Warning--Rear Hatch Opens Very High
Discussion in 'Gen 3 Prius Main Forum' started by stream, Jun 5, 2009.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Maybe mine was just really weak but it only took closing it that way once before I learned not to do it again. I guess others will chime in if they had similar problems. I'm in no way heavy-handed with my cars so it's not like I slammed it either. :)
  2. aforkosh
    aforkosh Active Member
    412
    272
    Oakland, CA
    2023 Prius
    On a Gen II Prius, you get better results pushing against the Toyota emblem above the license plate. You don't even really need to push down. A light push in slams the hatch shut.
    By the way, when I attended the Gen III event in San Francisco, I noticed that there are now 2 handholds on the inside of hatch: one left of center, and one right of center. The left-handed in the group should be happier now.
  3. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    HAHA, We had a nice, but whacky contractor build our garage and I just figured he screwed up. Now I know I'm not alone. :) I never needed to fix it though, our back garage has these cheaper insulated doors, with soft foam in them,... and vinyl on the back, so when it hit, it didn't seem to be a problem!
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Here's what I did. I bought a 6' piece of pipe insulation ($1.38 @ Home Depot), and cut it into 3 pieces. I stapled 1 piece to the center garage door beam, and then put the other 2 pieces on top of it (think of 3 concentric circles--see pic below).
    It's quite thick and pretty soft so if one of my kids forgets to hold the hatch as it opens, it should cushion the impact nicely.
  5. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Nice job - it will also be good protection when Kobe Bryant comes over to visit you.
  6. medaka
    medaka New Member
    Saint Paul, Minnesota, USA
    Happy to see this thread - but it comes too late to save my spoiler! Already has a bit of superficial damage from hitting the garage door today. Anyone here have experience getting paint-touch-ups on the rear spoiler (ours is black)? Any idea how much a *replacement* spoiler would cost? Thanks!
  7. stream
    2,977
    452
    Long Island, NY
    The rear spoiler on the 2010 Prius is plastic so paint repair won't work.
    Getting a replacement won't be cheap. Try some wax on the area, if that doesn't work some rubbing compound might, followed by wax. Good luck.
  8. brad_rules_man
    716
    76
    Effingham
    WOW! I got my 2010 and I really see what you mean. I mean, that rear spoiler literally moves and flexes if you pull on it. I highly recommend you use the inside handle areas.
  9. web1b
    web1b Active Member
    817
    52
    So, there is no convenient place to grab that's outside?
  10. aforkosh
    412
    272
    Oakland, CA
    2023 Prius
    For closing a 2004-2009 hatchback I use a two-step method:
    1) Pull down using the inside handle
    2) As the hatch descends, help it maintain momentum by pushing against the Toyota Emblam in the center of hatch. On those Prii, the emblem was a great leverage point and I see no reason why it shouldn't be on the 2010 either.
    Using this method, you stay away from any flexible parts like the spoiler.
  11. web1b
    web1b Active Member
    817
    52
    That sounds more awkward than it needs to be. They should have put a dedicated, reinforced grab point in a logical spot (maybe as part of the spoiler).
  12. turapeach
    turapeach Member
    100
    36
    Lexington, KY
    Yeah - how strange is it that this has apparently been irritating Prius drivers for years, and yet it still hasn't been fixed? One has to wonder how much it would cost to make the original part stronger and less susceptible to chips.... It's not like there aren't materials out there that could take an occasional tap on a garage door.
  13. stream
    2,977
    452
    Long Island, NY
    A few more observations on this one:
    -the inside handles work great for closing the hatch--grab one and gently pull down until about 3/4 of the way closed, then let go and gravity closes it perfectly--no need to touch the outside surface
    -watch your head if you have a low garage door like mine--you could bang your head on the hatch after reaching in for some packages (ask me how I know... ;))
    -I've washed the car myself so far, but do plan on using a local hand wash car wash, and have made a sign (see attached) to stick inside the hatch window for car wash trips, because the spoiler does seem flimsy and prone to scratching
  14. DeanFL
    1,015
    355
    EXACTLY the method I use on my 2010 (first time Prius owner). The hatch is counter-weighted very well and easy to close. As for opening and allowing to hit something overhead - same as swinging a door open and hitting a wall. Prudence.....
  15. brad_rules_man
    716
    76
    Effingham
    Just what he suggested, though like any car you can just put your hand on the door and slam it shut, might get your hand dusty though. The Toyota emblem area is a good strong place too, but I just hate to touch the outside of a vehicle to close it, so I grab the little hand areas on the inside and get some momentum going and close it. It seems to work well for me.
  16. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Agreed. But I've owned nothing but hatchbacks and station wagons for the last 35 years and I've never had one that had a dedicated grab point on the outside. However, that $16 L shaped hatch handle that I posted about above works very well.
  17. web1b
    web1b Active Member
    817
    52
    That is actually quite ridiculous to need to do that. How many other cars have this issue?
    I suppose if several spoilers break off or are damaged by car wash workers simply shutting the hatch door after cleaning the inside of the window, maybe Toyota will get enough complaints to make it more solid or integrate a dedicated grab handle.
  18. OliverWithPrius
    OliverWithPrius New Member
    Bay Area
    I don't think that's a fair analogy. The hatch door of my 2nd Gen Prius will hit the garage door if I don't park in exactly the right spot (and even then there's about an inch of space). You can't really hold the door down if you need two hands to put something in the trunk (well, at least I can't with my two hands). With the 3rd Gen Prius it now looks like even parking in the right spot isn't going to help.
    As much as I love my 2nd Gen Prius and would love to upgrade, I am disappointed by this design flaw. Guess I'll have to take a measuring tape to tomorrow's "Meet the new Prius" event at my local dealer :(
  19. CtrlAltDelete
    CtrlAltDelete New Member
    Daphne, AL
    My wife has a 2008 and I have a 2010. Next chance I get, I'll open both hatches and snap a pic. I did this the other day, but didn't think to take a pic. I seemed that my 2010 was only slightly higher that the 2008 with the hatch open.
    I have a package V, so I don't know if that changes the ride height compared to the other packages.
  20. phartin
    phartin Cookie Monster
    67
    24
    Dallas, TX
    Another place to be careful is parking garages. Mine got a tiny scratch from opening up and hitting an overhead pipe.
