Watch my commute.. is this normal?
Discussion in 'Gen 2 Prius Main Forum' started by jefe, Jun 14, 2013.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    ^^ nice analysis.
    Starting out in the cold going uphill with a low battery SOC is a perfect recipe for a high revving, quite inefficient ICE.
  2. jefe
    jefe Member
    169
    50
    Cary, NC
    Thanks uart for that post. The terrain is like is: my drive is very steep but short, then the road is flat for the first quarter. Then there is a short downhill followed by a longer uphill. Then flat again until I arrive to my company's campus. There, it is primarily flat but in the middle there is a really long dip followed by mostly flat.
    Here's my plan, I'm going to replace the 12v this weekend. Then next week, I will document my beginning SOC and mpg for my morning commute.
    Like I said, I may just be hyper aware of it right now and am not accurately reporting the norm.
    Thanks again for taking the time to help me.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I have relatively limited experience.
    But I agree that the problem seems to be the initial state of charge on start up, NOT how The Prius is trying to deal with the low state of charge.
    My Prius is relatively new, but so far in spring and summer temperatures in a 24 hour period the HV battery never seems to discharge overnight to that low of a level.
    I think you need to find out why your battery is discharging nightly.
    Good Luck.
  4. jefe
    jefe Member
    169
    50
    Cary, NC
    Also, I. Don't have EV mode installed. Based on this thread, do you think I would benefit from it? Once I'm on campus at work, I have that stretch where it is low speed and mostly flat or downhill.
  5. uart
    uart Senior Member
    4,220
    1,212
    Australia
    The EV-mod might help as bit, but you've got to use it carefully. Learning about the stages of hybrid operation would also be very beneficial. http://techno-fandom.org/~hobbit/cars/five-stages.txt
    However the single biggest thing you can do to improve your performance is to find out what is causing you to get down to one or two bars of SOC at the start of the trip. Like I said before, take really careful note of the SOC at the exact point when you turn the prius off at the end of the day, and then note the SOC again at the *exact point* that you boot the car the next morning.
    If you find that you're actually losing the SOC *after* the Prius has made ready, then try letting it sit in "P" and idle for approx 60 seconds before driving. That's what I have to do and it definitely works for me.
    BTW. Yes change the 12V battery, it can't hurt.
  6. jefe
    jefe Member
    169
    50
    Cary, NC
    Ok so today when I got in it was green and 7 bars. Within 1 minute, before I was off my own street it was down to one pink bar.
    I will start noting end of day soc.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I'll say it again, try warming up the engine for 60 seconds before driving.
  8. jefe
    jefe Member
    169
    50
    Cary, NC
    That will be my next test. I had already left when I read your tip.
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    (y)
  10. bisco
    52,829
    take it for a nice long drive (you might enjoy it!) and watch the battery level.
  11. jefe
    jefe Member
    169
    50
    Cary, NC
    Feeling much better about my battery this morning. Thanks uart for the great advice. The phases of a hybrid was very interesting and aswered a lot of questions for me (like why sometimes it appeared the ICE wasn't running, but mpg was still really low).
    So with the advice given, this was my experience this morning:
    Sunday night EOD SOC: 6
    Monday am SOC:6
    Started and let it sit, per uart's advice. the ICE showed a direct charge to the battery for about 30 seconds. RPMs dropped and the car went silent, so I drove.
    Commute was much more stable. Lowest the bars dropped was to 5. Stayed 5 or 6 the entire time.
    MPG for this morning: 37.5
    uart likes this.
  12. jefe
    jefe Member
    169
    50
    Cary, NC
    This is why I need a plugin. Short commute. Also, my company has free-to-use charging stations.
  13. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Jeff,
    Have you changed the 12 volt yet?
    I do agree that if you are doing short runs it does help to do what uart suggests. Also, it takes the Prius a good ten minutes before it is fully warmed up even on those warm summer days. By warmed up I mean where the MFD is showing a consistent 50 MPG or better on the MFD.
    Glad to hear you are feeling more comfortable with the new/rebuilt traction battery.
    Also, I am glad to hear you have learned about the 4 stages of the Prius. When one learns the ins and outs of the system, it tends to make it a little easier to operate the Prius to get the best MPG for the trips made. YMMV.
    Ron
  14. jefe
    jefe Member
    169
    50
    Cary, NC
    I haven't changed the 12v yet. I was planning to do it over the weekend, but didn't get time. I'm going to shoot for next weekend. I don't think my 12v situation is dire, since I'm maintaining a 12.2 overnight. But I do believe the time is coming for it. So I am going to try to pick up an Optima yellow top this week and switch it out Saturday.
  15. dorunron
    3,318
    1,105
    Houston, TX
    Jeff,
    Chances are your battery will be Ok through the summer, but will probably let you down come this winter. Keep an eye on the voltage especially if you let the Prius set for more than a couple of days with the SKS system on. In my signature you will find a link that details how to change it out. It is a simple job and only requires a few tools and some common sense.
    Thanks for the update and the reply.
    Ron
    jefe likes this.
  16. jefe
    jefe Member
    169
    50
    Cary, NC
    Thanks for the tip Ron.
    Understanding the phases of hybrid has opened my eyes to so many mpg questions. I knew that document existed but never took the time to read it.
    I think the bulk of my issues stem from my short commute. This morning I had to run an errand that took probably only 20 minutes longer than my commute and my average was 52.8.
    So it really is about getting out of that phase 1.
  17. dorunron
    3,318
    1,105
    Houston, TX
    Jeff,
    Our Prius does not have a "regular commute". It is used as a transport method for two old ailing adults who are caring for one another. It goes back and forth to the doctor, grocery store, and an occasional out of town trip. Hence, a lot of our trips are short.
    It wasn't until I learned about the five stages, the throttle positions which can be monitored by scan gage, tire pressure (critical for the Prius) and hypermiling that I began to actually "beat" the EPA. But I will admit that it is a challenge to "do it" on a day to day basis with the short trips.
    My best advice is to try to combine your trips when possible. And when you do that, go to the furthest one away first. That will allow the Prius to fully warm up and give the best MPG.
    Stage 4 is where you need to be as quickly as possible. It sounds and looks great on paper, but sometimes the conditions with a short trip just won't allow it. However, we both know that it is not impossible.
    Good luck to you.
    Ron
  18. jefe
    jefe Member
    169
    50
    Cary, NC
    Thanks Ron. Explain the throttle positions monitoring.
    Also, here's another question. I know the optimal place to be when the battery is in a good SOC is in the glide. No moving bars. Sometimes, no matter how much a feather it, I can't get it into the glide. Does switching to "N" accomplish the same thing, and is there any harm in doing that?
  19. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Jeff. I see you've found the link to hybrid stages useful. (y)
    You've managed the trick of getting through "stage 1" without running the SOC down too low, and that's helping a lot. The second trick to look into, is getting out of "stage 3" once the engine is warmed up. This is the key to giving the prius good gliding manners.
    Stage 3 is like the hypermilers bugbear. If you're in stage 3 and you try to start a glide from below about 34 MPH (stage 3a) then it just wont do it. In this mode it keeps the engine running indefinitely, so you just cant get a true glide. Even when the "arrows" on the display show no engine (ICE) power, you'll notice that it's still often less than 99.9MPG and the engine is still actually running. Since the engine is already running then the slightest demand for power from the accelerator will normally result in ICE providing it. Take a look at your video and you'll clearly notice this effect in the last few minutes of your journey. You've got plenty of charge (7 bars) but you just can't make full use of it because of that dammed "stage 3".
    So what to do? Well there's basically only two choices (well three if you include just putting up with it, as realistically most people just do so).
    1. You can try to always reach at least 35 MPH before each glide. This can of course be difficult or impossible in some cases due to traffic conditions. However I often manage it by leaving a bit of a gap to the car in front and then accelerating to 35MPH just to release the go pedal and glide.
    BTW. My wife hates it and always yells at me that I'm going to rear end the car in front when I do this.
    One time she asked: "What are you doing accelerating up the arse of the car in front like that?".
    I replied: "I have to make 57 km/h to get the prius to stage 3b for a glide!" (with tone of voice implying this is more important than avoiding an accident).
    She said: "What the heck, this is worse than the DeLorean in Back to the Future!" :ROFLMAO:
    OR
    2. You can try to arrange a stop with the engine running. This is the cue for the Prius to transition to the holly grail of "stage 4", full hybrid mode. Unfortunately you have to be at a complete stop for 7 to 10 seconds with the engine running for this transition to occur. Most people try to arrange it at a regular traffic light stop, but some die hard hypermilers actually make a dedicated stop where they pull over just to allow this to happen.
    One tip if you stop (at lights for example) from more than 34MPH (stage 3b) and therefore the engine has cut out. Is to hold the brake pedal and then tap the accelerator pedal to force the engine to come on. If the engine is warm enough it will idle for 7 to 10 seconds and then cut out, placing you into stage 4 for the remainder of the trip. (If however the engine turns off immediately then it wasn't warm enough, so unfortunate you're still in stage 2 and the procedure didn't work.)
    Data Daedalus and dorunron like this.
  20. dorunron
    3,318
    1,105
    Houston, TX
    My best suggestion would be for you to read the article in my signature that hobbit posted. It is lengthy, but a wealth of info is in there. I don't have the scanguage like you, so I have to rely on the MFD and the various readouts to make an educated guess. I concentrate on that subject when I cannot "glide" (above 42 MPH). There is a threshold that can be found where the Prius will read out 60 MPG and higher at times with certain accelerator positions. It seems to work best on flat surfaces. IIRC some folks call it "dead banding" ("just enough" constant accelerator to maintain speed and allowing speed to fall on uphill and pick back up on down hill) The way I find it is to accelerate to target speed, then let off accelerator just enough to see the instantaneous read out show 60 or more AND the odometer changing speed very slowly or maintaining target speed.
    The trick to getting a true glide is making sure you are in "stage 4". I concentrate on allowing the engine to come to a full stop at traffic lights, stop signs and what have you. It takes a few minutes (usually ten summer time, a little longer winter time) for the ICE to fully warm up. Also, when you have a lower SOC, the ICE will try to kick in to recharge the traction battery. Sometimes it becomes a game to keep tricking the system to keep the ICE off and keep the momentum going until you can regen by slowing down and or braking at the next stop. There are times I still have to use the ICE to pick up some SOC as regen is not as efficient concerning charging of the traction battery. It's a double edged sword but if you can keep the SOC high (5 to 6 bars) and keep the ICE off by hypermiling as much as possible, you can beat the EPA average overall. Note, overall means a average of ALL trips, not just one...
    EDIT: uart's post above is spot on concerning the two methods to get into "Stage 4". I utilize the second step, but at times have also done the first. The main thing is to get into "Stage 4" as quickly as you can. END OF EDIT.
    I believe the correct answer is "No, switching to neutral only disengages the drive lines". When you do that the ICE will stay at whatever stage it is until the transaxle is shifted back to D, B, R, or P. If the ICE is idling and you shift to neutral, the ICE will continue to run, and the injectors will continue to feed fuel (lowering the MPG) There have been post's in the past that state shifting to R from D will cause the ICE to turn off, sometimes that works, other times it does not. Concerning the use of N (neutral): It is best NOT to use it except in a case of emergency or absolute need. When in N, the charging system for the traction battery turns off and does not maintain the normal SOC. If the SOC falls too low, the red triangle will light and the alarm will sound. There will also be a warning appear on the MFD saying to shift to P to allow battery to charge.
    One tip that really helps me is to fully release the accelerator pedal then reapply enough pressure to achieve a glide state and or find that "sweet spot" that hobbit talks about. Feathering seems to be slower and more difficult to find the right position for me.
    NOTE: Hobbit calls feathering what I described in the last paragraph. I describe feathering as easing on and off of the accelerator pedal. Sorry if I added any confusion in my post.
    Ron
    Data Daedalus and uart like this.
