[WARNING] Running out of gas (Gen III)
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, Jun 26, 2009.
  1. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    efusco, I tried.
    When others, (and I do this too) respond to hyperbole and NOT to the answers/ideas about the topic at hand, it just all spins out of control.
    So I will repeat myself here, as I am interested what you think about these as possible reasons for the change.
  2. bwilson4web
    16,217
    I'm not the first to notice this feature as this MotorWeek review of the 2004 Prius shows:
    MotorWeek: Road Test: Long Term
    MotorWeek has already identified the safety aspect of that expensive EV option and importance of it working. I concur but life it too short to deal with the 'noise' about 'running out of gas.' Running out of gas was just a convenient way to disable the engine but there are others.
    I really don't really care about whether one should or should not run out of gas or should or should not have another, unplanned engine problem. I do care about having an inert vehicle that disables the EV button when the engine fails. I paid good money for that EV capability and to have it arbitrarily disabled denys a capability I paid for. But I also see 'running out of gas' appears to inflame some folks.
    I've already filed my notice with Toyota and will follow it up with a letter. A copy of the letter will go to Motorweek and absent some reply, I know where the NHTSA resides ... they have become 'great friends.'
    Is this enough of a problem that I'll revert to the earlier Prius? DONE! I already have one, an NHW11, 2003 Prius. But this remains a safety issue with my wife's 2010 that sits at home in case she needs to run an errand or we need to do a day-trip.
    Absent resolution or an effective workaround (my next test,) I'll look for a cabin safe, emergency gas can that will fit in the storage compartment by the driver-side, rear. I have one now but it doesn't fit under the cover so I'm shopping:
    • Justrite has Type II Safety and Plastic Gas Cans
    • Northern tools has a couple
    • Marine and lawn equipment suppliers may have some too
    Given the choice between having an EV that works if the engine fails versus having a gallon spare can in my wife's car, I'll take whatever choice is available. The simple solution is to reprogram the car to preserve an important, emergency EV mode.
    Life entails managing risks, after all, no one gets out except by death. But we can mitigate these risks either with the help of others or make our own choices. Given we're Prius owners, face it, we have a certain amount of independent thought, the ability to make the uncommon choice regardless of the opinions of others.
    3 people like this.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Maybe, I guess there may have been a few of these, and problems are more likely to be reported that those who were actually able to use the battery to get to gas or safely to the side of the road. But I'll tell you we've seen no reports like that here or in the other Prius forums. So I'd be quite surprised if that were the reason.
    See above
    I guess I'd need to hear an example of what you're thinking. I just don't see how dead in the middle of an intersection or on a busy highway bridge is safer than 9mph or so in that same situation until the car can pull over to safety.
    My guess is that it's something more complex in the programming, and perhaps even an unintended 'bug' of that programming. Perhaps they couldn't find a good way to both enable EV in the out of gas mode and adequately shut down the system when the SOC got to their predetermined threshold. I just don't believe they would actually intentionally cause the car to be disabled if they could regulate that SOC/speed situation with the current firmware.
  4. fuzzy1
    10,452
    You know your aircraft fuel load to a fraction of an hour. Without user calibration, my various cars have displayed a two hour disagreement.
    You love the precision of flying, but deride attempts to bring similar precision to driving.
    Bob has tried to bring some fuel precision to a particular car model. If you applied your own rule to one of my past cars on my routes, you would have found yourself stranded numerous times -- by the time it started giving warning, it would already be too late to get to an open station. To plan ahead with any precision, before the car gives warning, I want to know the fuel starvation point better than a wishy-washy, 2-hour-uncertain, "refill at X gauge level" rule.
  5. CAR4TWO
    CAR4TWO New Member
    239
    Grants Pass, OR
    If someone is prone to running out of gas, why not have a second 1-gallon gas tank installed? At the flip of a switch, you could instantly while still coasting drop another gallon in the tank and off you go.
    Why travel one mile under electric power when you can drive 50 on a gallon of gas?
  6. Therand
    Therand New Member
    31
    Atlanta, GA
    I have been left stranded in the middle of the interstate before. There were eight lanes of traffic, no possible way for me to exit the vehicle safely, and no way to reach either shoulder. Was it a Prius I or II? No. Was it because I ran out of fuel? No. My fuel system simply decided it was a good time to kick the bucket.
    If I was in a Prius I or II, I could have made it to the side and the rest of this would never have taken place.
    Over the next half hour (the time it took before an officer could halt traffic long enough for me to push the vehicle off the road), I witnessed four accidents. Two were luckily low speed accidents. Two were at moderate speed (25-35mph). While I was lucky enough not to be involved in the accidents themselves, my stalled vehicle was clearly the catalyst. I watched one of the drivers of the two moderate speed accidents as the accident took place. He was looking right at me when his pickup truck climbed right onto the cars in front of him. I never found out if everyone made it out ok. The two low speed accidents took place after the drivers were rubber necking, saw that they were closing too quickly on the rubber necker in front of them, and weren’t able to stop their vehicle in time to avoid a fender bender.
    This was one of two times in my life where I was stuck in my car, terrified, and helpless to do anything about it. I was 19 or 20 at the time of the above. I am now 34 and have a family to think about.
    Now, we (posters to PC) have apparently become polarized on this issue. One side apparently railing against Bob or anyone they consider stupid. And another side looking for support to get a feature returned to an otherwise very cool vehicle.
    I'm not on PC to debate what is stupid or what defines a safe vehicle. I am looking for helpful information to help educate me and make me a better customer.
    So, what can we do? Do we have any recourse with Toyota's engineering team? Does anyone have contacts within Toyota? Maybe we can get to the bottom of this and discover the real reason they put in the lockout.
    It could simply be an oversight and only require a software update. Lord knows I run across software bugs all the time. If its not a bug, they might listen to enough of us and be willing to allow us the ability to override the EV lockout. Thus allowing us the ability to choose EV if the situation is dire.
  7. efusco
    19,891
    1,196
    Nixa, MO
    For the very reasons everyone's been decrying in this thread...
    1) Rarity of need--the gas would likely go bad before it every got used.
    2) Expense--another fuel pump, another tank, electronics to initiate it
    There's also weight & safety to consider,the space that would occupy, etc.
    Whereas a limp/EV would be a simple software issue with no additional expense, weight, space issues or complexity.
  8. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Unfortunately the reporting of information on here often turns into personal attacks. When I first started reading Bob's information, I simply took it as an experiment he ran, found something different and told us about it. Was it a flaw or intentional, If intentional why didn't Toyota tell us about it. Why does Toyota not tells us about anything? I'm certainly not understanding the somewhat frequent attacks on Bob about all this.
    I don't plan on running out of gas (again) but as many of you mentioned there will be times a car stops and it's not necessarily a fuel issue. It would be nice to be able to limp over to the side of the road. Am I worried? No. Do I wish Toyota fixes this? Yes. If they do though it will take time. That will give us a lot of opportunity to hammer on each other. I'm pretty sure Toyota is listening.
    7 people like this.
  9. efusco
    19,891
    1,196
    Nixa, MO
  10. Noz
    Noz New Member
    28
    Los Angeles
    Seriously!
    Mr Wilson was kind enough to let people here know that if you run out of fuel, you're in trouble with this car when, in theory and practice from past models, this shouldn't be the case. It's a step back.
    What certain people here seem to not understand is IF the computer system EVEN THINKS that you ran out of fuel, say due to a failing sensor or malfunction, you're screwed.
    People never think it'll happen to them...and then it does.
    I'm scared sh&tless of flying...I'm a mechanical engineer with an aero degree. People never expect to go down in an aircraft....but it happens. Let's hope it never does.
  11. Zythryn
    6,408
    4,407
    Efusco, you may well be right. Perhaps something was simply missed in the programing and can simply be updated. I actually would agree that is the most likely reason I have heard so far.
    The other ideas I proposed were simply what I saw as possibilities. I don't know the details about what complaints Toyota has had, or what expenses they have had.
    How damaging is it to the battery if it is run down to nothing?
    There are many places in my area where I have seen people driving very agressively around folks driving under 20mph on the shoulder. They get agravated and drive that way. When this is a full width shoulder, not to big a deal. When it is a half shoulder, cars need to move around just a bit. If done carefully, not a big deal. If the driver is agravated...
    I do agree with the 'wouldn't it be nice' aspect. And the information regarding the behavior of the new model and the numbers is FANTASTIC. I thank bob for that info.
    Where I disagree is that this is a life or death issue equivalent to getting into accidents without seatbelts.
    Sure, there have been incidents of people getting in accidents because of running out of gas in bad places. There have also been many more incidents of accidents due to high speeds. Should we have limit all cars to 35mph? That would prevent far more deaths in my opinion than this hubbub about the running out of gas thing.
    No matter what the car's method of motion is, there will always be accidents. Minimizing those is important, but priorities are needed.
  12. CAR4TWO
    CAR4TWO New Member
    239
    Grants Pass, OR
    #1 Stabill will keep the gallon of gas good for one year.
    #2. The extra gallon tank would be gravity fed to the main tank. You go back to the cargo area and turn a spigot if you wanted it mechanical. Keep it simple.
    The real problem with relying on EV mode is that it is only good for one mile. It may or may not even get you off the road. A mile down the freeway is of little use.
  13. efusco
    19,891
    1,196
    Nixa, MO
    If you review my posts in this thread I agree with you and described that as hyperbole and probably what derailed the entire thread and thus we've lost the focus on the real issues...why? and can it be changed back to the way it was in the Prius I & II?
  14. efusco
    19,891
    1,196
    Nixa, MO
    Indeed, that would be a nice way to give true range extension, but you're still talking about extra cost, some space occupation, and a temporarily dead in the road car until you get back there to turn the spigot.
  15. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The problem with this theory is that Toyota already controls the response available from the battery when you press the go pedal. There is no reason that they should not be able to allow some EV mode without allowing such a high amp draw that it damages the battery.
    Seriously, from what I've gathered at PC a mountain climb is likely to be harder on the battery than the out of fuel situation. 1/4 mile runs are probably hard on it too... Yet, Toyota has not yet decided to shut down the car when you approach too steep a grade.
  16. Celtic Blue
    2,224
    139
    Midwest
    That's great to know! And you will live forever because you don't take any unnecessary risks and wear your seat belt. :rolleyes: Time to cancel the insurance as it is just a waste of money.
    Care to share the lotto numbers with me, because my crystal ball is out of calibration at the moment... ;)
  17. fuzzy1
    10,452
    Only 50 miles? The Pacific Northwest has (or had) much longer gasless stretches than that.
    Considering that those most prone to run dry are also prone to get much less than 50 mpg, and more prone to not know whether or not they've passed the midpoint of the 100+ mile gasless stretches (are my biases showing?), the reserve tank should be a bit larger.
  18. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    i assume you are trying for a laugh and don't actually equate the aging process, ending in death, with the process of using gas and running out at the end?
    yes i will die someday. everybody who has ever lived, except those alive today, has died. it's a pretty sure bet.
    i am pretty sure i won't run out of gas though. pretty sure. can't say 100% - that would be silly of me. but yes, pretty sure.
  19. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Bob, keeping w/ the spirit of experimentation - if SOC is well above 2 bars, can you turn off the car, start the car and immediately activate EV for some motive power?
  20. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Thankyou Rick, for returning us to the tenor of Bob's original post, from the trackless deserts that some have ventured to in this thread.
    I too have Qs for Bob on this issue:
    1. In the original versions of the Prius, G1 and G2, when all of the fuel was consumed in your experiments, was the SOC for the Traction Battery simultaneously down to the level at which, under normal conditions, the ICE would have kicked in to re-generate charge?
    2. In your experiments so far with the G3 Prius, does a parallel situation occur? That is, the HV battery reaches a state of simultaneous SOC at which point the ICE would (if gas were present) kick in to re-charge the HV battery. I recall you indicated that there were 2 bars remaining on the SOC indicator. I assume then that this corresponds to the minimum SOC Toyota wants to allow. But did the car actually run out of fuel at a higher SOC?
    One way to check would be to see what happens when operating under the EV-only mode when plenty of gas is present, and noting when the ICE kicks in.
