Water from passenger sunvisor clip
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nougatti, Jan 7, 2018.
  1. Nougatti
    Nougatti Member
    119
    59
    Norway
    The car is a 2012 Plugin, no sunroof. It's gone some 41000 km (25500 mi).
    It's winter time (between -5'C and -15'C (23'F - 5'F) every day) and I'm wondering if any of you other people have had this issue:
    There is sometimes water dripping from the passenger side sunvisor holder/clip/thingy. Not the outer joint, but the little U-shaped receptacle that the visor snaps into, closest to the rear view mirror. Could this be condensation, and is this an issue that could lead to bigger problems if it hasn't been checked? Car ran out its warranty in November 2017, so I guess Toyota aren't gonna "goodwill it" for me either.
    I use a block- and cabin-heater during the mornings. It's a simple system that takes house-power from an outdoor outlet and sends it to both a block-heater (some 6-700 W) and a cabin heater (1900W) mounted on the inner passenger side footwell wall. It's all on a timer and runs from about 6 AM to 8 AM every morning, leaving the car at cosy room temperature for me to drive. The block is probably at around 40-50'C when I start driving.
    I'm guessing that what happens is that the hot air condensates as it meets the cold roof panels behind the headliner and somehow converges to the mounting point of this visor? What can I do to prevent this?
    52,854
    try not heating it and see if it stops, to determine that that is the problem.
    i have read that the ww tube goes through the ceiling to the rear window, and someone had a leak.
    other than that, if it's not raining, I'm baffled.
  3. Nougatti
    Nougatti Member
    119
    59
    Norway
    It's cold as balls. There's no "not heating it".
    Also, I mean obviously, things would be frozen and not dripping if I didn't heat it up.
    I haven't used the rear washer in ages. I also think it would smell terribly if I had washer fluid for the rear window piling up in there.
  4. Nougatti
    Nougatti Member
    119
    59
    Norway
    Called my local dealer.
    The guy thinks there's built up moisture in the air from bringing snow in, evaporating it, and the vapor penetrating the headliner before condensing and freezing in contact with the roof panels. When the car is stationary and getting heated thoroughly by the slightly upwards-facing cabin heater for a few hours, that frozen water up there will melt. He doesn't think it's gonna be an issue apart from when it's very very cold (which it has been), but asked me to take a video of it and see if they can't make a goodwill-case with Toyota (since the warranty IS expired).
  5. bisco
    52,854
    i'm driving around in 7 degree weather with no heat. windshield is the issue, i have to hold my breath.
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    If the car is parked in a garage or under a "carport" or if you have the side window visors you could leave the side windows open a cm or two. I leave Pearl S' front side windows open that much in my garage to allow moisture to escape along with the plastic outgasing stuff.
  7. Nougatti
    Nougatti Member
    119
    59
    Norway
    It's parked outside without cover and I also have no issues with the plastic in my car.
    iPhone ?
  8. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    I recently discovered, during a heavy rain that water is infiltrating also on my 2014 Prius V, but in the middle area of windshield, upper the mirror.
    I searched for a detailed documentation about the black rubber that is between the windshield and the sun roof, but no luck until now.
    Does anybody knows if that rubber can be removed and cleaned?
