Water-Alcohol Vapor Infusion System ( EWAI )
Discussion in 'Gen 3 Prius Accessories and Modifications' started by engerysaver, Nov 13, 2013.
Thread Status:
Not open for further replies.
  1. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Actually platinum is an amazing (and expensive) catalsyt used in industry (and catalytic converters) becuase trace amounts of platinum can indeed speed up combustion remarkably even in ppm quantities.
    However the OP is not using Platinum.
    OP is trying to utilize "evaporative cooling" to cool the air into the engine (to cool down his radiator becuase he is hauling a 1900-lb RV...:eek:). He is trying to cool the air by vaporizing an alcohol/water mixture. I am thinking there might be a better way such as auxilliary add-on radiator.
  2. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    might want to keep an eye on cvt temp also. The thing is the car is not set up for towing, so doing things to keep engine and cvt temp down may just cause a different type of issue like working the hybrid parts to hard. so I think the OP is playing with fire so to speak.:confused:
    water injection can cool the engine a lot from what I understand so it may be an effective method for this issue of overheat in 100 deg weather towing. If this is how the prius will be used frequently I think it would be wise to pull the trailer with a auto made with towing in mind.:)
  3. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    The central problem.
    A Fred and his money are quickly parted. He extols the virtues of his investment in hopes of bringing more Freds into alignment with his viewpoint. Of course, this is never malicious, but just a matter of enthusiasm (instead of the wiser skepticism) and doubling-down with other people's investments. Because the more popular, the less he can be wrong, right?
    At some point down the line, he may eventually come to the conclusion that the device didn't actually work (pure snake oil), or worked either minimally or at-a-high-drawback (some popular mods-not-to-be-named) to be not really worth the cost/effort from a practical/performance sense.
    The device then comes quietly off the car (or just isn't opted-for in the next vehicle)... and the mistake is never admitted to and nullified out there in greater society.
    Meanwhile, the myths of the device/mods are perpetuated by either word-of-mouth, or linger about in Internet form.
    32kcolors and ftl like this.
  4. xraydoug
    571
    176
    Roseburg, Oregon
    I don't think distance will affect vacuum as long as there is no leaks. I used drip watering stuff like .5 gal hr mister and used a section of clear tubing so I could see how much water was going into the intake. and also had a shutoff so when it ran out I could shut off so I had no vacuum leak. I did have problems with changes in the amount of vacuum the engine had in different situations. My eventual goal was to have a larger tank in the back with a pump that came on with engine if the switch for the pump was in the on position. anyway I never did it because I got a new prius c and I am not going to mess with it very much. I have blocked the grill upper and lower, in these cool temps the engine has to run often so I am thinking of enclosing the under engine area like it is in the regular prius.
    Good luck with your system, but I reccomend if you are towing very much get something else to do it. Just my opinion(y)
    engerysaver likes this.
  5. Tideland Prius
    16,535
    Keep this civil and watch the language or this discussion will end.
    WE0H and usnavystgc like this.
  6. engerysaver
    engerysaver Real Senior Member
    426
    132
    Tyler, Texas ; USA
    Started out with fuel tank full of gas, drove 70.6 miles with 90% highway, driving averaging 65 MPH; and 10% city using electric when possible; with about 500 lbs in Prius, of witch 260 lbs being me!! Had vapor valve 100% open. Gas up again, using 1.098 gallons = 63.3 MPG. A/C was used 50% of time. Still using 60% water, 20% alcohol, 20% methanol; and still using my thin plastic tank ..... I going to replace it when I find time. I know this is not a true test? No warning lights or bells going off!! ........ I know this is my undertaking and I'm pushing the limits!! Time will tell !! ....... But this looks very promising !! :)
    I want to here from anybody that has tried this type of modification (injection or infusion) on a Prius? Please read post # 1 , 29, 41 and 46.
    Please no more negative comments or bad language !!
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    engerysaver
    that look so promising, can't wait to see all final product. Please post all pics if you cann, I just want to do exactly what you did.
    V/r
    Khoi Nguye
  8. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    If we are not allowed to call snake oil snake oil, this forum will be nothing but K&N filter and Royal Purple threads.
    I try to expose the bad ideas, not attack people.
    milkman44, Corwyn, DtEW and 1 other person like this.
  9. engerysaver
    426
    132
    Tyler, Texas ; USA
    My system is based on the, " Mark 2 Air Vapor Bleed Injector System"; the changes that I have made is using 3/8 tubing, different mix, and a funnel for more ram air and not using a vacuum line, but using the air intake. It is working, but I'm still working on some idea's, so it is not finished, yet.
    In 1976 the EPA tested the, " Mark 2 Vapor Injector System", on over stated/ false claims, by using a 1971 Chev. Vega ( a gas guzzler by today's standards ), using Mark 2 mixture of 65% methanol, 34% acetone 1% propylene glycol as 1 part; the other; 2 parts water.
    After 2,000 miles of testing, on page 19 of the report it stated, " A significant 2 % increase in 75 fuel economy was observed by mileage accumulation "and, " no improvements in performance were observed". It went on and said that the purchase price and operating expenses did not justified the minor fuel economy improvement.
    That got me thinking; that was in 1976 when gas was $ .60 a gallon. And on page 18, I found that the Mark 2 mixture was in smaller amounts as reported in their literature ..... ( it was watered down ).
    On page 15, one statement caught my eye, " Thus it was difficult to envision a long term effect of the Mark 2 that would tend to improve only the low speed stop-and-go type driving fuel economy ". That might be good for any fuel efficient vehicle? ...... Prius ?
    This is not, " snake oil "; Open your mind up and think outside of the box. Google " Mark 2 Vapor Injection "; and read the EPA 29 page report. Read the good and bad in it!! If you like this info ..... Press Like, Thank you :) .
    xraydoug and kknguyen1168 like this.
  10. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    And again in 1975 gas will be unleaded and ethanol free, while in 2013 gas is lead free and has 10% ethanol already.
    So with totally different inputs, you hope to show 40 year old testing on a car without fuel injection, unlike 100% of cars today, is still relevant.
    usnavystgc likes this.
  11. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I say let the OP do what he wants while we watch his Prius croak pulling a 1900 lb. RV. Plenty of Prius to replace it if need be.
  12. ETC(SS)
    7,098
    The next time I want to improve the fuel efficiency of a carburated, 1970's car, I'll give it a tumble. :D
    Why are you trying to run your "Like" numbers up BTW???
    Did I miss some new Prius Point Giveaway announcement???
    I concur.
    Let him post his posts....let others post theirs.
    More info....more truth.
    Why stifle debate?
    WE0H likes this.
  13. WE0H
    WE0H Senior Member
    3,247
    528
    Mobile on my SGH-i717
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    All I can say is some people are extremely gullible but, I'm not one of them. Enjoy the needless debate friends, I'm out.
    PS: Press "like" if you like me (lol)
  15. xraydoug
    571
    176
    Roseburg, Oregon
    well I guess many of you will blame the experiment if he has any engine problems. but it will more likely be due to over working the prius engine. and towing in high temp with a poor little car designed for light work and great mpg.
    I would say that most of the things we do with are cars to get better mpg be difficult to prove. like pulse and glide I haven't seen any EPA study that confirms that you get any better mpg than driving steady. yet it is true you do get better mpg pulse and glide.
    some of the posts are not helpfull, some questioning of the mod. is fine. but don't loose sight of the OP this is to cool the engine under extreme conditions of towing in 100 deg heat. injecting water/alchol seemed to work for him. and the concept of that type of system cooling an engine is known with race cars. do a search and there are kits out there and Im pretty sure they do work. usually on turbo charged engines. If the OP trys the system out and his engine temp drops then I'm thinking it cools the engine even if many don't believe.
    someone could also mist water on the radiator and this will increase the amount of heat the radiator can remove from the coolant. this would be a simple mod using a portable mister tip and an rv water pump.
    I do question the wisdom of using an innocent prius to pull that trailer.
  16. ursle
    ursle Gas miser
    1,049
    192
    NH
    But what if there's money in it for you?
  17. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    You're missing much of this entire thread if you think he's injecting anything. This an un-pressurized system. There is no atomizer/injector in the intake. The intake span of the tubing does not actually access any fluid*, but to the air space at the top of the reservoir. A separate length of tubing that goes into the bottom/fluid side is there merely to let air in. As a whole, this is a bubbler/car bong powered by the modicum of negative pressure there is on the intake side. Very little of this fluid is ever consumed, i.e. makes it into the engine. That should tell you something.
    * - speculation was should the intake span actually ingest and pass along any significant amount of fluid, say, from sloshing about... this might have some bad ramifications for the engine.
    Do not confuse this with an actual water-injection system, since they exist for much different reasons, for much different engines, and are implemented much differently. Do understand that there are people who know more than the mere, "what has been done," from a moment of Googling, but rather the "why," and the "how." We can see that this is not one of those systems. Even had it been a bona fide water injection system, you might not be able to get more out of the Prius' Atkinson cycle engine, and it might even incur some real problems.
    This is like sticking a straw into a nostril, and waving the other end near an open bottle of Gatorade, and calling it a glucose IV drip.
    And yeah, there will be people who will declare, "I feel better already!"
    This *could* actually do something, although the OP said nothing about any sort of overheating issue. That said, I think the copious amounts of water vapor that this would generate (and condense into visible steam; water vapor is actually transparent, it's the microcondensates that are visible as steam) out of the engine compartment would cause a bit of concern to both driver and passing cars.
  18. engerysaver
    426
    132
    Tyler, Texas ; USA
    It is relevant; if you look at the general idea; that the atomization of the mixture to a vapor to help burn your gas more efficiently. And in the report, the Mark 2 mixture was , " watered down ". It don't matter if it is a carburetor or fuel injection, neither one turns gas into a " true " vapor !!
    In the mid 1930's and on, the oil company's was buying patents to carburetors that would give more than 200 miles to one gallon of gas. These carburetors were turning gas into a vapor by using electric coils to heat the gas, thus the vapor of the gas was used. The key word is, " vapor ".
    The auto industry knows this; the oil industry will do everything possible to keep their patents from ever being used.
    My Water- Alcohol Infusion System uses 60% water, 20% alcohol, 20% methanol; and I have the tank lower than where the vapor enters the intake, to help against the aspiration of the mixture. The mixture in the tank looks like it will last 3 to 4 months at my current rate of use. My total cost for this modification is $ 35.03 ; but I'm still looking for a proper tank. Will post on testing.
  19. ETC(SS)
    7,098
    I knew if we pulled on this thread long enough that we would get to the 200MPG carburetor.
    Just imagine.
    A car built in the 50's...or 60's.....
    Getting 200 MPG!
    Heck.....that's almost four times the measly 50+MPG that I get from my G3.....and they built some pretty fun cars back then!
    ftl and DtEW like this.
  20. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    This thread has officially jumped... er... hypermiled the shark.
    ftl and Corwyn like this.
Thread Status:
