota Venza with a conventional vacuum brake assist. If the engine is operating wide-open-throttle (WOT), then there is very little engine vacuum available and if you pump the brakes you will deplete the vacuum in the booster reservoir (goes to atmospheric pressure) and you will lose assist. But if you have a brake fluid leak, pumping the pedal will re-supply brake fluid to the brake lines and you will be able to restore braking -- until you deplete the fluid reservoir.
    But nothing in the video applies to the Prius -- if you engine is operating WOT, you'll still have the electric boost pump. Actually, the engine shut off does apply to the Prius.
  20. Former Member 68813
    3,524
    983
    US
    I don't think it's wise to drive the car in this condition. Please let us know that you're OK.
