Warranty and “checks”
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by pakitt, Oct 17, 2023.
  1. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    I have carried out at the dealer the four free checks on my 2021 Prime. Two require oil and filter change, while the other two, in between, are “checks”.
    I have only 21k miles and 70% of those are in some form of EV mode (either in EV mode or in HV). Essentially the ICE is hardly used.
    Now, according to the service plan, I am supposed to do another “check” service after 6 months from the last “big one” at the two year mark. Essentially I have to go to waste money for them to check levels.
    If I skip this “check” and instead take the car in for the 3-year “big” service, due early next year, is my warranty void?
    I check regularly by myself oil and coolant/brakes fluid levels, especially before longer trips.
    When I lived in Europe I had to bring in the car only once a year or after 7.5k miles. (Considering the smaller distances, that happened about once a year too.)
    49,399
    you don't have to follow the recommended maintenance schedule or go to a dealer for it.warranty is for factory defects
    pakitt likes this.
  3. pakitt
    2,173
    1,311
    Colorado
    Thank you. This is quite different in Europe. AFAIK, during the warranty period in EU, if you miss a scheduled maintenance or an oil change, as required by the manufacturer, and the warranty is void.
    But at least the maintenance plan doesn’t require you to go every six months to give money to a $tealer for “checks”.
    49,399
    just do the routine maintenance, fluid and filter changes, either yourself, private mechanic, or dealer.
    in a warranty claim, a dealer has to prove that something you did or didn't do caused the failure, to deny warranty coverage.
    dealers get paid by the manufacturer to do warranty work. while they would love to take your money for their overpriced services, it is in their best interest to allow the warranty coverage, as long as they can justify it to the manufacturer
    pakitt likes this.
  5. Trollbait
    11,515
    The service plan that comes with a new Toyota should cover all the required checks at a dealer.
  6. bisco
    49,399
    That would be a great money maker for the dealers.
    Come in for the free check, go home with an empty wallet :p
