[WARNING] Running out of gas (Gen III)
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, Jun 26, 2009.
  1. bwilson4web
    16,187
    And I'm OK with this although for another reason. I still believe it is better to let the operator know the engine will no longer run for any reason, including running out of gas.
    As someone else had pointed out, there is a desire for an indication of when the engine is running. That happens to dovetail with another project I've been planning and it is easy enough to incorporate an independent "check engine light" indicator. But what to do in the meanwhile.
    For those who may be curious, this is the latest addition to our Prius kit:
    [​IMG][​IMG][​IMG]
    This is the "Northern Tool + Equipment" part 179057, "Enviro-flow 1-ga. Gas Can P" that fits nicely in the left-hand storage area (NOTE: WalMart sells the same part.) There is an interlock on the valve that requires two-handed operation to open. With the carpet cover, it will avoid direct sunlight and should handle even Alabama summers. Yes, I researched and ordered the part a week ago when I realized what is happening and the time it would take to effect a permanent fix.
    I was hoping this would be a temporary workaround until a better solution came along. No problem, no fault, no foul. Having an answer maps out my course.
    Thanks,
  2. JJJ
    JJJ New Member
    A few years ago a friend "borrowed" our '05. Ran it dry. He put in a gallon, did not help, would not go. Dealer came to pick it up. They put in a gallon. No go. Previously I had read on PriusChat somewhere that it takes 3 THREE gallons to get the fuel pump primed, told the dealer tech, fired right up.
    Remember 3 gallons!!!!!!! (at least on an '05 !!!!)
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I just don't get it. If I ran the tank dry on my FJ, and expected the thing to keep running, I'd be called a fool or an idiot. I've never let the gas tank on any vehicle I've ever owned - Prius included - get below 1/4
  4. RFBrown
    RFBrown New Member
    Vancouver, WA
    Thanks Bob, for all of your testing. ​
    Thanks to those who remind us “Don’t try this at home.”​
    One thing I'm interested in, especially with the other thread on here about the conservative fuel gauge is the physical layout of the tank and the position of fuel pump. It’s said (I don’t have it here to check) that the manual recommends re-filling at a quarter tank, which to me seems like about 4+ gallons remaining in the tank. I wonder if there is any data or consensus on how much fuel is required to cool the pump and keep it running well for a long time. Seems like at a quarter tank, there is a lot of fuel left and while I wouldn’t normally not re-fuel, I might postpone it in certain circumstances if I knew I wasn’t doing long term damage to the fuel pump. ​
  5. LAPriusIV20
    LAPriusIV20 New Member
    30
    Los Angeles
    THANKS FOR THE UPDATE.
    I am striving to get the worst MPG of any member of Prius Chat. I'm at 32 on my current tank and 42 overall with 1700 miles.
  6. rcsting
    rcsting Toyota Fanatic
    282
    112
    Gold River , California
    Congrats I guess :confused:
  7. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    If that's the case, then be certain to use premium gasoline. That will help lower your gas mileage further......:loco:
  8. cmann
    cmann New Member
    I was down to 1 bar and i still didnt get any warning lights. When will i get my warning light?
  9. green curry expert
    green curry expert New Member
    105
    Toronto, Canada
    Very interesting read. Thank you to all the posters who contributed information, especially Bob who performed the test. Now we know how far we can drive before running out of gas.
    The only time I ran out of gas was in my 1992 Corolla. I drove 60km (about 45 miles) between when the fuel warning light turned on and when the engine stopped. I took this as my guideline when I got my 2002 Corolla. One time the fuel warning went on, I drove close to 60km but I never went beyond that knowing the car will run out of gas by then.
    Nowadays I always fill up when the car is 1/4 full. But it's good to know.
    It was also interesting to find out that the fuel gauge ignores the last 1/8 of the tank. I filled up 3 times already and I'm always scratching my head... (one bar left, but I only filled 33L (less than 9 gallons) of gas)
  10. concertinajohnnyboy
    104
    Minneapolis
    This I could not understand in the United States.
  11. bps
    bps Active Member
    304
    119
    Bob, thanks for testing and reporting!
    One question: does the Northern Tool Enviro-flow completely prevent the smell of gas fumes when storing it in your car? I checked Northern Tool's website and they say it "virtually eliminates emissions", but I'm curious if you still smell the gas.
    Thanks!
    Bryan
  12. pdxrose
    pdxrose New Member
    175
    25
    Late to this party but reading though since I filled up 9.6 gallons yesterday shortly after pip started blinking. When I read your post about Atlanta traffic I was reminded why I am soooo happy I no longer live there :D Almost anywhere else four accidents would be fiction but not ATL. I remember all the weekdays over 13 years when I had to plan which of three routes to take home in advance by listening to different radio traffic reports.
    Every few weeks the guy in the heli would say...Kroger truck just ran over a pinto :eek:. Not to mention if you broke down (or ran out of gas) in the wrong place (just about anywhere), you had to lock yourself in the car and pray (even though I am agnostic). Oh and did I mention the 103% humidity...but I do miss the BBQ! I have rented cars in every major city, when working out of town, and I must say that if I was going to run out of gas in a major metro city, the PDX metro would be the place I would want to do it! But I will be sure to fill up as soon as the pip blinks.
    PS I do appreciate the members that do experiment and add so much value...as I still have not had the guts to push the EV button.
  13. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    "I still have not had the guts to push the EV button. "
    That's shocking. :eek:
  14. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    I'm finding all kinds of time I can spent running in EV!
    Yesterday behind a convoy of construction trucks, ran in EV until I was able to pass them. Touch and go traffic on the freeway, Leaving and returning to my residential area. Basically, anytime I can go under 25 mph and have some battery, my rear is in EV!!
    It's totally safe. If you need to go faster, the car automatically kicks you out of EV.
    You gotta go for it girl....
  15. StonePony9/1
    StonePony9/1 New Member
    Re: [WARNING] Running out of gas
    Is the safety issued caused by Toyota not putting in a feature to let you run on the battery when you run out of gas or is it caused by you not refueling before it runs out of gas? Toyota put in a safety feature to help you prevent this safety issue from occuring. it is called the fuel guage.
  16. bwilson4web
    16,187
    You're ignoring the fact that people do run out of gas. For example:
    When you go back and read the whole thread, you'll notice that the earlier models, the NHW11 and NHW20, let us know when the last of the gas was gone. The ZVW30 does not and I would prefer that mine did. You of course are welcome to your opinion but the facts and data show that people still run out of gas ... even in airplanes.
  17. Tad Moody
    Tad Moody New Member
    35
    Duarte, CA, USA
    Um...
    WHO runs out of gas? Is filling up a fuel tank THAT difficult?
  18. bwilson4web
    16,187
    I do it for several reasons:
    1. purge out earlier gasoline - this important when running fuel studies. Otherwise, the previous fuel can dilute the effect of the new fuel.
    2. describe what happens when car runs out of gas - this is to replace Fear Uncertainty and Doubt with facts and data.
    3. answer those who seem to be 'judgmental' about running out of gas with 'it happens and this is what occurs.
    Really, it is just another operational scenario and no big deal unless you are not prepared to deal with it.
  19. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I don't understand why Prius owners are so tied up in getting the most out of a specific tank. Get over it, put gas in the car and run it!! I know an MD that would push his car to the gas station because he would wait too long. He tore his achille's tendon!! On crutches for months. Your mileage is the same if you fill up at 1/4 tank or 1/2 or let it go empty. It's just safer for all to do it before you run out.
  20. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I don't believe for a moment that most "Prius owners are so tied up in
    getting the most out of a specific tank." A relatively small percentage
    are, for God-only-knows-what reasons.
    On the other hand, Bob Wilson has clearly set out the reasons for his
    doing so.
    There are lots of things to still be discovered, tested, and documented
    about the Gen III. No big surprise, many of the operating algorithms
    for the Gen II, and even the Gen I, remain mysteries. And Bob has
    taken on the role of "crash test mannequin" for exploring the
    envelope of what happens when the GEN III runs out of gas/petrol.
    Bob, absolutely no pun or put down intended in the above graphic
    allusion. I use it to suggest the potential for damage that you face in
    your pursuit. You are putting you personal car at risk for all Gen III
    owners' benefit. Good on ya'. You and others did the same thing for
    the Gen II, and we all have benefited, though we rarely know who to
    thank.
    I for one say, thank you. :cheer2:
    And please, keep up the good work. :rockon:
