Water in taillights
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by gmacfan01, Apr 14, 2015.
  1. gmacfan01
    gmacfan01 Junior Member
    56
    I have the 2012 gen III C i believe and i notices today 2-4 in of water in each taillight. I bought the car from the dealer just under a year ago, and i have never been hit or disassembled the taillights. I called the dealer to see if it is covered under warranty and they said it is not. How much will it cost to fix? I dont really understand how it isnt covered. Is it a complicated process i would like to DIY.
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    turn it upside down and shake it that should do the trick
    honestly though if you look on youtube there might be a video of how to assemble in disassemble the taillight
  3. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Quick search shows you are not the first to have this problem. Escalate this complaint and it might help, and keep any receipts. Below is just one link to remove so you can drain it...and check the seal/s while it's off. Who engineered this thing anyway? I smell a TSB.
  4. gmacfan01
    56
    what i have done for now is drilled holes in the bottom, the oem replacement is only 109 according to the repair shop i go to so i may just be replacing them. Its been raining so i havent been able to actually take them off and check out the seal yet.
  5. gmacfan01
    56
    Jeesh i hope there are not that many steps for the c
  6. RobAustin
    RobAustin Member
    104
    51
    Austin, tx
  7. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
  8. buenavides1
    buenavides1 Junior Member
    27
    2011 Prius Alpha
    This doesn't happen a lot instead there's a crack on your tail light.
