Warnings lights: (!), ABS, brake. Codes: (!) 65, ABS 42
Discussion in 'Gen 2 Prius Main Forum' started by Javamon31, Aug 28, 2017.
  1. Javamon31
    Javamon31 New Member
    Dallas
    The car:
    2005 Toyota Prius (2nd gen)
    55,033 miles
    History:
    Has been in one extremely wimpy wreck. Hit a curb while turning sharply. I was going < 5 mph. The axle snapped and needed replacing. Had axle replaced. HV battery crapped out immediately after (coincidence?). I rebuilt the battery. Have run diagnostics using Torque OBD2 pro all things seem OK with battery. It drives fine.
    After conditioning battery, II was hoping the (!), brake, and ABS lights would pop off after a reset. They didn't. Tried the OBD2 jumper method. Both came back on. Counted the flashes and here are there error #'s
    (!) 65
    ABS 42
    What I've tried:
    The car drives fine. Stops fine. I checked the relays for superficial damage. Seem fine. Not sure how to check the relay guts yet.
    As a last note, it seems every post looking for help is responded to with at least one "did you check the 12 volt battery?". The 12 volt battery is at it proper voltage when the car is both off and on. I would assume its not the 12 volt battery.
    Thoughts?
    52,847
    didn't you just post that all was well?o_O
    anywho, if your 12v is really at it proper voltage, why not tell us what the proper voltage is?
    Javamon31, Raytheeagle and kenoarto like this.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    And if you waited overnight to do the battery test.
    Javamon31 and bisco like this.
  4. ChapmanF
    19,019
    Have you looked up what the ECB code 65 means for a Gen 2 yet?
    I'm pretty sure the ABS 42 just means "hey, there's an ECB code, go check that."
    However, my techinfo subscription's not paid up at the moment, or I'd look up the 65 for you; in a second gen I'm not sure what that one is offhand.
    -Chap
    Javamon31 likes this.
  5. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    ECB 65 is equivalent to C1344 - Malfunction In Hydraulic System (Rear Left). If you could get the sub-code (could be 581-585), it would help pinpoint the fault.
    Here is a link to the workup for the group of codes that includes that one:
    Diagnostics – ECB – C1341 -C1344
  6. Javamon31
    Dallas
    Hey Chap-
    I've tried looking up the codes. Spent the better part of my free time yesterday searching Google for them. Had no luck. Was hoping someone here might be familiar before I splurged on the techinfo subscription. Thanks for your input!
    Javamon31
  7. Javamon31
    Dallas
    Hi dolj,
    Thanks for the info. I tried to get the codes via an OBD2 adapter at home then at Autozone. No codes are showing up? Could it be an erroneous warning or would both code retrieval methods not pull the codes?
    I read through the workup and I am really having no issue with braking. It would seem those errors would potentially imply a noticeable issue? Granted were it only one brake malfunctioning you'd still have three others to mask the deterioration.
    Thanks!
  8. Javamon31
    Dallas
    Yes I did! All is well with the HV system. I was hoping after that fix the warning lights related to the brake system would shut off after a reset (the red triangle is off now). They did not shut off.
    Measured Aux batt:
    ACC-> ~12.3V
    Ready-> ~14.2V
    I tested for variations in battery bloc behavior using torque obd2 pro. From what I've read there is no quantitative method to this. However, it seems you can infer battery health from the spread of the blocs V while they are all discharged. I did 5 battery drain/charge cycles per day for 3 days (so after an overnight too...). The bloc spread of my graphed data was very tight even compared to what I've spreads indicative of a healthy battery. Maybe the tightness is a bad thing?
    What I thought the issue stem'ed from was the wimpy wreck at < 5 mph and subsequent axle fix. However, as dolj points out the codes refer to a back brake which I didn't expect.
  9. dolj
    dolj Senior Member
    8,641
    4,393
    More likely both methods were not up to the task. If you have the (!) light on, you have a code to be read.
    It may not be noticeable. The malfunction could be that the piston is not applying pressure to the calliper on the left rear.
  10. bisco
    52,847
    12.3v is borderline low. many people are not aware that a new 12v is actually 13+ volts fully charged, and that is what the computer parameters include. when you go to put the car in ready, the voltage drops even lower due to the system load, and can confuse the computers.
    depending on how old yours is, you may want to try charging it and checking it regularly, or replacing it with new, making sure it is fully charged before installing.
  11. dolj
    dolj Senior Member
    8,641
    4,393
    While what is stated here is mostly true:
    • 12.3 V is low;
    • most people are not aware that a fully charged battery, depending on the type, is in the region of 12.9 - 13.2 V;
    • when you go to put the car in ready, the voltage drops even lower due to the system load;
    the load on the start up pulls the voltage ~1.5 V down momentarily, so anything where the standing voltage is less than 12 V gets into the territory of "problematic". Some ECUs can start to see the voltage as a problem when it is in the 10.5 V or lower region.
    Again most people do not realise the high current draw, albeit fleetingly brief, when the (Gen II) Prius goes through the start up cycle.
    It is for these reasons that the posters are advised to check the 12 V and ensure it is a) charged up and b) checked that it can hold its charge under load.
    I would caution the proliferation of advice that gives the impression that a "bad" 12 V battery is the cause of all that ails a Prius. In a lot of cases, it may be a factor that does not aid troubleshooting, it is not often the root cause of the problem(s).
    When giving advice, please be sure to explain what it is that could possibly be the cause so that people get a full understanding of what is really the cause.
    Further, it is just bad advice to recommend to people to purchase a new 12 V battery just because it is old or the standing voltage is low. It may turn out they need a new battery, but unless proper tests and cheaper remedies have been tried and not worked, it is an expensive remedy to just replace these AGM batteries on a whim, given how much they cost. Much easier to advise when it is not your money.
    Javamon31 and fotomoto like this.
  12. ChapmanF
    19,019
    Searching techinfo is never a splurge. :)
    Ok, it would be a splurge, for me to feed it another $15 just to look up your codes. I'm generous, but there have to be limits. But for you to look up your codes, it's pretty cheap.
    I don't know what you'd call your going hourly rate, but I'd assume "the better part of (your) free time yesterday" is worth more than $15 (not counting the extra confusion I often see in PriusChat threads when somebody has googled up a code description that is for some other car or model year, or is unhelpful or just plain wrong).
    A lot of alternative problem-solving strategies I see people coming up with instead of reading the manual seem to have price tags starting higher than $15....
    -Chap
    Javamon31 and dolj like this.
  13. bisco
    52,847
    i can't agree with most of this, only because in most of these cases, we never get a clear answer to the health of the 12v.
    and while it's true that the 12v is not usually the problem, it is the place to start because it is a fairly easy check for a newbie.
    if they can't figure out how to check the 12v health, or refuse to go to the trouble, only giving the answer that they 'tested' it and it is fine, how are they ever going to go beyond that to reading trouble codes, going to the service manual, and beginning the troubleshooting process?
    and i don't agree that replacing a 6 or 7 year old battery just because of its age is a bad idea, even though it is possible to get a few more years out of it.
    that is fine for the experienced owner, who regularly checks the health, understanding the ramifications.
    GrGramps, kenoarto and Raytheeagle like this.
  14. dolj
    dolj Senior Member
    8,641
    4,393
    I never said that the reason not to replace a battery was to get a few more years out of it, it was as you even said:
    Nevertheless, if it is too hard or they won't or can't follow simple instructions then they can't be helped.
    It is still no reason to jump to conclusions not supported by the evidence and recommend they change their 12 V battery anyway. Is all I'm saying.
    #14 dolj, Aug 30, 2017
  15. bisco
    52,847
    peace brother, you know way more about these beasts than i do. i'm just trying to help people out. sometimes i succeed, sometimes i fail, sometimes they are their own worst enemy.
    Raytheeagle and dolj like this.
  16. dolj
    dolj Senior Member
    8,641
    4,393
    Peace to you too brother, I didn't mean to sound aggressive, I apologise if I came across that way.
    Raytheeagle and bisco like this.
  17. bisco
    52,847
