Water-Alcohol Vapor Infusion System ( EWAI )
Discussion in 'Gen 3 Prius Accessories and Modifications' started by engerysaver, Nov 13, 2013.
Thread Status:
Not open for further replies.
  1. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    LOL I can see it in my imagination a prius pulling a travel trailer with steam pouring out of the engine compartment. and the dirver says nothing wrong with it it is the way it always works pulling the trailer :ROFLMAO:
    I guess this radiator mister would be an attention getter.
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Regarding a misting system. Lol, the radiator doesn't get hot enough to turn even fine droplets of water sprayed on it into steam. If it did, there's a much larger issue.
    The water will absorb a lot of heat, then either evaporate or most likely drip away. No great billowing steam clouds to be seen.
    SCH-I535
  3. xraydoug
    571
    176
    Roseburg, Oregon
    It's like driving in a fog .... moist cool air makes for better MPG; and with the addition of alcohol makes the car use less gas; have better overall performance; more power for pulling loads; ice runs cooler ( great for 1oo + degree days, but since ice runs cooler, grill blocking strategy is a must on less hot days ); more efficient way to burn fuel; helps clean ice carbon buildup.
    My mistake, Im not sure how I got this mixed up. above is one place that mentions ICE runs cooler. I think there were other mentions about the actual temp of engine on some of his testing.
  4. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    And a human mouth certainly isn't hot enough to turn water into steam on a cold day... and yet it does.
    This is why I took pains to define "steam" as microcondensates of water vapor. Most people have this erroneous notion that steam *IS* water vapor (it actually isn't; water vapor is transparent) and steam only comes from boiling water, forgetting all the other manifestations of steam, such as fog, visible breath, etc.
    Steam merely comes about from lots of water vapor, so much so that it starts to condense into microdroplets. These microdroplets refract light and appear as white.
    Water goes into the gaseous state at an entire range of temperatures. It even sublimates from ice.
    When you wet a huge surface area (like a radiator) and favorable ambient conditions, getting enough water vapor into the air to cause steam is not at all far-fetched.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Looks like this thread is getting some people steaming mad :mad:
  6. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Well, if this thing actually took in some steam, it might be more effective. :p
  7. Tideland Prius
    16,547
    This isn't going anywhere.
    Closed.
Thread Status:
