Water Coolant Valve/ Oil Temp Sensor part of Powertrain???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daisy555, Aug 12, 2017.
  1. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Love this guy for learning about cars! See this for an explanation about tires:
  2. daisy555
    daisy555 Senior Member
    1,715
    710
    CT
    water control valve part # 16670-21010 (sorry I called it water coolant valve)
    oil temp sensor part # 89429-47010
    Invoice is packed away but I found my notes regarding part numbers Thx
  3. Patrick Wong
    18,210
    6,510
    Thanks, that is very strange. I've posted images showing the part number for the engine coolant temperature sensor and also looked up the part number you cited. I am 100% sure that there is no oil temperature sensor, and don't know why that is listed on your invoice.
    In any event, it sounds like your car was mostly repaired on Toyota's dime, so hopefully once you buy some tires you'll be good for a while.
  4. daisy555
    1,715
    710
    CT
    Very strange since I had multiple dealers and even an independent hybrid specialist in CA verifying these parts back when repair occurred and they didn't question oil temp sensor. Who knows...it was a nightmare to resolve and hopefully parts will continue to work until I'm done with her. Thanks for asking.
